Sort Coded Value Domain (Data Management Tools)
Summary
Sorts the code or description of a coded value domain in either ascending or descending order.
Parameters
Label Explanation Data type
Input Workspace
The geodatabase containing the domain to be sorted.
Workspace
Domain Name
The name of the coded value domain to be sorted.
String
Sort By
Specifies whether the code or description will be used to sort the domain.
  • Code—Records are sorted based on the code value for the domain.
  • Description—Records are sorted based on the description value for the domain.
String
Sort Order
Specifies the direction the records will be sorted.
  • Ascending—Records are sorted from low value to high value.
  • Descending—Records are sorted from high value to low value.
String
Derived output
Updated Input Workspace
The updated input workspace.
Workspace
Environments
Current Workspace
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
