Raster file formats
The geodatabase is the native data model in ArcGIS for storing geographic information, including raster datasets, mosaic datasets, and raster catalogs. However, there are many file formats you can work with that are maintained outside a geodatabase. The following table includes a description of the supported raster formats (raster datasets) and their extensions and identifies if they are read-only or if they can also be written by ArcGIS.
See Aerial imagery raster types for information about aerial sensor raster file and data types.
Format |
Description |
Extensions |
Read / Write |
Supported data types |
Supports multiband |
Supports compression |
Supports color map |
Airborne Synthetic Aperture Radar (AIRSAR) |
AIRSAR is an instrument designed and managed by NASA's Jet Propulsion Laboratory (JPL). ArcGIS supports the polarimetric AIRSAR data (POLSAR). |
Multiple files with an L, C, or P in the file name followed by |
Read-only |
64-bit complex |
Yes (Six bands) |
No |
No |
ARC Digitized Raster Graphics (ADRG) |
Distributed on CD-ROM by the National Geospatial-Intelligence Agency |
Multiple files Data file—extension Legend file—extension |
Read-only |
8-bit unsigned integer |
Yes (Always three bands) |
No |
No |
ADRG Legend |
ADRG Overview |
ASCII Grid |
The ArcGIS Desktop Advanced ASCII Grid format is an ArcGIS Desktop Advanced Grid exchange file. |
Single file—extension |
Read-only (Write—requires ArcGIS Spatial Analyst extension) |
16-bit signed integer |
No |
No |
No |
32-bit floating point |
No |
No |
No |
AVIRIS |
AVIRIS is an airborne hyperspectral sensor managed by JPL and NASA, with 224 bands between 400 nm and 2,500 nm. Two product levels are available:
ENVI header file extension |
Read-only |
Yes |
No |
No |
Band interleaved by line (BIL), band interleaved by pixel (BIP), band sequential (BSQ) |
This format provides a method for reading and displaying decompressed, BIL, BIP, and BSQ image data. By creating an ASCII description file that describes the layout of the image data, black-and-white, grayscale, pseudo color, and multiband image data can be displayed without translation into a proprietary format. |
Multiple files Data file—extension Header file—extension Color map file—extension Statistics file—extension |
Read and write |
1-,and 4-bit unsigned integer |
Yes |
No |
Yes |
8-, and 16-bit signed and unsigned integer |
Yes |
No |
Yes |
32-bit signed and unsigned integer |
Yes |
No |
No |
Bathymetric Attributed Grid (BAG) |
The Bathymetric Attributed Grid is a nonproprietary file format for storing bathymetric data. |
Read-only |
Yes (Always two bands) |
Yes |
No |
Binary Terrain (BT) |
The Binary Terrain format was created by the Virtual Terrain Project (VTP) to store elevation data in a more flexible file format. The BT format is flexible in terms of file size and spatial reference system. |
Single file—extension Projection file—extension |
Read-only (Write—developer only) |
16- and 32-bit signed integer |
No |
No |
No |
No |
Unknown |
No |
Bitmap (BMP), device-independent bitmap (DIB) format, or Microsoft Windows bitmap |
BMP files are Windows bitmap images. They are usually used to store pictures or clip art that can be moved between different applications on Windows platforms. |
Single file—extension World file—extension |
Read and write |
Yes (Limited to one or three bands) |
No |
Yes |
BSB |
This is a compressed raster format used in the distribution of raster nautical charts by MapTech |
Multiple files—extensions |
Read-only |
Yes |
Yes |
Yes |
Cloud raster format (CRF) |
Optimized for writing and reading large files in a distributed processing and storage environment. In a CRF file, large rasters are broken down into smaller bundles of tiles which allows multiple processes to write simultaneously to a single raster. |
Directory—extension Bundle files—extension |
Read and write |
8-, 16-, and 32-bit unsigned and signed integer, 32-bit floating point, 64-bit complex |
