Generate Block Adjustment Report (Data Management Tools)
Summary
Generates a report after performing an ortho mapping block adjustment on a mosaic dataset. The report is useful when evaluating the quality and accuracy of the ortho mapping products.
Usage
  • If the optional control points table is included, the output report will contain the accuracy assessment of the control points, as well as the accuracy assessment of the block adjustment.
Parameters
Label Explanation Data type
Input Mosaic Dataset
The input mosaic dataset path.
Mosaic Dataset; Mosaic Layer
Input Solution Table
The associated solution point table after block adjustment.
Table View
Input Solution Points
The solution point feature class.
Table View
Output Report
The output ortho mapping report file path and name with extension.
File
Input Control Points For Adjustment
(Optional)
The associated control points table, which may include tie points and ground control points.
Table View
Report Format
(Optional)
Specifies the output format of the block adjustment report.
  • HTML—The adjustment report will be created in HTML format. This is the default.
  • PDF—The adjustment report will be created in PDF format.
  • JSON—The adjustment report will be created in JSON format.
  • Brief JSON—The adjustment report will be created in an abbreviated JSON format.
String
Environments
Current Workspace
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
