Data Management toolbox history
The tables below catalog changes made to every tool in the toolbox. There is one table per tool and you can click the tool name to go to the tool reference page.
For more information about how to interpret and use these tables, see Toolbox history topics.
Add 3D Formats To Multipatch
Version
2.7
New at this version
Add Attachments
Version
3.3
License changed from Standard to Basic
1.0
Ported from ArcMap 10.3
Add Attribute Index
Version
1.0
Add Attribute Rule
Version
3.4
New parameter added: triggering_fields
2.4
Parameter error_number has new data type: String
Parameter error_number had data type removed: Long
2.3
3 new parameters added:
  • severity
  • tags
  • batch
Parameter type had new option added: VALIDATION
2.1
New at this version
Add Coded Value To Domain
Version
1.0
Add Colormap
Version
1.0
Add Contingent Value
Version
2.5
2.3
New at this version
Add Data To Trajectory Dataset
Version
3.1
New at this version
Add Feature Class To Topology
Version
1.3
New at this version
Add Field
Version
3.3
Parameter field_type had new option added: DATEHIGHPRECISION
3.2
Parameter field_type has 4 new options:
  • BIGINTEGER
  • TIMESTAMPOFFSET
  • TIMEONLY
  • DATEONLY
1.0
Add Fields (multiple)
Version
3.0
New parameter added: template
Parameter field_description changed from Required to Optional
2.0
New at this version
Add Field Conflict Filter
Version
1.0
Add Full-Text Index
Version
3.5
New at this version
Add Files To LAS Dataset
Version
1.0
Add Full-Text Index
Version
3.7
New parameter added: sync_on_commit
Add Geometry Attributes
Version
3.0
Deprecated
This is a deprecated tool. This functionality has been replaced by the Calculate Geometry Attributes tool.
1.0
Add Global IDs
Version
1.0
Add GPS Metadata Fields
Version
3.5
New parameter added: include_offset_fields
2.2
New at this version
Add Incrementing ID Field
Version
1.2
New at this version
Add Items To Catalog Dataset
Version
3.3
Parameter input_item_types had new option added: TIN
Parameter input_item has new data type: TIN Layer
3.1
New at this version
Add Join
Version
3.3
New parameter added: join_operation
3.2
New parameter added: rebuild_index
2.9
New parameter added: index_join_fields
1.0
Add Portal Items To Catalog Dataset
Version
3.7
Parameter input_portal_itemtypes has new option added: TILED_IMAGERY_SERVICE
3.1
New at this version
Add Rasters To Mosaic Dataset
Version
3.4
Parameter aux_inputs has 2 new options:
  • RadiometricQuantityType
  • PanelReflectanceFactor
2.7
Parameter input_path has new data type: WMTS Layer
2.3
2 new parameters added:
  • enable_pixel_cache
  • cache_location
Parameter order changed at parameter 21:
  • Old parameter: out_mosaic_dataset
  • New parameter: enable_pixel_cache
1.4
Environments added:
  • Remote Processing Server
  • Remote Processing User Name
  • Remote Processing Password
1.2
  • aux_inputs
  • estimate_statistics
Parameter input_path has new data type Raster Catalog
1.0
Add Relate
Version
1.0
New at this version
Add Rule To Relationship Class
Version
2.3
New at this version
Add Rule To Topology
Version
1.3
New at this version
Add Spatial Index
Version
1.0
Add Spatial Join
Version
3.2
  • permanent_join
  • match_fields
3.0
New at this version
Add Subtype
Version
1.0
Add XY Coordinates
Version
1.0
Adjust 3D Z
Version
1.0
Alter Attribute Rule