Yes |
Yes |
Yes |
Cloud Optimized GeoTIFF (COG) |
A COG is a regular GeoTIFF that has been optimized for being hosted and worked with on a HTTP file server. Optimization depends on the ability of a COG to store and organize raw pixel data in addition to using HTTP GET requests such that only selected portions of imagery is obtained at a time. |
Single file—possible file extensions
Read and write |
Yes |
Yes |
Yes |
Committee on Earth Observing Sensors (CEOS) |
This format reads CEOS SAR image files—specifically those radar images provided from Radarsat and ERS data products. |
Read-only |
Yes |
No |
No |
Compressed ARC Digitized Raster Graphics (CADRG) |
Distributed by the NGA. CADRG/ECRG is geographically referenced using the ARC system in which the globe is divided into 18 latitudinal bands, or zones. The data consists of raster images and other graphics generated by scanning source documents. CADRG achieves a nominal compression ratio of 55:1. ECRG uses JPEG 2000 compression using a compression ratio of 20:1 |
File extension is based on specific product. |
Read-only |
No |
Vector quantization |
Yes |
Controlled Image Base (CIB) |
Panchromatic (grayscale) images that have been georeferenced and corrected for distortion due to topographic relief distributed by NGA. Thus, they are similar to digital orthophoto quads and have similar applications, such as serving as a base or backdrop for other data or as a simple map. |
Read-only |
No |
Yes |
Digital Geographic Information Exchange Standard (DIGEST) Arc Standard Raster Product (ASRP), UTM/UPS Standard Raster Product (USRP) |
DIGEST datasets are digital replicas of graphic products designed for seamless worldwide coverage. ASRP data is transformed into the ARC system and divides the earth's surface into latitudinal zones. USRP data is referenced to UTM or UPS coordinate systems. Both are based on the WGS84 datum. |
Multiple files Main raster image—extension General information file—extension Georeference file—extension Source file—extension Quality file—extension Transmission header file—extension |
Read-only |
1-, 4-, and 8-bit unsigned integer |
No |
Run length encoding |
Yes |
Digital Image Map |
The DIMAP format is an open format in the public domain; however, its primary purpose was for the distribution of data from the SPOT satellite. The format is composed of a GeoTIFF file and a metadata file. |
Directory |
Read-only |
8-, and 16-bit unsigned integer |
Yes |
TIFF |
TIFF |
Yes |
TIFF |
TIFF |
Digital Terrain Elevation Data (DTED) Level 0, 1, and 2 |
A simple, regularly spaced grid of elevation points based on 1 degree latitude and longitude extents. Created by NGA. |
Single file—various file extensions All possible file extensions are available by default |
Read Write using the Raster to DTED tool |
No |
No |
No |
Digital Video Plotter (DVP) |
The PAR raster type is scanned or digital aerial imagery that has been photogrammetrically processed using the legacy Digital Video Plotter (DVP) system and stored as a |
Earth Surface Mineral Dust Source Investigation Imaging Spectrometer (EMIT) |
The EMIT raster type is NetCDF (recommended) or TIFF. |
ArcGIS supports gridded |
Read and write |
8-, 16-, and 32-bit unsigned and signed integer, 32-bit floating point, 64-bit complex, 8-bit character, and variable length string |
Yes |
No |
Yes |
Enhanced Compressed ARC Raster Graphics (ECRG) |
Distributed by the NGA. CADRG/ECRG is geographically referenced using the ARC system in which the globe is divided into 18 latitudinal bands, or zones. The data consists of raster images and other graphics generated by scanning source documents. CADRG achieves a nominal compression ratio of 55:1. ECRG uses JPEG 2000 compression using a compression ratio of 20:1. |
Read-only |
JPEG 2000 |
No |
Enhanced Compressed Wavelet (ECW) |
ECW is a proprietary format. It is a wavelet-based, lossy compression, similar to JPEG 2000. |
