Disable Last Edit Time (Data Management Tools)
Summary
Disables the last edit time property on an enterprise geodatabase dataset.
Disabling the last edit time property on a dataset will stop the recording of timestamps of when the data was last edited.
Usage
Enabling the last edit time functionality on an enterprise geodatabase dataset may stop the dataset from being opened in older clients. Run this tool to disable the last edit time property to open the dataset in these clients.
The input dataset must have the last edit time enabled and be nonversioned.
This tool must be run as the data owner.
Parameters
| Label | Explanation | Data type |
Input Dataset |
The enterprise geodatabase table, feature class, feature dataset, attributed relationship class, or many-to-many relationship class that will have the last edit time property disabled. |
Table View; Feature Dataset |
Derived output
Updated Dataset |
The updated input dataset with the last edit time disabled. |
Environments
This tool does not use any geoprocessing environments.
Licensing information
- Basic: No
- Standard: Yes
- Advanced: Yes
