Add Colormap (Data Management Tools)
Summary
Adds a new color map or replaces an existing color map on a raster dataset.
Usage
  • The color map applied to the input raster dataset can originate from a raster dataset that already has a color map, a .clr file, or an .act file.
  • This tool will not work when the color map is internally stored in the attribute table of an IMG or a TIFF dataset. If the attribute table contains the fields Red, Green, and Blue, this tool cannot be used.
  • The input raster dataset must be a single band raster dataset with integer values. Color maps can only be created for single-band raster datasets with a pixel depth of 16-bit unsigned or fewer. Certain formats cannot have a color map associated with them; please consult Supported raster dataset file formats.
Parameters
Label Explanation Data type
Input Raster
The raster dataset to add or replace a color map.
Raster Layer
Input Template Raster
(Optional)
A raster dataset that has a color map that you want to apply to the input raster dataset.
Raster Layer
Input .clr or .act File
(Optional)
Specify a .clr or .act file to use as the color map.
File
Derived output
Updated Input Raster
The output raster dataset.
Raster Layer
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