Version
3.5
New parameter added: subtype
3.4
2.6
New parameter added: exclude_from_client_evaluation
2.4
  • triggering_events
  • script_expression
Parameter tags had new option added: RESET
2.3
New at this version
Alter Domain
Version
3.0
New parameter added: new_domain_owner
1.4
Parameter split_policy has 3 new options:
  • GEOMETRY_RATIO
  • DEFAULT
  • DUPLICATE
Parameter merge_policy has 3 new options:
  • DEFAULT
  • AREA_WEIGHTED
  • SUM_VALUES
1.0
New at this version
Alter Field
Version
3.2
  • BIGINTEGER
  • TIMESTAMPOFFSET
  • TIMEONLY
  • DATEONLY
2.2
Parameter clear_field_alias has 2 new options:
  • DO_NOT_CLEAR
  • CLEAR_ALIAS
1.1
License changed from Advanced to Basic
1.0
Alter Field Group
Version
2.5
New parameter added: is_restrictive
2.3
New at this version
Alter Fields (multiple)
Version
3.4
New at this version
Alter Geometry Index Preference
Version
3.7
New at this version
Version
3.7
Parameter raster_type_names has 4 has new options:
  • Cartosat
  • PAZ
  • Dragonette
  • NISAR
3.6
Parameter raster_type_names has 3 new options:
  • EnMAP
  • Tanager
  • PACE OCI
3.5
  • Hyperion
  • THEOS-2
  • WorldView Legion
3.4
Parameter raster_type_names has 2 new options:
  • Satellogic
  • AVIRIS
3.3
  • EMIT
  • Vision-1
3.2
  • Match-AT
  • SOCET SET
  • Capella
3.1
Parameter raster_type_names has 4 new options:
  • RCM
  • ICEYE
  • BlackSky
3.0
  • Pleiades Neo
  • SuperView-1
  • Landsat 9
2.9
Parameter raster_type_names had new option added: MAXAR
2.8
Parameter raster_type_names had new option added: PlanetScope
2.5
Parameter raster_type_names had new option added: Sentinel-3
2.4
  • RedEdge
  • Altum
2.2
  • SkySat
  • TeLEOS-1
2.1
  • ASTER
  • Sentinel-1
  • WorldView-4
1.4
Parameter raster_type_names has 8 new options:
  • ADS
  • GF-4 PMI
  • Scanned Aerial Imagery
  • KOMPSAT-3
  • Jilin-1
  • DubaiSat-2
  • DEIMOS-2
  • UAV/UAS
1.2
Parameter raster_type_names has 11 new options:
  • HJ 1A/1B CCD
  • GF-2 PMS
  • SPOT 7
  • ZY1-02C PMS
  • TH-01
  • Sentinel-2
  • GF-1 WFV
  • GF-1 PMS
  • ZY1-02C HRC
  • ZY3-SASMAC
  • ZY3-CRESDA
1.1
  • WorldView-3
  • NCDRD
1.0
Alter Subtype
Version
3.7
New at this version
Version
2.6
New parameter added: target_owner
2.3
Default value for parameter access changed from PRIVATE to (blank)
1.0
Version
1.1
Parameter components has 5 new options:
  • RASTER
  • BUSINESS
  • DELETES
  • ADDS
  • FEATURE
1.0
Version
1.4
New parameter added: maximum_level
1.2
Parameter out_overlap_table changed from Required to Optional
1.0
Version
1.0
Version
2.0
Environments added:
1.0
Version
3.7
Parameter version has new option added: 3.6
3.6
Parameter version had new option added: 3.5
3.5
Parameter version had new option added: 3.4
3.4
Parameter version has new option added: 3.3
3.3
Parameter version has 2 new options:
  • 3.1
  • 3.2
3.1
Parameter version had new option added: 3.0
3.0
New at this version
Version
3.6
This tool now uses the fissix module to review Python code. The fissix module is a modernized backport of the deprecated Python lib2to3 library.
2.7
Parameter input has new data type: Toolbox
1.0
Version
3.7
2 parameters added:
  • candidate_fields
  • skip_options
3.5
New parameter added: feature_service_mode
The display order of the Target Dataset parameter has changed from the third position to the first position.
