Repair Mosaic Dataset Paths (Data Management Tools)
Summary
Resets paths to source imagery if you have moved or copied a mosaic dataset.
Usage
  • You need to know the file path location in order to change it. You can use the Export Mosaic Dataset Paths tool to retrieve the original path names.
  • You can type an asterisk (*) as the original path if you wish to change all your paths.
  • Database fragmentation and frequent data manipulation can significantly increase the size of a mosaic dataset. If the database size is large due to constant transactions, run the Compact tool.
Parameters
Label Explanation Data type
Mosaic Dataset
The mosaic dataset with the broken paths.
Mosaic Layer
Paths List
A list of the paths to remap. Include the current path stored in the mosaic dataset and the path to which it will be changed. You can enter an asterisk (*) as the original path if you wish to change all your paths.
Value table columns:
  • Original Path—The path that you want to change.
  • New Path—The path that you want to map the data to.
Value Table
Query Definition
(Optional)
An SQL expression to limit the repairs to selected rasters within the mosaic dataset.
SQL Expression
Derived output
Repaired Input Mosaic Dataset
The updated mosaic dataset.
Mosaic Layer
Environments
Extent, Parallel Processing Factor
Licensing information
  • Basic: No
  • Standard: Yes
  • Advanced: Yes
