Interpolate From Point Cloud (Data Management Tools)
Summary
Interpolates a digital terrain model (DTM) or a digital surface model (DSM) from a point cloud.
Usage
  • The form of the point cloud can be either LAS files or a solution point table.
Parameters
Label Explanation Data type
Input LAS Folder, LAS Dataset or Point Table
The path and name of the input file, folder, feature layer, or LAS dataset. The input can be a folder of LAS files, a solution point table from Ortho mapping tools, or an LAS dataset. For cloud storage, provide the cloud storage path, such as C:\Temp\Cloud.acs\las.
The LAS files can be the output from the Generate Point Cloud tool in which LAS points are categorized as ground and above ground. A solution point table is output from the Compute Block Adjustments or Compute Camera Model tool.
Folder; File; Feature Class; Feature Layer
Output Raster
The output raster dataset location, name, and file extension. You can also save the output raster dataset by providing a cloud storage path such as C:\Temp\Cloud.acs\lasfolder.
The output can be created in most writable raster formats, such as TIFF, CRF, or IMG.
Raster Dataset
Cellsize
The cell size of the output raster dataset.
Double
Interpolation Method
(Optional)
Specifies the method that will be used to interpolate the output raster dataset from the point cloud.
  • TIN linear interpolation—The triangulation method will be used. It is also known as triangulated irregular network (TIN) linear interpolation and is designed for irregularly distributed sparse points, such as solution points from block adjustment computation.
  • TIN natural neighbor interpolation—The natural neighbor method will be used. It is similar to triangulation but generates a smoother surface and is more computationally intensive.
  • Inverse distance weighted average interpolation—The inverse distance weighted (IDW) average method will be used. It is used for regularly distributed dense points, such as point cloud LAS files from the Generate Point Cloud tool. The IDW search radius is automatically computed based on average point density.
String
Smoothing Method
(Optional)
Specifies the filter that will be used to smooth the output raster dataset.
  • Gaussian 3 by 3—A Gaussian filter with a 3 by 3 window will be used.
  • Gaussian 5 by 5—A Gaussian filter with a 5 by 5 window will be used.
  • Gaussian 7 by 7—A Gaussian filter with a 7 by 7 window will be used.
  • Gaussian 9 by 9—A Gaussian filter with a 9 by 9 window will be used.
  • No smoothing—No smoothing filter will be used.
String
Surface Type
(Optional)
Specifies whether a digital terrain model or a digital surface model will be created.
  • Digital terrain model—A digital terrain model will be created by interpolating only the ground points.
  • Digital surface model—A digital surface model will be created by interpolating all the points.
String
Input Fill DEM
(Optional)
A DEM raster input that is used to fill NoData areas. Areas of NoData may exist where pixels do not have enough information from the input to generate values.
Raster Dataset; Raster Layer; Mosaic Dataset; Mosaic Layer
Classify Ground Options
(Optional)
Classify ground points from the input LAS data.
This parameter is active when the Surface Type parameter is set to Digital terrain model.
To set an option in the Geoprocessing pane, type the Name keyword method that will be used to detect ground points, and the corresponding value in the list box.
  • Classify—Classify the ground using different options depending on the type of terrain. The options are not case sensitive.
    • standard—This method has a tolerance for slope variation that allows it to capture gradual undulations in the ground's topography that would typically be missed by the conservative option, but not capture the type of sharp relief that would be captured by the aggressive option. This is the default.
    • conservative—When compared to other options, this method uses a tighter restriction on the variation of the ground's slope that allows it to differentiate the ground from low-lying vegetation such as grass and shrubbery. It is best suited for topography with minimal curvature.
    • aggressive—This method detects ground areas with sharp relief, such as ridges and hilltops, that may be ignored by the standard option. This method is best used in a second iteration of this tool with the ReuseGround option set to 1. Avoid using this method in urban areas or flat, rural areas, since it may result in the misclassification of taller objects—such as utility towers, vegetation, and portions of buildings—as ground.
  • LowNoise—The distance below the ground that will be used to classify the point to be low-noise points. The unit is meters. The default value is 0.25 meter.
  • HighNoise—The distance above the ground that will be used to classify the point to be high-noise points. The unit is meters. The default value is 100 meters.
  • ReuseGround—Specifies whether existing ground points will be reclassified or reused. A value of 0 specifies reclassify, and a value of 1 specifies reuse. The default value is 0.
  • ReuseLowNoise—Specifies whether existing low-noise points will be reused or reclassified. A value of 0 specifies reclassify, and a value of 1 specifies reuse. The default value is 0.
  • ReuseHighNoise—Specifies whether existing high-noise points will be reused or reclassified. A value of 0 specifies reclassify, and a value of 1 specifies reuse. The default value is 0.
Value table columns:
  • Name—The name of the adjustment option.
  • Value—The value for the adjustment option.
Value Table
Environments
Cell Alignment, Current Workspace, Extent, Geographic Transformations, Mask, Output Coordinate System, Parallel Processing Factor, Pyramid, Scratch Workspace
Licensing information
  • Basic: No
  • Standard: Requires ArcGIS Reality for ArcGIS Pro
  • Advanced: Yes
