Compute Block Adjustment (Data Management Tools)
Summary
Computes the adjustments to the mosaic dataset. This tool will create a solution table that can be used to apply the actual adjustments.
Usage
  • Use the output control points from the Compute Tie Points tool as the input control points for this tool.
  • The output solution table from this tool will be used in the Apply Block Adjustment tool.
  • The tool requires the ArcGIS Desktop Advanced license when the Transformation Type value is set to RPC or Frame.
  • Many Adjustment Options parameter options are available to optimize the block adjustment solution when the Transformation Type parameter is specified as Frame. See the available settings for the Adjustment Options parameter.
Parameters
Label Explanation Data type
Input Mosaic Dataset
The input mosaic dataset that will be adjusted.
Mosaic Layer; Mosaic Dataset
Input Control Points
The control point table that includes tie points and ground control points.
This feature class is usually the output from the Compute Tie Points tool.
Feature Layer
Transformation Type
Specifies the type of transformation that will be used when adjusting the mosaic dataset.
  • Zero-order polynomial—A zero-order polynomial will be used in the block adjustment computation. This is commonly used when the data is in flat area.
  • First-order polynomial—A first-order polynomial (affine) will be used in the block adjustment computation. This is the default.
  • Rational Polynomial Coefficients—The rational polynomial coefficients (RPCs) will be used for the transformation. This is used for satellite imagery that contains RPC information in the metadata. This option requires the ArcGIS Desktop Advanced license.
  • Frame camera model—The Frame camera model will be used for the transformation. This is used for aerial imagery that contains the frame camera information in the metadata. This option requires the ArcGIS Desktop Advanced license.
String
Output Solution Table
The output solution table containing the adjustments.
Table
Output Solution Points
(Optional)
The output solution points table. This will be saved as a polygon feature class. This output can be quite large.
Feature Class
Maximum Residual
(Optional)
A threshold that is used in block adjustment computation; points with residuals exceeding the threshold will not be used. This parameter applies when the transformation type is Zero-order polynomial, First-order polynomial, or Frame camera model. If the transformation type is Rational Polynomial Coefficients, the proper threshold for eliminating invalid points will be automatically determined.
When the transformation type is Zero-order polynomial or First-order polynomial, the units for this parameter will be map units, and the default value will be 2.
When the transformation type is Frame camera model, the units for this parameter will be pixels, and the default value will be 5.
Double
Adjustment Options
(Optional)
Additional options that will be used to fine-tune the adjustment computation.
To set an option in the Geoprocessing pane, type the keyword and the corresponding value in the list box.
  • MinResidual—The minimum residual value, which is the lower threshold value, will be used. When the transformation type is POLYORDER0 or POLYORDER1, the units will be map units and the default minimum residual value will be 0.
    The minimum residual value and the maximum_residual_value parameter value are used in detecting and removing points that generate large errors from the block adjustment computation.
  • MaxResidualFactor—The maximum residual factor will be used to generate the maximum (upper threshold) residual value if the maximum_residual-value parameter is not defined. In this case, MaxResidualFactor * RMS will be used to calculate the upper threshold value.
    The minimum residual value and the maximum_residual_factor parameter value are used in detecting and removing points that generate large errors from block adjustment computation.
Additional options for the adjustment engine are listed below when Frame is specified for the Transformation Type parameter. The specifications of many of the options are supplied by the data provider.
The options include the following:
  • CalibrateF—Calibrate the sensor's focal length for use in the block adjustment. Assign a value of 1 for focal length calibration or 0 for no calibration. The default is 0.
  • CalibratePP—Calibrate the principle point in the block adjustment. Assign a value of 1 for calibration or 0 for no calibration. The default is 0.
  • CalibrateP—Calibrate for radial distortion parameters in the block adjustment. Assign a value of 1 for calibration or 0 for no calibration. The default is 0.
  • CalibrateK—Calibrate for tangential distortion parameters in the block adjustment. Assign a value of 1 for calibration or 0 for no calibration. The default is 0.
Calibration parameters, such as perspective data, are usually provided for most professional digital aerial cameras, such as UltraCam or DMC. The calibration options can be 0 if camera calibration parameters are prepared in the camera table.
  • APrioriAccuracyX—Include the accuracy of the x-coordinate provided by the airborne Position Orientation System. The units must match PerspectiveX. If the value is set to 0, the x-coordinate of the image location is not adjusted in adjustment. This is not recommended for most UAV data.
