Find Identical (Data Management Tools)
Summary
Reports any records in a feature class or table that have identical values in a list of fields, and generates a table listing the identical records. If the Shape field is specified, feature geometries will be compared.
The Delete Identical tool can be used to find and delete identical records.
Illustration
Find Identical tool illustration
Points with the OBJECTIDs of 1, 2, 3, 8, 9, and 10 are spatially coincident (blue highlight). The output table identifies those spatially coincident points that share the same CATEGORY.
Usage
  • Records are identical if values in the selected input fields are the same for those records. The values from multiple fields in the input dataset can be compared. If more than one field is specified, records are matched by the values in the first field, then by the values of the second field, and so on.
  • With feature class or feature layer input, specify the Shape field in the Field(s) parameter to compare feature geometries to find identical features by location. The XY Tolerance and Z Tolerance parameters are only valid when the Shape field is specified.
    If the Shape field is specified and the input features have m- or z-values enabled, the m- or z-values will also be used to determine identical features.
  • Check the Output only duplicated records parameter if you want only the duplicated records in the output table. If this parameter is unchecked, the output will have the same number of records as the input dataset.
  • The output table will contain the following fields:
    • IN_FID—The Object ID field value from the input dataset. This field can be used to join the records of the output table back to the input dataset.
    • FEAT_SEQ—The sequence number. Records from the input that have the same values will have the same FEAT_SEQ value while nonidentical records will have a unique sequential value. The FEAT_SEQ values have no relationship to IDs of input records.
Parameters
Label Explanation Data type
Input Dataset
The table or feature class for which identical records will be found.
Table View
Output Dataset
The output table reporting identical records. The FEAT_SEQ field in the output table will have the same value for identical records.
Table
Field(s)
The field or fields whose values will be compared to find identical records.
Field
XY Tolerance
(Optional)
The x,y tolerance that will be applied to each vertex when evaluating whether there is an identical vertex in another feature.
This parameter is active when the Field(s) parameter value includes the Shape field.
Linear Unit
Z Tolerance
(Optional)
The z-tolerance that will be applied to each vertex when evaluating whether there is an identical vertex in another feature.
Double
(Optional)
Specifies whether only duplicated records will be included in the output table.
  • Checked—Only duplicate records will have corresponding records in the output table. The output will be empty if no duplicate is found.
  • Unchecked—All input records will have corresponding records in the output table. This is the default.
Boolean
Environments
Current Workspace, Scratch Workspace, Extent, XY Tolerance, Z Tolerance
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
