Create Pansharpened Raster Dataset (Data Management Tools)
Summary
Combines a high-resolution panchromatic raster dataset with a lower-resolution multiband raster dataset to create a high-resolution multiband raster dataset for visual analysis.
Learn more about pan sharpening
Usage
  • Only the areas that fully overlap will be affected by this tool.
  • You can save the output to BIL, BIP, BMP, BSQ, DAT, Esri Grid, GIF, IMG, JPEG, JPEG 2000, PNG, TIFF, MRF, or CRF format or to any geodatabase raster dataset.
  • The four weight values assigned to the blue, green, red, and infrared bands allow you to adjust the pan-sharpening algorithms.
  • Pan sharpening performed on a three-band raster dataset will produce a raster dataset that has three bands. Pan sharpening performed on a four-band raster dataset will produce a raster dataset that has four bands.
Parameters
Label Explanation Data type
Input Raster
The raster dataset that will be pan sharpened.
Mosaic Dataset; Mosaic Layer; Raster Dataset; Raster Layer
Red Channel
The input raster band that will display with the red color channel.
Long
Green Channel
The input raster band that will display with the green color channel.
Long
Blue Channel
The input raster band that will display with the blue color channel.
Long
Infrared Channel
(Optional)
The input raster band that will display with the infrared color channel.
Long
Output Raster Dataset
The name, location, and format of the raster dataset that will be created.
When storing the raster dataset in a file format, specify the file extension as follows:
When storing a raster dataset in a geodatabase, do not add a file extension to the name of the raster dataset. When storing the raster dataset in a file format, you must specify the file extension:
  • .bil for Esri BIL
  • .bip for Esri BIP
  • .bmp for BMP
  • .bsq for Esri BSQ
  • .dat for ENVI DAT
  • .gif for GIF
  • .img for ERDAS IMAGINE
  • .jpg for JPEG
  • .jp2 for JPEG 2000
  • .png for PNG
  • .tif for TIFF
  • .mrf for MRF
  • .crf for CRF
  • No extension for Esri Grid
When storing a raster dataset to a JPEG format file, a JPEG 2000 format file, a TIFF format file, or a geodatabase, you can specify Compression Type and Compression Quality values in the geoprocessing environments.
Raster Dataset
Panchromatic Image
The higher-resolution panchromatic image.
Raster Layer
Pan-sharpening Type
Specifies the algorithm that will be used to combine the panchromatic and multispectral bands.
  • IHS—Intensity, Hue, and Saturation color space will be used.
  • Brovey—The Brovey algorithm based on spectral modeling will be used.
  • Esri—The Esri algorithm based on spectral modeling will be used.
  • Simple mean—The averaged value between the red, green, and blue values and the panchromatic pixel value will be used.
  • Gram-Schmidt—The Gram-Schmidt spectral-sharpening algorithm to sharpen multispectral data will be used.
String
Red Weight
(Optional)
A value from 0 to 1 that will be used to weight the red band.
Double
Green Weight
(Optional)
A value from 0 to 1 that will be used to weight the green band.
Double
Blue Weight
(Optional)
A value from 0 to 1 that will be used to weight the blue band.
Double
Infrared Weight
(Optional)
A value from 0 to 1 that will be used to weight the infrared band.
Double
Sensor
(Optional)
Specifies the sensor of the multiband raster input.
You can specify the sensor when the Pan-sharpening Type parameter is set to Gram-Schmidt. Specifying the sensor will set appropriate band weights.
  • Unknown—The sensor is unknown or unlisted.
  • BlackSky—The sensor is a BlackSky satellite sensor.
  • Cartosat—The sensor is a Cartosat satellite sensor.
  • DubaiSat-2—The sensor is a DubaiSat-2 satellite sensor.
  • GeoEye-1—The sensor is a GeoEye-1 and OrbView-3 satellite sensor.
  • GF-1 PMS—The sensor is a Gao Fen satellite 1, Panchromatic and Multispectral CCD Camera sensor.
  • GF-2 PMS—The sensor is a Gao Fen 2 satellite, Panchromatic and Multispectral CCD Camera sensor.
  • IKONOS—The sensor is an IKONOS satellite sensor.
  • Jilin-1—The sensor is a Jilin-1 satellite sensor.
  • KOMPSAT-2—The sensor is a KOMPSAT-2 satellite sensor.
  • KOMPSAT-3—The sensor is a KOMPSAT-3 satellite sensor.
  • Landsat 1-5 MSS—The sensor is a Landsat MSS satellite sensor.
  • Landsat 7 ETM+—The sensor is a Landsat 7 satellite sensor.
  • Landsat 8—The sensor is a Landsat 8 satellite sensor.
  • Landsat 9—The sensor is a Landsat 9 satellite sensor.
  • Pléiades-1—The sensor is a Pléiades satellite sensor.
  • Pléiades Neo—The sensor is a Pléiades Neo satellite sensor.
  • Quickbird—The sensor is a QuickBird satellite sensor.
  • SkySat-C—The sensor is a SkySat-C satellite sensor.
  • SPOT 5—The sensor is a SPOT 5 satellite sensor.
  • SPOT 6—The sensor is a SPOT 6 satellite sensor.
  • SPOT 7—The sensor is a SPOT 7 satellite sensor.
  • SuperView-1—The sensor is a SuperView-1 satellite sensor.
  • Tian Hui 1—The sensor is a Tian Hui 1 satellite sensor.
  • THEOS-2—The sensor is a Thailand Earth Observation System-2 (THEOS-2) satellite sensor.
  • Ultracam—The sensor is an UltraCam aerial sensor.
  • Vision-1—The sensor is a Vision-1 satellite sensor.
  • WorldView-2—The sensor is a WorldView-2 satellite sensor.
  • WorldView-3—The sensor is a WorldView-3 satellite sensor.
  • WorldView-4—The sensor is a WorldView-4 satellite sensor.
  • WorldView Legion—The sensor is a WorldView Legion satellite sensor.
  • ZY-1 PMS—The sensor is a Ziyuan High Panchromatic Multispectral Sensor.
  • ZY-3 CRESDA—The sensor is a Ziyuan CRESDA satellite sensor.
  • ZY-3 SASMAC—The sensor is a Ziyuan SASMAC satellite sensor.
String
Environments
Compression, Current Workspace, Extent, Geographic Transformations, NoData, Output CONFIG Keyword, Output Coordinate System, Parallel Processing Factor, Pyramid, Raster Statistics, Resampling Method, Scratch Workspace, Snap Raster, Tile Size
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
