Geometric function
Overview
The Geometric function produces an orthorectified image based on a sensor definition and a terrain model. It increases the positional accuracy of a dataset by accounting for elevation.
To learn about orthorectification, see Introduction to ortho mapping.
Notes
You can use this function when your raster data has rational polynomial coefficients. If you don't have a digital elevation model (DEM), you can specify the Constant Z value, but this generates an inaccurate result; even a low-resolution DEM tends to have better accuracy than a Constant Z value. If you have a DEM, check the Use DEM check box.
Computation time for increasing positional accuracy can be higher for some sensor models. To improve performance, set a Tolerance. This allows for a less rigorous solution, using an approximation to reduce the number of computed transformations. The specified tolerance threshold is the maximum distance from the source point. The default for the NITF (NCDRD) raster type is 2. If left blank or 0 is specified, the approximation is not used.
Parameters
Parameter name |
Description |
Raster |
The input raster. |
Method |
Choose the elevation method for the geometric function:
Constant Z |
Specify a constant elevation to use for the Geometric function. |
DEM |
Specify the DEM to use for the Geometric function. You can use a DEM contained in the mosaic dataset as a raster dataset or as a mosaic dataset whose output is a DEM. |
Z Factor |
Satellite rational polynomial coefficients (RPCs) are scaled for elevation datasets with vertical units in meters. If your elevation uses other vertical units, enter a Z Factor to rescale to meters. For example, if your elevation units are in feet, you would use a value of 0.3048 to convert your elevation units from feet to meters. |
Z Offset |
The base value to be added to the elevation value in the DEM. This could be used to offset elevation values that do not start at sea level. |
Geoid |
Most elevation datasets, such as USGS NED or ArcGIS Online World elevation, are orthometric heights, so it is necessary to select the Geoid correction for compatibility with satellite RPCs, which require ellipsoidal heights. Check the Geoid check box to apply the geoid (EGM96) correction to the z-values, unless your DEM is already referenced to ellipsoidal heights. |
Tolerance |
Specify the maximum tolerable error in the geometric function, given in number of pixels. The default for the NITF (NCDRD) raster type is two. |
