Transfer Files (Data Management Tools)
Summary
Transfers files between a file system and a cloud storage workspace.
Usage
  • This tool supports hosted image products in the cloud.
  • The tool does not support file transfers to or from geodatabases.
  • When the tool is run in a server context, such as a published geoprocessing service, it can accept the data store's relative path, for example, /cloudStores/s3cloudstore/datafolder.
Parameters
Label Explanation Data type
Input Paths
The list of input files or folders that will be copied to the output folder. The path can be a file system path or cloud storage path where the .acs file can be used.
Raster Dataset; File; Folder
Output Folder
The output folder path where the files will be copied.
Folder
Filters
(Optional)
A file pattern filter that will limit the number of files that need to be copied, such as .tif, .crf, and similar image file types.
String
Derived output
Output Folder
The output raster dataset.
Folder
Environments
Parallel Processing Factor
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