3.4
New parameter added: enforce_domains
3.3
  • appended_row_count
  • updated_row_count
3.1
  • update_geometry
  • match_fields
2.9
Parameter schema_type had new option added: TEST_AND_SKIP
2.2
New parameter added: expression
1.3
Environment added: Maintain Attachments
1.0
Version
2.2
New at this version
Version
2.4
Default value for parameter append_option changed from GCP to ALL
2.3
  • area_of_interest
  • append_option
2.1
Parameter in_input_control_points has 2 new data types:
  • String
  • File
2.0
New parameter added: Geoid
1.4
  • in_z_accuracy
  • in_xy_accuracy
1.0
Version
3.2
New parameter added: adjust_tiepoints
2.3
  • out_control_point_table
  • solution_point_table
Parameter adjustment_operation had new option added: REACTIVATE
1.4
4 new parameters added:
  • zoffset
  • DEM
  • adjust_footprints
  • control_point_table
1.0
Version
2.2
Parameter in_layer has 2 new data types:
  • Feature Layer
  • Raster Layer
2.1
New parameter added: update_symbology
1.0
Version
2.2
Parameter clear_value has 2 new options:
  • DO_NOT_CLEAR
  • CLEAR_VALUE
1.0
Version
1.0
Version
2.3
Parameter in_workspace has new data type: Raster Layer
Parameter in_workspace had 2 data types removed:
  • Mosaic Dataset
  • Raster Dataset
Parameter out_workspace has new data type: Raster Layer
Parameter out_workspace had 2 data types removed:
  • Mosaic Dataset
  • Raster Dataset
1.0
Version
1.0
Version
2.6
Parameter Input_Feature_Class_or_Dataset has 2 new data types:
  • Feature Layer
  • Feature Dataset
Parameter Input_Feature_Class_or_Dataset had data type removed: Geodataset
1.0
Version
3.0
New at this version
Version
2.9
Parameter line_type had new option added: PLANAR
2.6
New parameter added: attributes
1.0
Version
1.0
Version
2.1
Parameter reset_footprint has 4 new options:
  • GEOMETRY
  • RADIOMETRY
  • NONE
  • COPY_TO_SIBLING
Parameter reset_footprint had 4 options removed:
  • Geometry
  • Radiometry
  • None
  • Copy to sibling
2.0
  • None
  • Radiometry
  • Copy to sibling
  • Geometry
  • COPY_TO_SIBLING
  • GEOMETRY
  • RADIOMETRY
  • NONE
1.4
Environments added:
1.0
Version
2.6
New at this version
Version
1.4
Environments added:
1.0
Build Multidimensional Info
Version
2.5
Deprecated
The tool has been moved to the Multidimensional toolbox.
2.4
New at this version
Build Multidimensional Transpose
Version
2.5
Deprecated
2.4
New at this version
Version
1.4
Environments added:
1.0
Version
1.0
Version
2.5
New parameter added: sips_mode
2.0
Environments added:
New parameter added: where_clause
1.0
Version
2.9
New parameter added: convert_colormap
2.6
The tool now builds raster attribute tables for multidimensional raster datasets and multidimensional mosaic datasets.
1.0
Version
1.4
Environments added:
  • max_sliver_size
  • min_thinness_ratio
  • min_region_size
Parameter computation_method has 2 new options:
  • VORONOI
  • DISPARITY
1.0
Version
3.0
Default value for parameter maximum_angle changed from 70.0 to 90.0
2.7
New parameter added: same_flight
2.2
New parameter added: group_by
Parameter order changed at parameter 7:
  • New parameter: group_by
1.4
New at this version
Version
1.0
Version
1.0
Version
3.3
3.2
Parameter expression_type had new option added: VB
  • BIGINTEGER
  • TIMESTAMPOFFSET
  • TIMEONLY
  • DATEONLY
2.8
2.5
New parameter added: field_type
2.1
Default value for parameter expression_type changed from PYTHON_9.3 to PYTHON3
Parameter expression_type has 3 new options:
  • PYTHON3
  • ARCADE
  • SQL
2.0
Environment added: Transfer Field Domain Descriptions
1.0
Version
3.2
2.8
2.1
New at this version
Version
3.1
Parameter area_unit has 5 new options:
  • SQUARE_MILES_INT
  • SQUARE_FEET_INT
  • SQUARE_NAUTICAL_MILES_US
  • ACRES_US
  • SQUARE_YARDS_US
Parameter length_unit has 4 new options:
  • NAUTICAL_MILES_INT
  • MILES_INT
  • YARDS_INT
  • FEET_INT
2.5
New parameter added: coordinate_format
2.2
New at this version
Version
3.6
New at this version
Version
2.6
The tool now calculates statistics for each variable in a multidimensional raster or multidimensional mosaic dataset.