Read-only |
Yes |
Wavelet |
No |
Envisat |
Envisat (Environmental Satellite) is an Earth-observing satellite operation by the European Space agency (ESA). This format supports Advanced Synthetic Aperture Radar (ASAR) Level 1 and above products, and some Medium Resolution Imaging Spectrometer (MERIS) and Advanced Along Track Scanning Radiometer (AATSR) products. |
Multiple data files |
Read-only |
Yes |
No |
No |
ENVI Header |
When ENVI works with a raster dataset, it creates a header file containing the information the software requires. This header file can be created for multiple raster file formats. |
Header file—extension Multiple data files—extension |
Read and write (.dat—via UI) (.bsq, .img, and .raw—developer only |
Yes |
Yes |
Yes |
16-, and 32-bit unsigned and signed integer, and 32-, and 64-bit floating point |
Yes |
Yes |
No |
EOSAT FAST |
The Earth Observation Satellite (EOSAT) FAST format support consists of the following: FAST-L7A (Landsat TM) and FAST Rev. C. (IRS). |
Read-only |
Yes |
No |
No |
ER Mapper ERS |
A proprietary raster format from ER Mapper. Produced using the ER Mapper image processing software. |
Multiple files Header file—extension Data file—usually same as header file without the |
Read-only |
8-, 16-, and 32-bit unsigned and signed integer, and 32-bit floating point |
Yes |
No |
No |
ERDAS 7.5 GIS |
Single-band thematic images produced by ERDAS 7.5 image processing software. |
Multiple files Header file—extension Color map file—extension |
Read-only |
1-, 2-, 4-, 8-, and 16-bit unsigned integer |
No |
No |
Yes |
ERDAS 7.5 LAN |
Single- or multiband continuous images produced by the ERDAS 7.5 image processing software. |
Read-only |
8- and 16-bit unsigned integer |
Yes |
No |
No |
ERDAS 7.5 RAW |
Provides a method for reading and displaying files that are not otherwise supported by another format but are formatted in such a way that the arrangement of the data can be described by a relatively small number of parameters. By creating an ASCII file that describes the layout of the raster data, it can be displayed without translation in a proprietary format. The format is defined in the ERDAS IMAGINE software. |
Read-only |
No |
No |
Yes |
ERDAS IMAGINE |
Produced using IMAGINE image processing software created by ERDAS. IMAGINE files can store both continuous and discrete single-band and multiband data. |
Single file—extension If image is bigger than 2 GB—extension World file—extension |
Read and write |
1-, 2-, and 4-bit unsigned integer |
Yes |
Adaptive run length compressed, or None |
Yes |
8-, 16-bit unsigned and signed integer |
Yes |
Yes |
32-bit unsigned/signed integer |
Yes |
No |
Yes |
No |
No |
64-bit double precision |
Yes |
No |
No |
Esri Grid |
A proprietary Esri format that supports 32-bit integer and 32-bit floating-point raster grids. Grids are useful for representing geographic phenomena that vary continuously over space and for performing spatial modeling and analysis of flows, trends, and surfaces such as hydrology. |
Directory Color map file—extension |
Read and write |
No |
Adaptive run length compressed |
No |
No |
No |
No |
Esri Grid stack |
Used to reference multiple Esri Grids as a multiband raster dataset. A stack is stored in a directory structure similar to a grid or coverage. |
Directory |
Read and write |
Yes |
No |
Yes |
No |
No |
Esri Grid stack file |
Used to reference multiple Esri Grids as a multiband raster dataset. A stack file is a simple text file that stores the path and name of each Esri Grid contained within it on a separate line. |
Single file—possible file extension |
Read and write |
Yes |
No |
Yes |
No |
No |
Extensible N-Dimensional Data Format(NDF) |
Used for storing data representing n-dimensional arrays of numbers, such as images. Uses container files (directories containing files and directories) to manage the data objects. |
Directory—extension |
Read-only |
