Delete Colormap (Data Management Tools)
Summary
Removes the color map associated with a raster dataset.
Usage
- This tool will not work when the color map is internally stored in the attribute table of an IMG or a TIFF dataset. If the attribute table contains the fields
Red,Green, andBlue, this tool cannot be used.
Parameters
| Label | Explanation | Data type |
Input Raster |
The raster dataset that containing the color map you want to remove. |
Raster Layer |
Derived output
Updated Input Raster |
The output raster dataset. |
Raster Layer |
Environments
This tool does not use any geoprocessing environments.
Licensing information
- Basic: Yes
- Standard: Yes
- Advanced: Yes
