Delete Multiple (Data Management Tools)
Summary
Permanently deletes multiple data items of the same or different data types. All types of geographic data supported by ArcGIS, as well as toolboxes and workspaces (folders and geodatabases), can be deleted. If a specified item is a workspace, all items contained in it will also be deleted.
Usage
  • To delete data items of the same name in the same workspace but with different data types, you must also specify their data type. The tool provides all appropriate options in the Input Data Element parameter's Data Type choice list.
  • Feature classes and tables participating in a network analysis dataset or a topology cannot be deleted.
  • Deleting a relationship class deletes the row corresponding to that relationship from the relationship table.
  • Deleting a mosaic dataset will only delete the mosaic dataset. To delete a mosaic dataset in its entirety—including any tables in the database and, optionally, any overviews or caches created with it—use the Delete Mosaic Dataset tool
  • This tool does not delete hosted feature services.
  • Data currently in use in another ArcGIS application cannot be deleted.
  • This tool can be used to delete data in the memory workspace. The memory workspace cannot be deleted.
  • Deleting a layer removes only the layer; its source data is not deleted.
  • Deleting a database connection file removes the shortcut to the database, it does not delete the enterprise database.
  • Deleting a shapefile also deletes ancillary files such as the metadata, projection, and index files.
  • Deleting a folder moves the folder to the system recycle bin, where it can be restored or permanently deleted.
Parameters
Label Explanation Data type
Input Data Element
The input data that will be deleted.
The data type is necessary in the event of a name conflict between data types. For example, a geodatabase can contain a feature class with an identical name to a relationship class. In this case, specify the relevant keyword.
  • FeatureClass—In the event of duplicate names, the feature class will be used.
  • FeatureDataset—In the event of duplicate names, the feature dataset will be used.
  • MosaicDataset—In the event of duplicate names, the mosaic dataset will be used.
  • ParcelFabric—In the event of duplicate names, the parcel fabric will be used.
  • RelationshipClass—In the event of duplicate names, the relationship class will be used.
  • Topology—In the event of duplicate names, the topology will be used.
Value table columns:
  • Input Data Element—The input data.
  • Data Type—The data type of the data.
Value Table
Derived output
Delete succeeded
Specifies whether the delete operation was successful.
Boolean
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
