Compute Dirty Area (Data Management Tools)
Summary
Identifies areas within a mosaic dataset that have changed since a specified point in time. This is used commonly when a mosaic dataset is updated or synchronized, or when derived products, such as cache, need to be updated. This tool will enable you to limit such processes to only the areas that have changed.
Usage
This tool constructs a polygon that defines regions containing one or more mosaic dataset items that have been modified since a specified point in time.
This allows tools and applications that depend on the mosaic dataset for the construction of derived products, such as cache, to perform partial updates since the last time the derived products were synchronized with the mosaic dataset.
The date and time parameter can be specified in one of two following ways:
XML time sting
Non-XML string
A valid XML time string must be in one of the following formats:
YYYY-MM-DD
Thh:mm:ssYYYY-MM-DD
Thh:mm:ss.ssssZYYYY-MM-DD
Thh:mm:ss.ssss-00:00YYYY-MM-DD
Thh:mm:ss+00:00YYYY
YYYY-MM
YYYY-MM-DD
YYYY-MM-DD
ZYYYY-MM-DD
ThhYYYY-MM-DD
ThhZYYYY-MM-DD
Thh:mmYYYY-MM-DD
Thh:mmZYYYY-MM-DD
Thh:mm:ssYYYY-MM-DD
Thh:mm:ssZ
The last possible part of the XML time strings is the time zone. The time zones specified with a
Zrefers to Zulu Time, or Greenwich Mean Time. You can also specify a time zone by using the positive or negative hours from Zulu Time. If you do not specify a time zone, then the local time zone will be used.Valid Non-XML time strings can take on any format shown below:
YYYY/MM/DD hh:mm:ss.s
YYYY/MM/DD hh:mm:ss
YYYY/MM/DD hh:mm
YYYY/MM/DD hh
YYYY/MM
YYYY-MM-DDhhmmss.s
YYYY-MM-DDhhmmss
YYYY-MM-DDhhmm
YYYY-MM-DDhh
YYYY-MM-DD
YYYY-MM
YYYYMMDDhhmmss.s
YYYYMMDDhhmmss
YYYYMMDDhhmm
YYYYMMDDhh
YYYYMMDD
YYYYMM
YYYY
Parameters
| Label | Explanation | Data type |
Mosaic Dataset |
The mosaic dataset that you want to analyze for changes. |
Mosaic Layer |
Query Definition (Optional) |
SQL expression to select specific rasters within the mosaic dataset on which to compute dirty areas. |
SQL Expression |
Start Date and Time |
Compute the areas that have changed since the input time. XML time syntax:
Non-XML time syntax:
String |
Output Feature Class |
The feature class containing the areas that have changed. |
Feature Class |
Environments
Current Workspace, Extent, Scratch Workspace
Licensing information
- Basic: No
- Standard: Yes
- Advanced: Yes
