An overview of the Domains toolset
The Domains toolset contains tools to create and edit domains to manage attribute fields.
Domains are a way to define a range of values that can be used for multiple attribute fields. Using domains helps ensure data integrity by limiting the choice of values for a particular field. Validation for coded value domains is accomplished by restricting field values in drop-down lists. Range domains are automatically validated during editing.
Tool
Add Coded Value To Domain
Adds a value to a domain's coded value list.
Alter Coded Value Description
Updates the description of an individual, existing coded value pair.
Alter Domain
Alters the properties of an existing attribute domain in a workspace.
Assign Domain To Field
Sets the domain for a particular field and, optionally, for a subtype. If no subtype is specified, the domain is only assigned to the specified field.
Create Domain
Creates an attribute domain in the specified workspace.
Delete Coded Value From Domain
Deletes a value from a coded value domain.
Delete Domain
Deletes a domain from a workspace.
Domain To Table
Creates a table from an attribute domain.
Remove Domain From Field
Removes an attribute domain association from a feature class or table field.
Set Value For Range Domain
Sets the minimum and maximum values for an existing Range domain.
Sort Coded Value Domain
Sorts the code or description of a coded value domain in either ascending or descending order.
Table To Domain
Creates or updates a coded value domain with values from a table.
