Update Interior Orientation (Data Management Tools)
Summary
Refines the interior orientation for each image in the mosaic dataset by constructing an affine transformation from a fiducial table.
Usage
  • The input fiducial table is the output from the Compute Fiducials tool.
  • This tool can be used to update the film coordinate system of the images in a mosaic dataset, for example, when the images are rotated incorrectly after adding them to a mosaic dataset.
Parameters
Label Explanation Data type
Input Mosaic Dataset
The mosaic dataset that is created from scanned aerial photos using the scanned raster type or frame camera raster type.
Mosaic Layer
Query Definition
(Optional)
A query definition string that defines a subset of rasters for computing fiducials.
SQL Expression
Fiducial Table
The fiducial table created using the Compute Fiducials tool.
Table View
Film Coordinate System
Defines the film coordinate system of the scanned aerial photograph. It is used in computing fiducial information and affine transformation construction.
  • No change—Maintain the coordinate system of the mosaic dataset. Do not change the film coordinate system of the scanned aerial photograph. Maintain the coordinate system of the mosaic dataset.
  • X right, Y up—The origin of the scanned photo's coordinate system is the center, and positive X points right and positive Y points up.
  • X up, Y left—The origin of the scanned photo's coordinate system is the center, and positive X points up and positive Y points left.
  • X left, Y down—The origin of the scanned photo's coordinate system is the center, and positive X points left and positive Y points down.
  • X down, Y right—The origin of the scanned photo's coordinate system is the center, and positive X points down and positive Y points right.
String
Update Footprints
(Optional)
Generates or updates the footprints of the digital photos in the mosaic dataset.
  • Checked—The footprints will be generated or updated.
  • Unchecked—The footprints will not be generated or updated. This is the default
Boolean
Derived output
Output Mosaic Dataset
The updated mosaic dataset.
Mosaic Layer
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: No
  • Standard: Requires ArcGIS Reality for ArcGIS Pro
  • Advanced: Yes
