Create Ortho Corrected Raster Dataset (Data Management Tools)
Summary
Creates an orthocorrected raster dataset using a digital elevation model (DEM) and control data to accurately align imagery.
Usage
  • For a more accurate result, use the DEM option for elevation. Use a DEM in the orthocorrection process to correct geometric errors caused by relief displacement.
  • Using a constant elevation value for the Orthorectification Type parameter will not yield accurate results and should only be used when no DEM is available and approximate spatial accuracy is acceptable.
  • You can save the output to BIL, BIP, BMP, BSQ, DAT, Esri Grid, GIF, IMG, JPEG, JPEG 2000, PNG, TIFF, MRF, or CRF format, or any geodatabase raster dataset.
  • If using satellite data, rational polynomial coefficients (RPCs) require a DEM referenced to ellipsoidal heights, but most elevation data (such as USGS NED and ArcGIS Online World Elevation) are referenced to sea level orthometric heights. Check the Geoid parameter (Geoid = "GEOID" in Python) to orthorectify with RPCs unless the DEM is referenced to an ellipsoidal height.
Parameters
Label Explanation Data type
Input Raster
The raster dataset or mosaic dataset that will be orthorectified.
The input must have sensor information, such as RPCs, a frame camera model, or an airborne digital sensor (ADS) model.
Raster Dataset; Mosaic Dataset; Mosaic Layer; Raster Layer
Output Raster Dataset
The name, location, and format of the dataset that will be created.
When storing the raster dataset in a file format, specify the file extension as follows:
  • .bil—Esri BIL
  • .bip—Esri BIP
  • .bmp—BMP
  • .bsq—Esri BSQ
  • .dat—ENVI DAT
  • .gif—GIF
  • .img—ERDAS IMAGINE
  • .jpg—JPEG
  • .jp2—JPEG 2000
  • .png—PNG
  • .tif—TIFF
  • .mrf—MRF
  • .crf—CRF
  • No extension for Esri Grid
When storing a raster dataset in a geodatabase, do not add a file extension to the name of the raster dataset.
When storing a raster dataset to a JPEG format file, a JPEG 2000 format file, or a geodatabase, you can specify a Compression Type value and a Compression Quality value in the geoprocessing environments.
Raster Dataset
Specifies whether the orthorectification type will be a DEM or a specified value that represents the average elevation across the image.
  • Constant elevation—A specified elevation value will be used.
  • DEM—A specified digital elevation model raster will be used.
String
Constant Elevation (Meters)
The constant elevation value that will be used when the Orthorectification Type parameter is Constant elevation.
If a DEM is used in the orthocorrection process, this parameter value is not used.
Double
DEM Raster
(Optional)
The DEM raster that will be used for orthorectification when the Orthorectification Type parameter is DEM
Raster Dataset; Mosaic Dataset; Mosaic Layer; Raster Layer; Image Service
Z Factor
(Optional)
The scaling factor that will be used to convert the elevation values in the DEM.
If the vertical units are meters, set the parameter to 1. If the vertical units are feet, set the parameter to 0.3048. If any other vertical units are used, use this parameter to scale the units to meters.
Double
Z Offset
(Optional)
The base value that will be added to the elevation value in the DEM. This can be used to offset elevation values that do not start at sea level.
Double
Geoid
(Optional)
Specifies whether the geoid correction required by RPCs that reference ellipsoidal heights will be made. Most elevation datasets are referenced to sea level orthometric heights, so this correction is required in these cases to convert to ellipsoidal heights.
  • Checked—A geoid correction will be made to convert orthometric heights to ellipsoidal heights (based on EGM96 geoid).
  • Unchecked—No geoid correction will be made. Use NONE only if the DEM is already expressed in ellipsoidal heights.
Boolean
Environments
Cell Size, Compression, Current Workspace, Extent, Geographic Transformations, NoData, Output CONFIG Keyword, Output Coordinate System, Parallel Processing Factor, Pyramid, Raster Statistics, Resampling Method, Scratch Workspace, Snap Raster, Tile Size
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
