An overview of the Contingent Values toolset
The Contingent Values toolset contains tools for managing geodatabase contingent values and field groups. Contingent values functionality provides a way to add custom behavior to geodatabase data. You can incorporate contingent values into your workflows and automate the process of adding and removing values using these tools.
Learn more about contingent values
Learn more about creating and managing contingent values
Tool
Add Contingent Value
Adds a contingent value to a field group on a feature class or table.
Alter Field Group
Alters the properties of a field group.
Create Field Group
Create a field group for a feature class or table. Field groups are used when creating contingent values.
Delete Field Group
Deletes a field group from a table or feature class.
Export Contingent Values
Exports field groups and contingent values to a .csv file.
Generate Contingent Values
Generates contingent values from an existing dataset using either the data values in the table or the domain values assigned to the fields. The tool creates two .csv files: one for field groups and one for contingent values.
Import Contingent Values
Imports multiple contingent values and field groups from a comma-separated values file (.csv) to a dataset.
Remove Contingent Value
Removes a contingent value from a field group.
