Delete Field (Data Management Tools)
Summary
Deletes one or more fields from a table, feature class, feature layer, or raster dataset.
Usage
Caution:
This tool modifies the input data. See Tools that modify or update the input data for more information and strategies to avoid undesired data changes.
  • You can specify either the fields to delete or the fields to keep.
    • To delete fields, use the Fields parameter to specify the fields to delete, and set the Method parameter to the Delete Fields option.
    • To keep fields, use the Fields parameter to specify the fields to keep, and set the Method parameter to the Keep Fields option.
  • Fields cannot be deleted from nonnative, read-only data formats in ArcGIS, such as VPF and CAD datasets.
Parameters
Label Explanation Data type
Input Table
The table containing the fields to be deleted. The existing input table will be modified.
Mosaic Layer; Raster Layer; Table View
Fields
The fields to be deleted or kept from the input table, as specified by the Method parameter. Only nonrequired fields can be deleted.
Field
Method
(Optional)
Specifies whether the fields specified by the Fields parameter will be deleted or kept.
  • Delete Fields—The fields specified by the Fields parameter will be deleted. This is the default.
  • Keep Fields—The fields specified by the Fields parameter will be kept; all other fields will be deleted.
String
Derived output
Update Input Table
The updated dataset.
Table View; Raster Layer; Mosaic Layer
Environments
Current Workspace
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
