Create Domain (Data Management Tools)
Summary
Creates an attribute domain in the specified workspace.
Usage
  • Domain management involves the following:
    1. Create the domain using this tool.
    2. Add values to or set the range of values for the domain using the Add Coded Value to Domain or Set Value For Range Domain tool.
    3. Associate the domain with a feature class using the Assign Domain To Field tool.
  • Coded value domains only support default value and duplicate split policies and default value merge policies.
  • Range domains support all split and merge policies. After a split or merge operation, the attribute values of output features are calculated based on the numeric values of the input features and the specified split or merge policy.
  • The maximum length of the Domain Name parameter value is determined by the geodatabase as follows:
    • File geodatabase—160 characters
    • Mobile geodatabase—257 characters
    • Enterprise geodatabase—257 characters
Parameters
Label Explanation Data type
Input Workspace
The geodatabase that will contain the new domain.
Workspace
Domain Name
The name of the domain that will be created.
String
Domain Description
(Optional)
The description of the domain that will be created.
String
Field Type
(Optional)
Specifies the type of attribute domain that will be created. Attribute domains are rules that describe the accepted values of a field type. Specify a field type that matches the data type of the field to which the attribute domain will be assigned.
  • Short (16-bit integer)—The field type will be short. Short fields support whole numbers between -32,768 and 32,767.
  • Long (32-bit integer)—The field type will be long. Long fields support whole numbers between -2,147,483,648 and 2,147,483,647.
  • Big integer (64-bit integer)—The field type will be big integer. Big integer fields support whole numbers between -(253) and 253.
  • Float (32-bit floating point)—The field type will be float. Float fields support fractional numbers between -3.4E38 and 1.2E38.
  • Double (64-bit floating point)—The field type will be double. Double fields support fractional numbers between -2.2E308 and 1.8E308.
  • Text—The field type will be text. Text fields support a string of characters.
  • Date—The field type will be date. Date fields support date and time values.
  • Date only—The field type will be date only. Date only fields support date values with no time values.
  • Time only—The field type will be time only. Time only fields support time values with no date values.
String
Domain Type
(Optional)
Specifies the domain type that will be created.
  • Coded value domain—A coded type domain will be created that contains a valid set of values for an attribute. This is the default. For example, a coded value domain can specify valid pipe material values such as CL—cast iron pipe, DL—ductile iron pipe, or ACP—asbestos concrete pipe.
  • Range domain—A range type domain will be created that contains a valid range of values for a numeric attribute. For example, if distribution water mains have a pressure between 50 and 75 psi, a range domain specifies these minimum and maximum values.
String
Split Policy
(Optional)
Specifies the split policy that will be used for the created domain. The behavior of an attribute's values when a feature that is split is controlled by its split policy.
  • Use the attribute's default value—The attributes of the two resulting features will use the default value of the attribute of the given feature class or subtype.
  • Duplicate attribute values—The attribute of the two resulting features will use a copy of the original object's attribute value.
  • Use geometric ratio—The attributes of resulting features will be a ratio of the original feature's value. The ratio is based on the proportion into which the original geometry is divided. If the geometry is divided equally, each new feature's attribute gets one-half the value of the original object's attribute. The geometry ratio policy only applies to range domains.
String
Merge Policy
(Optional)
Specifies the merge policy that will be used for the created domain. When two features are merged into a single feature, merge policies control attribute values in the new feature.
  • Use the attribute's default value—The attribute of the resulting feature will use the default value of the attribute of the given feature class or subtype. This is the only merge policy that applies to nonnumeric fields and coded value domains.
  • Sum of the values—The attribute of the resulting feature will use the sum of the values from the original feature's attribute. The sum values policy only applies to range domains.
  • Area weighted average—The attribute of the resulting feature will be the weighted average of the attribute values of the original features. This average is based on the original feature's geometry. The area weighted policy only applies to range domains.
String
Derived output
Updated Input Workspace
The updated input workspace.
Workspace
Environments
Auto Commit, Current Workspace
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