1.0
Calculate Value
Version
1.3
This tool was deprecated from the Data Management toolbox. It remains accessible in ModelBuilder from the Insert > Utilities menu.
1.0
Version
1.0
Version
2.8
New parameter added: include_participating
Parameter in_features has 4 new data types:
  • Topology Layer
  • Parcel Layer
  • Utility Network Layer
  • Trace Network Layer
2.6
Parameter version_type had new option added: BRANCH
1.0
Version
3.1
New parameter added: problems_found
Parameter out_table changed from Required to Optional
2.9
Parameter in_features allows feature classes in an OGC GeoPackage as input.
2.7
Parameter in_features allows feature classes in databases and enterprise geodatabases as input.
2.0
New parameter added: validation_method
1.0
Version
2.9
New parameter added: out_mosaic_dataset
2.3
New at this version
Version
1.0
Version
3.6
Parameter rectangle has new data type: Extent
2.6
The tool now supports clipping a multidimensional raster.
2.3
The tool label changed from Clip to Clip Raster.
2.1
Parameter rectangle has two new data types:
  • Feature Layer
  • Feature Class
1.0
Version
3.3
9 new parameters added:
  • in_DEM_raster
  • ZFactor
  • ZOffset
  • Geoid
  • solution_points
  • target_objectid
  • refine_estimation
  • reduce_shadow
  • reduce_cloud
Parameter balancing_method had new option added: GLOBAL_FIT
2.1
Default value for parameter color_surface_type changed from SINGLE_COLOR to COLOR_GRID
1.4
Environments added:
  • Parallel Processing Factor
1.0
Version
3.1
New at this version
Version
3.6
New at this version
Version
1.0
Version
1.0
Version
1.1
License changed from Basic to Standard
1.0
Version
1.0
Version
3.3
Parameter adjustment_options has new option added: rigCamera
3.2
Parameter adjustment_options has 17 new options:
  • CalibrateF
  • CalibratePP
  • CalibrateP
  • CalibrateK
  • APrioriAccuracyX
  • APrioriAccuracyY
  • APrioriAccuracyZ
  • APrioriAccuracyXY
  • APrioriAccuracyXYZ
  • APrioriAccuracyOmega
  • APrioriAccuracyPhi
  • APrioriAccuracyOmegaPhi
  • APrioriAccuracyKappa
  • ComputeAntennaOffset
  • ComputeShift
  • ComputeImagePosteriorStd
  • ComputeSolutionPointPosteriorStd
3.1
  • DEM
  • elevation_accuracy
2.8
Parameter location_accuracy had new option added: VERY_HIGH
1.4
  • out_quality_table
  • location_accuracy
Parameter transformation_type has 2 new options:
  • Frame
  • RPC
1.0
Version
3.1
License changed from Advanced to Standard
2.6
Parameter gps_accuracy had new option added: VERY_HIGH
1.4
New at this version
Version
1.4
Environments added:
New parameter added: location_accuracy
1.2
  • density
  • distribution
  • area_of_interest
1.0
Version
3.2
New at this version
Version
1.0
Version
3.1
2.2
New at this version
Version
3.1
New parameter added: maximum_obliqueness_angle
1.4
New at this version
Version
1.0
Version
2.9
New parameter added: options
1.4
Environments added:
Default value for parameter density changed from LOW to MEDIUM
1.2
  • density
  • distribution
1.0
Version
2.9
No longer supports altering log file table settings for geodatabases (version 10.9.1.2.9 and later) in IBM Db2
2.4
No longer supports altering log file table settings for geodatabases (version 10.7.1.2.4 and later) in Oracle.
