Split Mosaic Dataset Items (Data Management Tools)
Summary
Splits mosaic dataset items that were merged together using Merge Mosaic Dataset Items.
Usage
  • If the selection or query does not contain any merged items, the tool will return an error message.
  • When the tool is run, it removes the merged items from the mosaic dataset table then adds all the originally merged items as new rows.
Parameters
Label Explanation Data type
Mosaic Dataset
The mosaic dataset containing the items to split.
Mosaic Layer
Query Definition
(Optional)
An SQL expression to select items to split.
If the query does not contain any previously merged items, the tool will return an error.
SQL Expression
Derived output
Updated Mosaic Dataset
The updated mosaic dataset.
Mosaic Layer
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: No
  • Standard: Yes
  • Advanced: Yes
