Create Referenced Mosaic Dataset (Data Management Tools)
Summary
Creates a separate mosaic dataset from items in an existing mosaic dataset.
Usage
  • A referenced mosaic dataset can be created in a geodatabase or a folder. When the mosaic dataset is created in a folder, it will not include a boundary.
  • Overviews cannot be created for a referenced mosaic dataset.
  • Use this tool to create a mosaic dataset from another mosaic dataset when you want to create a mosaic dataset with a different output. For example, you can create one mosaic dataset with elevation data and create another that will be used to produce a derived product, such as slope or hillshade.
Parameters
Label Explanation Data type
Mosaic Dataset
The mosaic dataset from which items will be selected.
Mosaic Layer; Mosaic Dataset
Output Mosaic Dataset
The referenced mosaic dataset to be created.
Mosaic Dataset
Coordinate System
(Optional)
The projection for the output mosaic dataset.
Coordinate System
Number of Bands
(Optional)
The number of bands that the referenced mosaic dataset will have.
Long
Pixel Type
(Optional)
The bit depth, or radiometric resolution, of the mosaic dataset. If this is not defined, it will be taken from the first raster dataset.
  • 1-bit—The pixel type will be a 1-bit unsigned integer. The values can be 0 or 1.
  • 2-bit—The pixel type will be a 2-bit unsigned integer. The values supported can range from 0 to 3.
  • 4-bit—The pixel type will be a 4-bit unsigned integer. The values supported can range from 0 to 15.
  • 8-bit unsigned—The pixel type will be an unsigned 8-bit data type. The values supported can range from 0 to 255.
  • 8-bit signed—The pixel type will be a signed 8-bit data type. The values supported can range from -128 to 127.
  • 16-bit unsigned—The pixel type will be a 16-bit unsigned data type. The values can range from 0 to 65,535.
  • 16-bit signed—The pixel type will be a 16-bit signed data type. The values can range from -32,768 to 32,767.
  • 32-bit unsigned—The pixel type will be a 32-bit unsigned data type. The values can range from 0 to 4,294,967,295.
  • 32-bit signed—The pixel type will be a 32-bit signed data type. The values can range from -2,147,483,648 to 2,147,483,647.
  • 32-bit floating point—The pixel type will be a 32-bit data type supporting decimals.
  • 64-bit—The pixel type will be a 64-bit data type supporting decimals.
String
Query Definition
(Optional)
An SQL expression to select raster datasets that will be included in the output mosaic dataset.
SQL Expression
Extent from Dataset
(Optional)
Select raster datasets based on the extent of another image or feature class. Raster datasets that lay along the defined extent will be included in the mosaic dataset. To enter the minimum and maximum coordinates directly, use the Extent parameter.
Feature Layer; Raster Layer
Extent
(Optional)
The minimum and maximum coordinates for the extent. If a dataset is selected in Extent from Dataset, those coordinates will automatically appear here.
Envelope
Using Input Geometry for Selection
(Optional)
Limit the extent to the shape or envelope when a feature class is specified in the Extent from Dataset parameter.
  • Checked—Select using the shape of the feature. This is the default.
  • Unchecked—Select using the extent of the data in the feature class.
Boolean
Scale Field
(Optional)
Legacy:
This parameter has been deprecated and is ignored in tool execution. It remains for backward compatibility reasons.
Field
Minimum Cell Size Field
(Optional)
Specify a field from the footprint attribute table that defines the minimum cell size for displaying the mosaic dataset; otherwise, only a footprint will be displayed.
Field
Maximum Cell Size Field
(Optional)
Specify a field from the footprint attribute table that defines the maximum cell size for displaying the mosaic dataset; otherwise, only a footprint will be displayed.
Field
Maximum Visible Cell Size
(Optional)
Set a maximum cell size to display the mosaic instead of specifying a field. If you zoom out beyond this cell size, only the footprint will be displayed.
Double
Build Boundary
(Optional)
Rebuild the boundary. If the selection covers a smaller area than the source mosaic dataset, this is recommended.
This is only available if the mosaic dataset is created in a geodatabase.
  • Checked—The boundary will be generated or updated. This is the default.
  • Unchecked—The boundary will not be generated.
Boolean
Environments
Current Workspace, Extent, Output CONFIG Keyword, Scratch Workspace
Licensing information
  • Basic: No
  • Standard: Yes
  • Advanced: Yes
