Create Random Raster (Data Management Tools)
Summary
Creates a raster dataset of random values with a distribution you define.
Usage
  • You can save your output to Esri Grid, CRF, IMG, TIFF, or any geodatabase raster dataset.
  • The values assigned to each cell in the output raster are derived from the random number generator and the selected distribution type. There are several random number generators available. Review the Random Number Generator environment to determine the one to use. The random number generator starts a stream of random numbers based on the generator type and a seed value. These numbers are randomly determined and the values fall between 0 and 1. Each value is independent of the other values.
    Multiple distribution types are available for the random number generators when assigning (or transforming) the values in the output raster. The distributions generally produce different results, and the distribution to use is determined by the end use of the raster. If the random raster is to model a natural phenomenon, the distribution selected should be the best representation of the process of the phenomenon.
    For a description of the distributions and how they are typically used, see Distributions for assigning random values.
  • The processing times for the Uniform, Integer, Normal, and Exponential distribution options are independent of their arguments. The processing times for the Poisson, Gamma, Binomial, Geometric, and Pascal options can vary considerably when arguments are changed.
  • A default value is calculated for the cell size parameter if no value is provided. This value is based on the size of the extent.
  • On the tool dialog box, the values of the Output extent parameter are in the coordinate system of the map. When the tool is run, the extent will be projected to the Output Coordinate System if it is specified in the environment settings.
Parameters
Label Explanation Data type
Output Location
The folder or geodatabase where the output raster dataset will be stored.
Workspace
Raster Dataset Name with Extension
The name and format of the raster dataset you are creating.
To store the output as a raster dataset in a geodatabase, do not add a file extension to the raster dataset name.
For file-based rasters, use the appropriate extension to specify the format to create as follows:
  • .tif—TIFF raster
  • .img—ERDAS IMAGINE raster
  • .crf—CRF raster
  • No extension—Esri Grid
String
Distribution
(Optional)
Specifies the random value distribution method to use.
Each type has one or two settings to control the distribution.
  • Uniform—A uniform distribution with the defined range between the Minimum and Maximum values. The default values are 0.0 for Minimum and 1.0 for Maximum. This is the default.
  • Integer—An integer distribution with the defined range between the Minimum and Maximum values. The default values are 1 for Minimum and 10 for Maximum.
  • Normal—A normal distribution with defined Mean and Standard Deviation values. The default values are 0.0 for Mean and 1.0 for Standard Deviation.
  • Exponential—An exponential distribution with a defined Mean value. The default value is 1.0.
  • Poisson-—A Poisson distribution with a defined Mean value. The default value is 1.0.
  • Gamma—A gamma distribution with defined Alpha and Beta values. The default values are 1.0 for Alpha and 1.0 for Beta.
  • Binomial—A binomial distribution with defined N and Probability values. The default values are 10 for N and 0.5 for Probability.
  • Geometric—A geometric distribution with a defined Probability value. The default value is 0.5.
  • Negative Binomial—A Pascal distribution with defined r and Probability values. The default values are 10.0 for r and 0.5 for Probability.
To edit the default value, click the value in the table and type the new value.
String
Output extent
(Optional)
The extent of the output raster dataset.
  • Current Display Extent Map View—The extent will be based on the active map or scene.
  • Draw Extent Square and Finish—The extent will be based on a rectangle drawn on the map or scene.
  • Extent of a Layer Layer—The extent will be based on an active map layer. Choose an available layer or use the Extent of data in all layers option. Each map layer has the following options:
    • All Features Select All—The extent of all features.
    • Selected Features Area from Selected Features—The extent of the selected features.
    • Visible Features Extent Indicator—The extent of visible features.
  • Browse Browse—The extent will be based on a dataset.
  • Clipboard Paste—The extent can be copied to and from the clipboard.
    • Copy Extent Copy—Copies the extent and coordinate system to the clipboard.
    • Paste Extent Paste—Pastes the extent and coordinate system from the clipboard. If the clipboard does not include a coordinate system, the extent will use the map's coordinate system.
  • Reset Extent Reset—The extent will be reset to the default value.
When coordinates are manually provided, the coordinates must be numeric values and in the active map's coordinate system. The map may use different display units than the provided coordinates. Use a negative value sign for south and west coordinates.
Extent
Cellsize
(Optional)
The spatial resolution of the output raster dataset.
Double
Build raster attribute table
(Optional)
Specifies whether the tool will unconditionally build a raster attribute table for the output raster in which the selected distribution results in an integer output raster.
This parameter has no effect if the output raster is floating point.
  • Checked—A raster attribute table will be unconditionally built for integer output rasters. This is the default.
  • Unchecked—A raster attribute table will not be built for integer output rasters if the number of unique values is greater than or equal to 65535. If the number of unique values is less than 65535, a raster attribute table will be built.
Boolean
Derived output
Output raster dataset
The output raster dataset.
Raster Dataset
Environments
Extent, Output Coordinate System, Pyramid
Licensing information
  • Basic: Requires 3D Analyst or Spatial Analyst
  • Standard: Requires 3D Analyst or Spatial Analyst
  • Advanced: Yes