1.4
No longer supports altering log file table settings for geodatabases (version 10.5.0.1.4 and later) in Microsoft SQL Server.
1.3
No longer supports altering log file table settings for geodatabases (version 10.4.1.1.3 and later) in PostgreSQL.
1.2
New at this version
Version
3.1
  • exclude_network_dataset
  • preserve_sqlite
2.5
New parameter added: select_related_rows
1.0
Version
1.0
Version
3.4
New parameter added: consolidate_to_one_fgdb
2.5
1.4
New parameter added: preserve_sqlite
1.0
Version
3.7
Parameter version has new option added: 3.7
3.6
Parameter version had new option added: 3.6
3.5
3.4
3.3
Parameter version had new option added: 3.3
3.2
Parameter version had new option added: 3.2
3.1
Parameter version had new option added: 3.1
3.0
  • 3.0
  • 2.9
Parameter version had 2.1 option removed
2.9
Parameter version had new option added: 2.8
2.8
Parameter version had new option added: 2.7
2.6
  • 2.5
  • 2.6
2.5
2.3
New parameter added: version
2.1
1.0
New at this version
Version
3.7
3.6
3.5
3.4
3.3
3.2
3.1
3.0
  • 3.0
  • 2.9
2.9
2.8
2.6
  • 2.5
  • 2.6
2.3
New at this version
Version
2.9
Parameter output_coordinate_format has 3 new options:
  • MGRS16
  • GEOREF16
  • USNG16
Parameter input_coordinate_format has 3 new options:
  • MGRS16
  • GEOREF16
  • USNG16
1.4
New parameter added: exclude_invalid_records
1.0
Version
2.1
New at this version
Version
3.6
Parameter formats had new option added: DYNAMIC_HTML
3.3
New at this version
Version
3.2
Tool label changed from Convert Time Field to Convert Temporal Field.
New parameter added: timezone_or_field
Parameter output_time_type has 4 new options:
  • BIGINTEGER
  • TIMESTAMPOFFSET
  • TIMEONLY
  • DATEONLY
2.5
Parameter input_time_format changed from Required to Optional
1.0
Version
2.7
Parameter input_time_zone had new option added: Yukon_Standard_Time
Parameter output_time_zone had new option added: Yukon_Standard_Time
2.5
Parameter input_time_zone had new option added: Qyzylorda_Standard_Time
Parameter output_time_zone had new option added: Qyzylorda_Standard_Time
2.1
Parameter output_time_zone has 2 new options:
  • Sudan_Standard_Time
  • Sao_Tome_Standard_Time
Parameter input_time_zone has 2 new options:
1.0
Version
1.4
New parameter added: associated_data
1.3
1.0
Version
1.3
1.0
Version
3.5
Parameter format has 3 new options:
  • WEBP
  • AVIF
  • JPEGXL
2.9
Parameter format had new option added: Zarr
2.8
Parameter format had new option added: NetCDF
2.4
  • build_multidimensional_transpose
  • process_as_multidimensional
2.2
Parameter format had new option added: COG
2.0
Parameter format had new option added: CRF
Parameter format had CACHE option removed
Parameter in_raster has new data type: Image Service
1.4
Environments added:
Parameter in_raster has new data type: File
Parameter format had DTED option removed
1.2
  • format
  • transform
1.0
Version
1.3
1.0
Version
2.9
The tool label changed from Create 3D Object Scene Layer Package to Create 3D Object Scene Layer Content.
