Build Boundary (Data Management Tools)
Summary
Updates the extent of the boundary when adding new raster datasets to a mosaic dataset that extend beyond its previous coverage.
Illustration
Boundary and footprints of a mosaic dataset
Usage
  • Boundaries can only be generated for mosaic datasets stored within a geodatabase.
  • If you remove or add rasters, or modify the extent of the footprints, you should use this tool to rebuild the boundary.
  • If you modify the shape of the boundary polygon (using editing tools), you can use this tool to recreate the original (unmodified) boundary.
Parameters
Label Explanation Data type
Mosaic Dataset
Select the mosaic dataset where you want to recompute the boundary.
Mosaic Layer
Query Definition
(Optional)
An SQL query to compute a boundary for select raster datasets. Use this option in conjunction with the Append to Existing Boundary option to save time when adding new raster datasets.
SQL Expression
Append To Existing Boundary
(Optional)
Specifies whether the perimeter of footprints will be appended to the existing boundary or the boundary will be recalculated in its entirety.
Check this parameter when adding new raster datasets to an existing mosaic dataset. Instead of calculating the entire boundary, only the boundary of the new raster datasets will merged with the existing boundary.
  • Checked—The perimeter of footprints will be appended to the existing boundary. This can save time when adding additional raster data to the mosaic dataset, as the entire boundary will not be recalculated. If there are rasters selected, the boundary will be recalculated to include only the selected footprints. This is the default.
  • Unchecked—The boundary will be recalculated in its entirety.
Boolean
Simplification Method
(Optional)
Specifies the simplification method that will be used to reduce the number of vertices, since a dense boundary can affect performance.
Choose the simplification method to use to simplify the boundary.
  • None—No simplification method will be used. This is the default.
  • Convex hull—The minimum bounding geometry of the mosaic dataset will be used to simplify the boundary. If there are disconnected footprints, a minimum bounding geometry for each continuous group of footprints will be used to simplify the boundary.
  • Envelope—The envelope of the mosaic dataset will provide a simplified boundary. If there are disconnected footprints, an envelope for each continuous group of footprints will be used to simplify the boundary.
String
Derived output
Updated Input Mosaic Dataset
The updated mosaic dataset.
Mosaic Layer
Environments
Parallel Processing Factor
Licensing information
  • Basic: No
  • Standard: Yes
  • Advanced: Yes
