Generate Raster From Raster Function (Data Management Tools)
Summary
Generates a raster dataset from an input raster function or function chain.
Usage
  • The tool is designed for raster processing using multiple threads to help speed up the processing.
  • The output raster format can be TIFF, GRID, ERDAS IMAGINE, CRF (Cloud Raster Format), or MRF (Meta Raster Format).
Parameters
Label Explanation Data type
Input Raster Function
The name of a raster function, raster function JSON object, or function chain (in .rft.xml format).
File; String
Output Raster Dataset
The output raster dataset.
Raster Dataset
Raster Function Arguments
(Optional)
The parameters associated with the function chain. For example, if the function chain applies the Hillshade raster function, set the data source, azimuth, and altitude.
Value table columns:
  • Name—The name of the raster function.
  • Value—The value of the raster function.
Value Table
Raster Properties
(Optional)
The output raster dataset key properties, such as the sensor or wavelength.
  • Name—The name of the key raster property.
  • Value—The value of the key raster property.
Value Table
Format
(Optional)
The output raster format.
The default format will be derived from the file extension specified in the Output Raster Dataset value.
  • TIFF—Tagged Image File Format for raster datasets will be used.
  • Cloud Optimized GeoTIFF—Cloud Optimized GeoTIFF format will be used.
  • ERDAS IMAGINE file—ERDAS IMAGINE raster data format will be used.
  • Esri Grid—Esri Grid raster dataset format will be used.
  • CRF—Cloud Raster Format will be used.
  • MRF—Meta Raster Format will be used.
String
Process as Multidimensional
(Optional)
Specifies whether the input mosaic dataset will be processed as a multidimensional raster dataset.
  • Checked—The input will be processed as a multidimensional raster dataset and all slices will be processed to produce a new multidimensional raster dataset. Set the Format parameter to CRF to use this option.
  • Unchecked—The input will not be processed as a multidimensional raster dataset. If the input is multidimensional, only the slice that is currently displayed will be processed. This is the default.
Boolean
Environments
Cell Alignment, Cell Size, Compression, Current Workspace, Extent, Geographic Transformations, GPU ID, Match Multidimensional Variable, NoData, Output Coordinate System, Parallel Processing Factor, Processor Type, Pyramid, Raster Statistics, Resampling Method, Scratch Workspace, Snap Raster, Tile Size, Union Dimension
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
