An overview of the General toolset
The General toolset contains tools for performing general data management operations. The toolset contains tools for combining feature classes or tables; renaming, copying, or deleting datasets; finding or deleting duplicate or identical records; sorting records; and uploading files to a portal.
Tool
Append
Appends to, and optionally updates, an existing target dataset with multiple input datasets. Input datasets can be feature classes, tables, shapefiles, rasters, or annotation or dimension feature classes. The inputs can also be hosted feature services.
Copy
Copies the input data to an output workspace of the same data type as the input workspace.
Create AI Service Connection File
Creates a connection file for hosted AI services.
Create Database View
Creates a view in a database based on an SQL expression.
Delete
Permanently deletes data. All types of geographic data supported by ArcGIS, as well as toolboxes and workspaces (folders and geodatabases), can be deleted. If the specified item is a workspace, all contained items will also be deleted.
Delete Identical
Deletes records from a feature class or table that have identical values in a set of fields. If the geometry field is selected, feature geometries are compared.
Delete Multiple
Permanently deletes multiple data items of the same or different data types. All types of geographic data supported by ArcGIS, as well as toolboxes and workspaces (folders and geodatabases), can be deleted. If a specified item is a workspace, all items contained in it will also be deleted.
Disable Last Edit Time
Disables the last edit time property on an enterprise geodatabase dataset.
Enable Last Edit Time
Enables the last edit time property on an enterprise geodatabase dataset.
Extract Data From Geodatabase
Extracts a subset of data from one geodatabase to another geodatabase or an .xml file.
Find Identical
Reports any records in a feature class or table that have identical values in a list of fields, and generates a table listing the identical records. If the Shape field is specified, feature geometries will be compared.
Merge
Combines multiple input datasets into a single, new output dataset. This tool can combine point, line, or polygon feature classes or tables.
Rename
Changes the name of a dataset. This includes a variety of data types, including feature dataset, raster, table, and shapefile.
Sort
Reorders records in a feature class or table, in ascending or descending order, based on one or multiple fields. The reordered result is written to a new dataset.
Transfer Files
Transfers files between a file system and a cloud storage workspace.
Upload File To Portal
Uploads a file to the active portal.
Tools in the General toolset