Yes |
Unknown |
No |
Floating point file |
A floating-point file is a binary file of floating-point values that represent raster data. |
Read-only (Write—Only via Raster To Float tool, or developer code) |
No |
No |
No |
GDAL Virtual Format (VRT) |
This is a file format created by the Geospatial Data Abstraction Library (GDAL). It allows a virtual dataset to be derived from other datasets that GDAL can read. |
8-, 16-, and 32-bit unsigned integer and 64-bit complex integer |
Yes |
Unknown |
Geodatabase Raster |
The geodatabase is the native data structure for ArcGIS and is the primary data format for representing and managing geographic information, including raster datasets and mosaic datasets. The geodatabase is a collection of various types of GIS datasets held in a file system folder. |
Raster datasets stored within |
Read and write |
1-, and 4-bit unsigned integer |
Yes |
Yes |
8-bit unsigned/signed integer |
Yes |
Adaptive run length compressed, JPEG, JP2, or None |
Yes |
16-bit unsigned/signed integer |
Yes |
Adaptive run length compressed, JP2, or None |
Yes |
32-bit unsigned/signed integer, or floating point |
Yes |
No |
Yes |
No |
Yes |
No |
Golden Software Grid (.grd) |
There are two types of Golden Software Grids that are supported: Golden Software Binary Grid (GSBG), and Golden Software Surfer 7 Binary Grid (GS7BG). |
Read and write |
32-bit floating point and 64-bit double precision |
No |
Unknown |
No |
Graphic Interchange Format (GIF) |
A bitmap image format generally used for small images. |
Read and write |
No |
LZW |
Yes |
GRIB |
The gridded binary format is used for the storage, transmission, and manipulation of meteorological archived data and forecast data. The World Meteorological Organization (WMO) is responsible for the design and maintenance of this format standard. |
Read-only |
Yes |
Unknown |
Unknown |
GRIB 2 |
The next generation standard for GRIB. Subdataset support is not available. |
Read-only |
No |
Unknown |
Unknown |
Grid eXchange File |
This is an ASCII format, primarily used in Geosoft |
Read-only |
32- and 64-bit floating point |
No |
No |
No |
HEIF/HEIC |
These are High Efficiency Image File Format and Container formats that offer better compression and image quality. |
Yes |
Yes |
No |
Heightfield |
This is a compressed height field format used to support terrain data as a raster. |
Single file—extension Gzip file—extension |
Read-only |
No |
No |
No |
HGT |
Raw SRTM height files containing elevation measured in meters above sea level, in a geographic projection (latitude and longitude array), with voids indicated using -32768. |
Read-only |
No |
Unknown |
No |
Hierarchical Data Format (HDF) 4 |
A self-defining file format used for storing arrays of multidimensional data. Subdataset support is not available. |
8-, and 16-bit signed integer |
Yes |
Yes |
No |
Yes |
Yes |
Yes |
Yes |
Yes |
No |
Hierarchical Data Format (HDF) 5 |
The next generation standard for HDF. Subdataset support is not available. |
Read-only |
Yes |
Yes |
No |
Yes |
Yes |
Yes |
Yes |
Yes |
No |
Hyperion |
This hyperspectral raster type supports Hyperion products that are delivered in TIFF format. It has a default processing template, which allows you to add all bands to the mosaic dataset. |
GeoTiff, |
Read and Write, as |
12-bit unsigned integer |
Yes |
Yes |
Yes |
High Resolution Elevation (HRE) |
HRE data is intended for a wide variety of National Geospatial-Intelligence Agency (NGA) and National System for Geospatial Intelligence (NSG) partners and members, and customers external to the NSG, to access and exploit standardized data products. HRE data replaces the current nonstandard High Resolution Terrain Elevation/Information (HRTE/HRTI) products and also replaces nonstandard products referred to as DTED level 3 thru 6. This data format is similar to NITF. |
Multiple files Raw image—extension Metadata—extension |
Read-only |
