Remove Depth Map (Data Management Tools)
Summary
Removes the depth map from a mosaic dataset. Other than the depth map removal, the tool will not update the mosaic dataset.
Depth maps are created by running the Compute Depth Map tool.
Usage
The input mosaic dataset is an adjusted mosaic dataset that has been augmented using the Compute Depth Map tool.
A depth map file (
.dm) is created for each input image item comprising the adjusted mosaic dataset. The depth map file is created in the same directory as the source imagery files comprising the original adjusted mosaic dataset.Specify the
.dmfile to remove using an SQL query.
Parameters
| Label | Explanation | Data type |
Input Mosaic Dataset |
The mosaic dataset that will have the depth map removed. |
Mosaic Dataset; Mosaic Layer |
Query Definition (Optional) |
An SQL expression that will be used to select items in the mosaic dataset depth map to be removed. If not specified, all depth map content in the source raster's folder will be removed. |
SQL Expression |
Derived output
Output Mosaic Dataset |
The updated adjusted mosaic dataset. The depth map content associated with source rasters will be deleted. |
Environments
This tool does not use any geoprocessing environments.
Licensing information
- Basic: No
- Standard: Requires ArcGIS Reality for ArcGIS Pro
- Advanced: Yes
