Split Raster (Data Management Tools)
Summary
Divides a raster dataset into smaller pieces, by tiles or features from a polygon.
Usage
  • The output files will share most of the properties of the input source raster, such as the spatial reference, source type, pixel type, pixel depth, and cell size.
  • The tiling method determines which of the optional parameters are used to determine the dimensions and location of the output tiles. In both cases, NoData values are used to pad the tiles where there is no corresponding source data. The data format depends on the limitations of the individual format specifications and the source image data type. Invalid combinations result in an appropriate error message.
  • If a tile already exists (if there is a file with the same name), it will not be overwritten.
  • If a tile only contains NoData pixel values, it will not be created.
  • Setting the Overlap parameter is recommended if you are working with elevation data, or raster data where you plan to apply focal functions, such as Slope, Aspect, Shaded Relief, and others.
Parameters
Label Explanation Data type
Input Raster
The raster to split.
Mosaic Dataset; Mosaic Layer; Raster Layer
Output Folder
The destination for the new raster datasets.
Folder
Output Base Name
The prefix for each of the raster datasets you will create. A number will be appended to each prefix, starting with 0.
String
Split Method
Determines how to split the raster dataset.
  • Size of tile—Specify the width and height of the tile.
  • Number of tiles—Specify the number of raster tiles to create by breaking the dataset into a number of columns and rows.
  • Polygon features—Use the individual polygon geometries in a feature class to split the raster.
String
Output Format
The format for the output raster datasets.
  • Geotiff (*.tif)—Tagged Image File Format. This is the default.
  • Bitmap (*.bmp)—Microsoft Bitmap.
  • ENVI (*.dat)—ENVI DAT.
  • Esri BIL (*.bil)—Esri Band Interleaved by Line.
  • Esri BIP (*.bip)—Esri Band Interleaved by Pixel.
  • Esri BSQ (*.bsq)—Esri Band Sequential.
  • GIF (*.gif)—Graphic Interchange Format.
  • Esri GRID—Esri Grid.
  • ERDAS IMAGINE (*.img)—ERDAS IMAGINE.
  • JPEG 2000 (*.jp2)—JPEG 2000.
  • JPEG (*.jpeg)—Joint Photographic Experts Group.
  • PNG (*.png)—Portable Network Graphics.
String
Resampling Technique
(Optional)
Choose an appropriate technique based on the type of data you have.
  • Nearest—The fastest resampling method, and it minimizes changes to pixel values. Suitable for discrete data, such as land cover.
  • Bilinear—Calculates the value of each pixel by averaging (weighted for distance) the values of the surrounding 4 pixels. Suitable for continuous data.
  • Cubic—Calculates the value of each pixel by fitting a smooth curve based on the surrounding 16 pixels. Produces the smoothest image, but can create values outside of the range found in the source data. Suitable for continuous data.
String
Number of Output Rasters
(Optional)
The number of columns (x) and rows (y) to split the raster dataset into. The X coordinate is the number of columns and the Y coordinate is number of rows.
Point
Size of Output Rasters
(Optional)
The x and y dimensions of the output tiles. The default unit of measurement is in pixels. The minimum tile size is 16. You can change this with the Units for Output Raster Size and Overlap parameter. The X coordinate is the X (horizontal) dimension the output tiles and the Y coordinate is the Y (vertical) dimension of output tiles.
Point
Overlap
(Optional)
The tiles do not have to line up perfectly; set the amount of overlap between tiles with this parameter. The default unit of measurement is in pixels. You can change this with the Units for Output Raster Size and Overlap parameter.
Double
(Optional)
Set the units of measurement for the Size of Output Rasters parameter and the Overlap parameter.
  • Pixels—The unit is in pixels. This is the default.
  • Meters—The unit is in meters.
  • Feet—The unit is in feet.
  • Degrees—The unit is in decimal degrees.
  • Miles—The unit is in miles.
  • Kilometers—The unit is in kilometers.
String
Cell Size
(Optional)
The spatial resolution of the output raster. If left blank, the output cell size will match the input raster. When you change the cell size values, the tile size is reset to the image size and the tile count is reset to 1.
Point
Lower left origin
(Optional)
Change the coordinates for the lower left origin point, where the tiling scheme will begin. If left blank, the lower left origin would be the same as the input raster.
Point
Split Polygon Feature Class
(Optional)
A feature class that will be used to split the raster dataset.
Feature Layer
Clip Type
(Optional)
Limits the extent of your raster dataset before you split it.
  • None—Use the full extent of the input raster dataset.
  • Extent—Specify bounding box as your clipping boundary.
  • Feature class—Specify a feature class to clip the extent.
String
Template Extent
(Optional)
An extent or a dataset used to define the clipping boundary. The dataset can be a raster or feature class.
  • Current Display Extent Map View—The extent will be based on the active map or scene.
  • Draw Extent Square and Finish—The extent will be based on a rectangle drawn on the map or scene.
  • Extent of a Layer Layer—The extent will be based on an active map layer. Choose an available layer or use the Extent of data in all layers option. Each map layer has the following options:
    • All Features Select All—The extent of all features.
    • Selected Features Area from Selected Features—The extent of the selected features.
    • Visible Features Extent Indicator—The extent of visible features.
  • Browse Browse—The extent will be based on a dataset.
  • Clipboard Paste—The extent can be copied to and from the clipboard.
    • Copy Extent Copy—Copies the extent and coordinate system to the clipboard.
    • Paste Extent Paste—Pastes the extent and coordinate system from the clipboard. If the clipboard does not include a coordinate system, the extent will use the map's coordinate system.
  • Reset Extent Reset—The extent will be reset to the default value.
When coordinates are manually provided, the coordinates must be numeric values and in the active map's coordinate system. The map may use different display units than the provided coordinates. Use a negative value sign for south and west coordinates.
Extent
NoData Value
(Optional)
All the pixels with the specified value will be set to NoData in the output raster dataset.
String
Derived output
Updated Folder
The output folder.
Folder
Environments
Compression, Extent, Geographic Transformations, Output CONFIG Keyword, Output Coordinate System, Parallel Processing Factor, Pyramid, Raster Statistics, Resampling Method, Snap Raster, Tile Size
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