16-bit signed integer and 32-bit floating point |
No |
No |
No |
IDRISI Raster Format (RST) |
File format native to IDRISI |
Multiple files Raw image—extension Descriptor—extension Color map—extension Georeference file—extension |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
ILWIS |
ILWIS format for raster maps and map lists. |
Raster Map— Maplist— |
Read-only |
Byte, 16-, and 32-bit unsigned integer, and 64-bit floating point |
Yes |
No |
No |
Integrated Software for Imagers and Spectrometers (ISIS) |
ISIS Cube format as created by the United States Geological Survey (USGS) for the mapping of planetary imagery. Versions 2 and 3 are supported. |
Read-only |
8-bit unsigned integer and 32-bit floating point |
No |
Unknown |
No |
Japanese Aerospace eXploration Agency (JAXA) PALSAR |
This format was created by the Japanese Aerospace eXploration Agency (JAXA) to store data from processed PALSAR data. Level 1.1 and Level 1.5 are supported. |
Read-only |
Yes |
Unknown |
No |
Joint Photographic Experts Group (JPEG) File Interchange Format (JFIF) |
A standard compression technique for storing full-color and grayscale images. Support for JPEG compression is provided through the JFIF file format. |
Read and write |
JPEG (lossy) |
No |
JPEG 2000 |
A compression technique especially for maintaining the quality of large imagery. Allows for a high-compression ratio and fast access to large amounts of data at any scale. |
Read and write |
8-, and 12-bit unsigned integer |
Yes |
Wavelet (lossy) |
No |
KEA |
An image file format that supports multiple bands and different data types that are smaller in file size. |
Yes |
Yes |
No |
Yes |
Yes |
Yes |
Yes |
Yes |
No |
MAP |
PCRaster's |
Single band |
No |
No |
Single band |
No |
No |
Single band |
No |
No |
Map service cache |
A map cache created by ArcGIS Server can be viewed as a single raster dataset. You cannot build pyramids or calculate statistics. It should not be used for any analysis or processing. |
Directory |
Read-only (in Desktop); write using ArcGIS Server |
Yes |
Yes |
Yes |
Meta Raster Format (MRF) |
MRF is a technology developed by NASA that combines raster storage with cloud computing for tiling, indexing, and multiple resolutions support. It is a raster storage format but also a tile cache format for web services and a dynamic tile cache for another raster. Note:The copy, rename, or delete operations are not supported because an |
Multiple files Raw image—extension Metadata—extension Index—extension |
Read and write |
Yes |
Yes |
Yes |
Multiresolution Seamless Image Database (MrSID) |
A proprietary compression technique especially for maintaining the quality of large images. Allows for a high compression ratio and fast access to large amounts of data at any scale. MrSID is developed and supported by Extensis. Generations 2, 3, and 4 are supported. |
Read-only |
Yes Generation 2 and generation 3—limited to 1 or 3 bands Generation 4—unlimited |
Wavelet (lossy) |
No |
ArcGIS supports gridded Note:Add NetCDF data using the multidimensional data dialog box, not dragging from the Catalog pane, like other datasets listed. Note:NetCDF supports nonraster data types (such as point, trajectory, and others). See What is NetCDF data and associated help topics for more details, including supported data types, structure, management, and so on. |
Read and write |
Yes |
No |
NASA-ISRO Synthetic Aperture Radar (NISAR) |
NISAR radar satellite produces earth observation data using the L-band and S-band SAR frequencies. |
Read-only |
8-, 16-, 32-, and 64-bit unsigned integer 16-, 32-, and 64-bit floating point |
Yes |
Unknown |
No |
National Imagery Transmission Format (NITF) 2.0, NITF 2.1/NSIF 1.0 |
A collection of standards and specifications that allow interoperability in the dissemination of imagery and its metadata among various computer systems. Developed by the NGA. Subdataset support is not available. |
Read
Write
1-, 2-, 4-, 8-, 16-, and 32-bit signed and unsigned integer |
