Assign Domain To Field (Data Management Tools)
Summary
Sets the domain for a particular field and, optionally, for a subtype. If no subtype is specified, the domain is only assigned to the specified field.
Usage
Domain management involves the following steps:
Create the domain using the Create Domain tool.
Add values to or set the range of values for the domain using the Add Coded Value to Domain tool or Set Value For Range Domain tool.
Associate the domain with a feature class using this tool.
One attribute domain can be associated with multiple fields in the same table, feature class, or subtype as well as in multiple tables and feature classes.
The Input Table parameter accepts feature layers or table views.
Parameters
| Label | Explanation | Data type |
Input Table |
The name of the table or feature class containing the field that will be assigned a domain. |
Table View |
Field Name |
The name of the field that will be assigned a domain. |
Field |
Domain Name |
The name of a geodatabase domain that will be assigned to the field name. Available domains will be loaded automatically. |
String |
Subtype (Optional) |
The subtype code that will be assigned a domain. |
String |
Derived output
Updated Input Table |
The updated input table. |
Table View |
Environments
Auto Commit, Current Workspace
Licensing information
- Basic: Yes
- Standard: Yes
- Advanced: Yes
