Set Value For Range Domain (Data Management Tools)
Summary
Sets the minimum and maximum values for an existing Range domain.
Usage
A range domain specifies a valid range of values for a numeric attribute. For example, a valid range of water main pressure values might be between 50 and 75 psi.
Domain management involves the following steps:
Create the domain using the Create Domain tool.
Add values to or set the range of values for the domain using the Add Coded Value To Domain tool or this tool.
Associate the domain with a feature class using the Assign Domain To Field tool.
You can also manage domains in Domains view which can be opened by clicking the Domains button found in the Design group on the Data ribbon.
Parameters
| Label | Explanation | Data type |
Input Workspace |
The geodatabase containing the domain to be updated. |
Workspace |
Domain Name |
The name of the range domain to be updated. |
String |
Minimum Value |
The minimum value of the range domain. |
String |
Maximum Value |
The maximum value of the range domain. |
String |
Derived output
Updated Workspace |
The updated workspace. |
Workspace |
Environments
Auto Commit, Current Workspace
Licensing information
- Basic: Yes
- Standard: Yes
- Advanced: Yes