Yes |
Read
Write
Yes |
National Land Archive Production System (NLAPS) |
The NLAPS data format (NDF) is used by the USGS to distribute their Landsat MSS and TM data. |
Multiple files Main file (Header)—extension Image data—extension |
Read-only |
Yes |
No |
No |
NOAA Polar Orbiter Level 1b |
Support for NOAA's Polar Orbiter Data (POD); specifically for the Advanced Very High Resolution Radiometer (AVHRR) Level 1b digital data. |
Multiple files—extension |
Read-only |
Yes |
No |
No |
PCI .aux |
This is a simple ASCII file used and created by PCI to read raw binary raster data. |
Read-only |
8-bit, 16-bit unsigned integer, 16-bit signed integer, and 32-bit |
Yes |
No |
No |
PCIDSK |
PCI Geomatics |
Yes |
Not supported |
Not supported |
Yes |
Not supported |
No |
Yes |
Not supported |
No |
Phase One IIQ |
A proprietary camera RAW format created for Phase One camera that stores the image data in a RAW lossless and smart compressed format. |
Read-only |
Yes |
No |
No |
Portable Document Format (PDF) |
PDF is a versatile file format created by Adobe. It is an open standard format maintained by the International Organization for Standardization (ISO). ArcGIS Pro supports Geospatial PDF documents, by extracting georeferencing information and rasterizing the data. See Opening PDFs in ArcGIS Pro. |
Read-only |
Yes |
No |
No |
Planetary Data System (PDS) |
The Planetary Data System (PDS) is managed by NASA to archive and distribute data from its planetary missions. PDS version 3 is supported. |
Single file—possible extensions |
Read-only |
No |
Unknown |
No |
Portable Network Graphics (PNG) |
Provides a well-compressed, lossless compression for raster files. It supports a large range of bit depths from monochrome to 64-bit color. Its features include indexed color images of up to 256 colors and effective 100 percent lossless images of up to 16 bits per pixel. |
Read and write Note:ArcGIS can read an alpha band from an existing PNG; however, it will only write one- or three-band PNG files. |
No |
Deflate/Inflate |
Yes |
*Yes (limited to one or three bands only, no alpha channel) |
Deflate/Inflate |
Yes |
Deflate/Inflate |
No |
Raster Product Format (RPF) |
The underlying format of CADRG and CIB. |
Single file—no standard file extension |
Read-only |
No |
No |
Yes |
RPF (CIB) |
No |
No |
RPF (CADRG) |
Yes |
Yes |
RPF (ADRG) |
No |
No |
No |
No |
Yes |
SAGA GIS Binary Grid |
SAGA binary grid datasets are composed of an ASCII header ( |
Read-only |
8-, 16-, and 32-bit unsigned, integer, 16-, and 32-bit signed integer, 32-, and 64-bit floating point |
Yes |
No |
No |
Sandia Synthetic Aperture Radar (GFF) |
Sandia National Laboratories created a complex image format to accommodate the data from its synthetic aperture radar. |
Read-only |
16-, and 32-bit complex integer |
Unknown |
Unknown |
No |
Satellogic (multispectral) |
Satellogic four-band multispectral imagery: blue, green, red, and near infrared. |
GeoTiff, |
Read and write |
8- and 16-bit unsigned, integer |
Yes |
Yes |
Yes |
Standard Archive Format for Europe (SAFE) |
Sentinel-1 and RCM data products are distributed using the Standard Archive Format for Europe (SAFE) format specification. |
Multiple files— Product information—extension Image Data—extension Metadata—extension |
Read-only |
8-bit unsigned integer, 16-bit signed integer, 16-bit unsigned integer, 32-bit floating point, and 32-bit integer complex |
Yes |
Unknown |
No |
The HGT format is used to store elevation data from the Shuttle Radar Topography Mission (SRTM). SRTM-3 and SRTM-1 v2 files can be displayed. |
No |
No |
No |
The Spatial Data Transfer Standard (SDTS) was created by the USGS. The purpose of this format is to transfer digital geospatial data between various computer systems in a compatible format that would not lose any information. |
Read-only |
16-bit signed integer or 32-bit floating point |
No |
No |
No |
