Raster To DTED (Data Management Tools)
Summary
Splits a raster dataset into separate files based on the DTED tiling structure.
Usage
  • There are three levels of the DTED tiling scheme available: DTED level 0, DTED level 1, and DTED level 2.
  • The input can only be a single band raster dataset.
  • The output spatial reference will be GCS_WGS84. Each tile's extent is one degree in each direction, plus a half pixel on each edge so adjacent tiles have one column and row of overlap. The output pixel size is dictated by the DTED level, and the data is converted and stored as signed, 16-bit integers.
  • The DTED format is intended to be used with one band data that represents elevation, so this tool cannot be used for multiband images.
Parameters
Label Explanation Data type
Input Raster
Select a single band raster dataset that represents elevation.
Raster Layer
Output Folder
Select a destination where the folder structure and DTED files will be created.
Folder
DTED Level
Select an appropriate level based on the resolution of your elevation data.
  • Level 0—900 m
  • Level 1—90 m
  • Level 2—30 m
String
Resampling Technique
(Optional)
Choose an appropriate technique based on the type of data you have.
  • Nearest—The fastest resampling method, and it minimizes changes to pixel values. Suitable for discrete data, such as land cover.
  • Bilinear—Calculates the value of each pixel by averaging (weighted for distance) the values of the surrounding 4 pixels. Suitable for continuous data.
  • Cubic—Calculates the value of each pixel by fitting a smooth curve based on the surrounding 16 pixels. Produces the smoothest image, but can create values outside of the range found in the source data. Suitable for continuous data.
String
Derived output
Updated Folder
The folder with the output DTED files.
Folder
Environments
Resampling Method
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
