Generate Exclude Area (Data Management Tools)
Summary
Masks pixels based on their color or by clipping a range of values. The output of this tool is used as an input to the Color Balance Mosaic Dataset tool to eliminate areas such as clouds and water that can skew the statistics used to color balance multiple images.
Usage
  • This tool is used to exclude areas that will be difficult to color correct, such as water, clouds, and anomalous areas.
  • The output of this tool can be used in the Color Balance Mosaic Dataset tool to exclude pixels (and colors) from the algorithm used to color correct the mosaic dataset.
Parameters
Label Explanation Data type
Input Raster
The raster or mosaic dataset layer that you want to mask.
Mosaic Dataset; Raster Dataset; Raster Layer
Output Raster Dataset
The name, location and format for the dataset you are creating. When storing a raster dataset in a geodatabase, do not add a file extension to the name of the raster dataset. When storing your raster dataset to a JPEG file, a JPEG 2000 file, or a geodatabase, you can specify a Compression type and Compression Quality within the Environment Settings.
Raster Dataset
Pixel Type
Choose the pixel depth of your input raster dataset. 8-bit is the default value; however, raster datasets with a greater bit-depth will need to have the color mask and histogram values scaled accordingly.
  • 8 bit—The input raster dataset has values from 0 to 255. This is the default.
  • 11 bit—The input raster dataset has values from 0 to 2047.
  • 12 bit—The input raster dataset has values from 0 to 4095.
  • 16 bit—The input raster dataset has values from 0 to 65535.
String
Generate Method
Create your mask based on the color of the pixels or by clipping high and low values.
  • Color mask—Set the maximum color values to include in the output. This is the default.
  • Histogram percentage—Remove a percentage of high and low pixel values.
String
Maximum Red
(Optional)
The maximum red value to exclude. The default is 255.
Double
Maximum Green
(Optional)
The maximum green value to exclude. The default is 255.
Double
Maximum Blue
(Optional)
The maximum blue value to exclude. The default is 255.
Double
Maximum White
(Optional)
The maximum white value to exclude. The default is 255.
Double
Maximum Black
(Optional)
The maximum black value to exclude. The default is 0.
Double
Maximum Magenta
(Optional)
The maximum magenta value to exclude. The default is 255.
Double
Maximum Cyan
(Optional)
The maximum cyan value to exclude. The default is 255.
Double
Maximum Yellow
(Optional)
The maximum yellow value to exclude. The default is 255.
Double
Low Percentage
(Optional)
Exclude this percentage of the lowest pixel values. The default is 0.
Double
High Percentage
(Optional)
Exclude this percentage of the highest pixel values. The default is 100.
Double
Environments
Current Workspace, Extent, Geographic Transformations, Output Coordinate System, Scratch Workspace, Snap Raster
Licensing information
  • Basic: No
  • Standard: Yes
  • Advanced: Yes