Tagged Image File Format (TIFF) (GeoTIFF tags are supported) |
Widespread use in the desktop publishing world. It serves as an interface to several scanners and graphic arts packages. TIFF supports black-and-white, grayscale, pseudo color, and true color images, all of which can be stored in a compressed or decompressed format. BigTIFF is supported. |
Single file—possible file extensions World file—extension |
Read and write |
1-bit unsigned integer |
No |
CCITT (1D), CCITT Group 3, CCITT Group 4, Packbits, LZW, or None |
Yes |
4-bit signed integer |
No |
Yes |
Yes |
Packbits, LZW, JPEG (lossy), or None |
Yes |
8-bit signed integer |
No |
LZW |
No |
Yes |
LZW |
Yes |
No |
LZW |
No |
No |
LZW |
No |
Terragen terrain |
The Terragen Terrain file was created by Planetside Software. It stores elevation data. |
Single file—possible file extensions |
No |
Unknown |
No |
TerraSAR-X |
The TerraSAR-X radar satellite produces earth observation data using the X-band SAR. |
Directory |
Read-only |
16-bit unsigned integer and 32-bit complex integer |
No |
No |
No |
Transformation Grids |
National Oceanic and Atmospheric Administration's (NOAA's) files used for shifting a vertical datum. |
Read-only |
No |
No |
No |
United States Geological Survey (USGS) digital elevation model (DEM) |
This format consists of a raster grid of regularly spaced elevation values derived from the USGS topographic map series. In their native format, they are written as ANSI-standard ASCII characters in fixed-block format. |
Read-only |
No |
No |
No |
USGS Digital Orthophoto Quadrangles (DOQ) |
This is the new, labeled DOQ (DOQ2) format from the USGS. |
Read-only |
Yes |
Yes |
No |
Vexcel Osprey |
The Vexcel Osprey simultaneously collects photogrammetry-grade nadir images (PAN, RGB, and NIR) and oblique images (RGB) in four directions. |
JPEG; TIFF with options for 8 and 16 bits, standard TIFF format |
Read-only |
8-bit unsigned integer 16-bit unsigned/signed integer |
Yes |
Yes |
Yes |
WebP |
An image format that provides lossy compression for photographic images. |
Read and write |
Yes |
Yes |
No |
Zarr |
A file format for an n-dimensional array. |
Single file—extension Directory with extension |
Read and write |
8-bit unsigned/signed integer 16-bit unsigned/signed integer 32-bit unsigned/signed integer, or floating point 64-bit unsigned and signed integer, or floating point 32-bit and 64-bit complex floating point. |
Yes |
No |
Yes |
Tip:
TIFF is recommended for most applications.
Dive in:
Most raster formats are supported using the Geospatial Data Abstraction Library (GDAL). For more details on specific formats, see www.gdal.org.
ECW and IIQ raster support is now configurable as an optional installation component. While it remains enabled by default, you have the option to disable ECW and IIQ support during ArcGIS Pro installation.
An A.TOC file cannot be copied and pasted since it requires a specific folder hierarchy and references to other files.
For ERDAS IMAGINE formats, the maximum number of elements (fields x rows) allowed in a raster attribute table is 20,00,000, which can be increased by setting the GDAL configuration option GDAL_RAT_MAX_ELEMENTS.
The bit depth capacity for supported export formats table follows.
= is supported
NA = not applicable
IMG |
TIFF |
GRID |
JPEG |
JP2 |
BMP |
GIF |
PNG |
BIL/BIP/BSQ |
DAT |
Note |
1-bit |
NA |
NA |
Converts to 8-bit for JPEG, JP2, BMP, GIF, PNG, BIL, BIP, BSQ, and DAT. |
2-bit |
NA |
NA |
NA |
NA |
NA |
NA |
NA |
NA |
NA |
4-bit |
NA |
NA |
4-bit color map |
NA |
NA |
NA |
NA |
Converts to 8-bit for BMP, GIF, PNG, BIL, BIP, and BSQ. |
8-bit unsigned |
8-bit signed |
NA |
NA |
NA |
NA |
NA |
NA |
8-bit color map |
NA |
NA |
NA |
8-bit 3 band |
NA |
NA |
8-bit > 3 band |
NA |
NA |
NA |
NA |
16-bit unsigned |
NA |
NA |
NA |
16-bit signed |
NA |
NA |
NA |
NA |
32-bit unsigned |
NA |
NA |
NA |
NA |
NA |
32-bit signed |
NA |
NA |
NA |
NA |
NA |
NA |
NA |
NA |
NA |
