Export Contingent Values (Data Management Tools)
Summary
Exports field groups and contingent values to a .csv file.
Usage
  • This tool can be used in conjunction with the Import Contingent Values tool.
  • The field groups .csv file includes the NAME, IS_RESTRICTIVE, and FIELD columns. The FIELD column name will be incremented as needed to include all fields in the field group, for example, FIELD1, FIELD2, FIELD3, and so on.
    Field groups .csv columns
    Column
    Example
    NAME
    The field group name
    AnimalCategories
    IS_RESTRICTIVE
    Specifies whether the field group is restrictive
    TRUE
    FIELD1
    The name of the field
    category
  • The contingent values .csv file includes the following columns: CAV_ID, IS_RETIRED, FIELD_GROUP, SUBTYPE, SUBTYPE_NAME, CV_TYPE, CV_VALUE, and DESCRIPTION.
    Contingent values .csv columns
    Column
    Example
    CAV_ID
    The ID of the contingent value.
    IS_RETIRED
    A Boolean value defining whether the contingent value is retired.
    False
    FIELD_GROUP
    The name of the field group to which the contingent value corresponds.
    AnimalCategories
    SUBTYPE
    If the dataset has a subtype and the subtype is used in the contingent value definition, this is the subtype code to which the rule is applied.
    SUBTYPE_NAME
    If the dataset has a subtype and the subtype is used in the contingent value definition, this is the text description of the subtype code.
    Cold blooded
    CV_TYPE1
    The type of contingent value. The type value is stored as an integer as follows:
    • 1—Any
    • 2—Null
    • 3—Coded Value
    • 4—Range
    CV_VALUE1
    The specific field value. If the type is any or null, the value in the .csv file is empty.
    DESCRIPTION1
    If the contingent value type is a coded value, this is the text description of the coded value.
    Fish
Parameters
Label Explanation Data type
Target Table
The input geodatabase table or feature class from which the field groups and contingent values will be exported.
Table View
Field Groups Output File (.csv)
The location and name of the output .csv file that will be created with specific column names containing information about the field groups of the target table.
File
Contingent Values Output File (.csv)
The location and name of the output .csv file that will be created with specific column names containing information about the contingent values of the target table.
File
Environments
Current Workspace
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
