Cached Raster function
Overview
The Cached Raster function creates a preprocessed cache at the point in the function chain where it's added. It is typically inserted in a function chain before the functions that can impede performance due to more computationally intensive processing. These functions can include Convolution, Band Arithmetic, Pansharpen, or Geometric. Multiple Arithmetic functions are also computationally intensive.
Notes
Caution:
This function is only supported when added to the function chain for an item in a mosaic dataset. It is not valid to add this function to the mosaic dataset's function chain or to the function chain on a layer.
You can insert this function when accessing the function chain for each raster in a mosaic dataset using the Raster Functions Batch Editor or the Define Mosaic Dataset Item Cache tool. You can generate the cache for each item when adding the function using the Define Mosaic Dataset Item Cache tool, or you can generate or update the cache using the Synchronize Mosaic Dataset tool with the Build Item Cache parameter checked.
Parameters
Parameter |
Description |
Raster |
The location in the function chain representing the last function output used in this function. This will be populated automatically. |
Cache Path |
The location where the cached dataset will be stored. By default, the cache is generated and stored in a folder next to where the mosaic dataset resides. This folder has the same name as the geodatabase, with a |
Cache Filename |
A system-generated name used to identify the cached dataset. This will appear once the function has been added to the function chain. It cannot be edited. |
Compression |
Specifies the type of compression, if any, that will be used when generating the cache.
The default is Lossless. |
Limits the size of the cache dataset by number of pixels in columns. If the extent of the data cannot fit within this constraint, it will not be generated. The default is 200000. |
Maximum Allowed Rows |
Limits the size of the cache dataset by number of pixels in rows. If the extent of the data cannot fit within this constraint, it will not be generated. The default is 200000. |
Request Size Type |
Specifies the technique that will be used to resample the resolution of the cached raster. Resampling a cached raster can make complicated function chains and intensive processes perform faster.
Request Size |
The pixel size at which the cached raster will be created. The default value is 1. |
