Delete Field Group (Data Management Tools)
Summary
Deletes a field group from a table or feature class.
Usage
If your dataset is stored in an enterprise geodatabase, you must be connected as the data owner to run this tool.
Caution:
Deleting a field group also deletes the associated contingent attribute values.
To modify field group properties without deleting the associated contingent attribute values, use the Alter Field Group tool.
Parameters
| Label | Explanation | Data type |
Target Table |
The input geodatabase feature class or table that will have the field group deleted. |
Table View |
Field Group Name |
The name of the field group that will be deleted. |
String |
Derived output
Updated Table |
The updated input table with the field group deleted. |
Table View |
Environments
Licensing information
- Basic: Yes
- Standard: Yes
- Advanced: Yes
