An overview of the Fields toolset
The Fields toolset contains tools for creating, modifying, and deleting fields. A field is a column in a table; each field contains the values for a single attribute. Any number of fields can be included in a table. Field settings can be specified, such as the field type and the maximum size of the data that can be stored in it.
Tool |
Description |
Adds a new field to a table or the table of a feature class or feature layer, as well as to rasters with attribute tables. |
Adds new fields to a table, feature class, or raster. |
This tool allows you to rename fields or field aliases for a geodatabase table or feature class. |
Alters the field properties of multiple fields in a feature class or table. |
Changes the spatial index preference setting of the specified geometry field in a feature class in an SAP HANA database. |
Creates a default value for a specified field. When a new row is added to the table or feature class, the specified field will be set to this default value. |
Transforms fields in a table or feature class based on schema defined in the definition table and creates a new table or feature class. |
Calculates the values of a field for a feature class, feature layer, or raster. |
Calculates the values of two or more fields for a feature class, feature layer, or raster. |
Deletes one or more fields from a table, feature class, feature layer, or raster dataset. |
Migrates text fields in an Oracle table from Unicode to non-Unicode types. |
The Fields toolset also includes additional toolsets for working with fields.
Toolset |
Description |
The COGO toolset contains tools for enabling and disabling COGO on a line feature class. |
The Data Engineering toolset contains tools for preparing fields for analysis workflows, such as transforming, standardizing, encoding, and reclassifying values. These tools are designed to ensure that datasets are clean, consistent, and ready for modeling or analysis workflows. |
The Database toolset contains tools for adding global ID and incrementing ID fields, and for managing editor tracking. |
The Date and Time toolset contains tools for temporal field manipulation. |
The GPS toolset contains a tool for adding GNSS fields to a feature class. |
