Remove Contingent Value (Data Management Tools)
Summary
Removes a contingent value from a field group.
Usage
- If your data is stored in an enterprise geodatabase, you must be connected as the data owner to use this tool.
Parameters
| Label | Explanation | Data type |
Target Table |
The input geodatabase feature class or table containing the contingent value that will be removed. |
Table View |
Contingent Value ID |
The unique contingent value ID. To view the contingent value ID in the Contingent Values view, click the Toggle Value IDs button on the ribbon. In Python, this value can be accessed using the |
String |
Derived output
Updated Feature Class |
The updated input with the contingent value removed. |
Table View; Raster Layer; Mosaic Layer |
Environments
Licensing information
- Basic: Yes
- Standard: Yes
- Advanced: Yes