  • APrioriAccuracyY—Include the accuracy of the y-coordinate provided by the airborne Position Orientation System. The units must match PerspectiveY. If the value is set to 0, the y-coordinate of the image location is not adjusted in adjustment. This is not recommended for most UAV data.
  • APrioriAccuracyZ—Include the accuracy of the z-coordinate provided by the airborne Position Orientation System. The units must match PerspectiveZ. If the value is set to 0, the z-coordinate of the image location is not adjusted in adjustment. This is not recommended for most UAV data.
  • APrioriAccuracyXY—Include the accuracy of the planar coordinate provided by the metadata. The units must match PerspectiveX. If the value is set to 0, planar coordinates (x and y) of the image location are not adjusted in adjustment. This is not recommended for most UAV data.
  • APrioriAccuracyXYZ—Include the accuracy of image location provided by the metadata. The units must match PerspectiveX. If the value is set to 0, the image location is not adjusted in adjustment. This is not recommended for most UAV data.
  • APrioriAccuracyOmega—Include the accuracy of the Omega angle provided by the airborne Position Orientation System. The units are in decimal degrees.
  • APrioriAccuracyPhi—Include the accuracy of the Phi angle provided by the airborne Position Orientation System. The units are in decimal degrees.
  • APrioriAccuracyOmegaPhi—Include the accuracy of the Omega or Phi angle provided by the airborne Position Orientation System. The units are in decimal degrees.
  • APrioriAccuracyKappa—Include the accuracy of the Kappa angle provided by the airborne Position Orientation System. The units are in decimal degrees.
  • ComputeAntennaOffset—Compute the offset between GNSS antenna center and camera projection center in adjustment. Assign a value of 1 to compute or 0 for no computation. The default is 0.
  • ComputeShift—Compute the GNSS signal shift in flights in bundle adjustment. Assign a value of 1 to compute or 0 for no computation. The default is 0.
  • ComputeImagePosteriorStd—Compute the posterior standard deviation of image location and orientation after adjustment. Assign a value of 1 to compute or 0 for no computation. The default is 1.
  • ComputeSolutionPointPosteriorStd—Compute the posterior standard deviation of solution points after adjustment. Assign a value of 1 to compute or 0 for no computation. The default is 0.
  • rigCamera—Allow processing of a multiple camera rig in the block adjustment. Assign a value of 1 to use the rigCamera module or a value of 0 to not use the rigCamera module. If a value of 1 is assigned, the relationship of multiple cameras in the adjustment will be computed. The default is 0.
Value table columns:
  • Name—The name of the adjustment option.
  • Value—The value for the adjustment option.
Value Table
Image Location Accuracy
(Optional)
Specifies the geometric accuracy level of the images.
This parameter is only active if the Transformation Type parameter is specified as Rational Polynomial Coefficients.
If low accuracy is specified, the control points will first be improved by an initial triangulation; then they will be used in the block adjustment calculation. The medium and high accuracy options do not require additional estimation processing.
  • High accuracy—The accuracy will be 30 meters or less.
  • Medium accuracy—The accuracy will be between 31 meters and 100 meters. This is the default.
  • Low accuracy—The accuracy will be more than 100 meters.
  • Very High accuracy—The imagery was collected with a high-accuracy, differential GPS, such as RTK or PPK. This option will keep image locations fixed during block adjustment.
String
Output Adjustment Quality Table
(Optional)
An output table used to store adjustment quality information.
Table
Refine by DEM
(Optional)
An input DEM from which elevations will be sampled as ground control points for refining the geometric accuracy of the image network in the adjustment.
This parameter is only active when the Transformation Type parameter is specified as Frame camera model.
Raster Dataset; Raster Layer; Mosaic Dataset; Mosaic Layer
Elevation Accuracy of DEM
(Optional)
The elevation accuracy of the input DEM. The accuracy value will be used as a weight for the sampled ground control points in the adjustment.
Double
Environments
Current Workspace, Scratch Workspace
Licensing information
  • Basic: No
    Requires the ArcGIS Desktop Advanced license when the Transformation Type value is set to RPC or Frame.
  • Standard: Requires ArcGIS Reality for ArcGIS Pro
  • Advanced: Yes
