Export Mosaic Dataset Paths (Data Management Tools)
Summary
Creates a table of the file path for each item in a mosaic dataset. You can specify whether the table contains all the file paths or just the ones that are broken.
Usage
  • The output of this tool is a table, either in a geodatabase or a .dbf file.
Parameters
Label Explanation Data type
Mosaic Dataset
The mosaic dataset containing the file paths to export.
Mosaic Layer
Output Table
The table to create. The table can be a geodatabase table or a .dbf file.
The SourceOID field in the output table is derived from the OID of the row in the original mosaic dataset table.
Table
Query Definition
(Optional)
An SQL expression to select specific rasters for export.
SQL Expression
Export Mode
(Optional)
Populate the table with either all of the paths, or only the broken paths.
  • All paths—Export all paths to the table. This is the default.
  • Broken paths only—Export only broken paths to the table.
String
Types of paths to export
(Optional)
Choose to export file paths from only the source raster, only the cache, or both. The default is to export all path types.
  • Raster—Export file paths from rasters.
  • Item cache—Export file paths from item cache.
String
Environments
Current Workspace, Extent, Output CONFIG Keyword, Scratch Workspace
Licensing information
  • Basic: No
  • Standard: Yes
  • Advanced: Yes