New parameter added: target_cloud_connection
Parameter out_slpk changed from Required to Optional
2.3
New at this version
Version
3.5
New at this version
Version
2.9
The tool label changed from Create Building Scene Layer Package to Create Building Scene Layer Content.
2.7
New parameter added: texture_optimization
2.3
New at this version
Version
3.1
New at this version
Version
3.5
Parameter service_provider had new option added: WEB
3.2
New parameter added: Authentication
3.0
Parameter service_provider had new option added: OZONE
2.8
Parameter service_provider had new option added: AZUREDATALAKE
2.7
Parameter service_provider had new option added: MINIO
2.5
Parameter service_provider had HUAWEI option removed
2.4
New parameter added: folder
2.3
Parameter service_provider had new option added: WEBHDFS
2.2
New at this version
Version
3.0
New at this version
Version
3.4
  • accuracy
  • extent
3.2
New parameter added: out_transformation
1.0
Version
3.2
New at this version
Version
3.2
New at this version
Version
3.5
New parameter added: host_url
Parameter auth_type had new option added: BASIC
Parameter database_platform has 2 new options:
  • ELASTICSEARCH
  • OPENSEARCH
3.3
Parameter auth_type had new option added: AZURE_ACTIVE_DIRECTORY_INTEGRATEDSERVICE_AUTHENTICATION
3.1
8 new parameters added:
  • role
  • refresh_token
  • project_id
  • default_dataset
  • key_file
  • warehouse
  • auth_type
  • advanced_options
Parameter database_platform has 3 new options:
  • REDSHIFT
  • SNOWFLAKE
  • BIGQUERY
Parameter instance changed from Required to Optional
2.8
Parameter database_platform had INFORMIX option removed
2.5
Parameter database_platform had 2 options removed:
  • NETEZZA
  • ALTIBASE
2.3
Parameter database_platform had new option added: INFORMIX
2.1
1.2
Parameter database_platform has 5 new options:
  • DAMENG
  • NETEZZA
  • SAP HANA
  • ALTIBASE
  • TERADATA
1.0
Version
2.8
2.5
  • NETEZZA
  • ALTIBASE
2.4
New at this version
Version
2.4
Parameter in_workspace allows file geodatabase as input.
2.1
New at this version
Version
2.1
Parameter input_database allows connections to SAP HANA.
1.0
Version
2.7
Parameter input_database accepts mobile geodatabases as input.
2.6
Parameter input_database accepts file geodatabases as input.
1.0
Version
3.2
Parameter field_type has 3 new options:
  • BIGINTEGER
  • TIMEONLY
  • DATEONLY
2.2
Parameter field_type changed from Required to Optional
1.0
Version
2.9
New parameter added: spatial_type
1.1
1.0
Version
3.2
New parameter added: oid_type
2.7
Parameter template has new data type: Table View
Parameter template had data type removed: Feature Layer
2.1
New parameter added: out_alias
1.0
Version
1.0
Version
2.5
2.3
New at this version
Version
1.0
Version
1.0
Version
1.0
Version
3.0
  • target_cloud_connection
  • out_name
2.9
The tool label changed from Create Integrated Mesh Scene Layer Package to Create Integrated Mesh Scene Layer Content.
Parameter texture_optimization has 2 new options:
  • All
  • Mobile
2.7
2.6
New parameter added: max_texture_size
2.5
New parameter added: out_coor_system
Parameter anchor_point has new data type: File
Default value for parameter file_suffix changed from * to osgb
Parameter file_suffix had new option added: osgb
Parameter file_suffix had OSGB option removed
2.3
2 parameters removed:
  • out_coor_system
  • transform_method
Parameter order changed at parameter 3:
  • Old parameter: out_coor_system
  • New parameter: anchor_point
2.2
New at this version
Version
3.0
  • boundary
  • extent
  • add_only_contained_files
2.4
Default value for parameter compute_stats changed from False to True
1.1
New parameter added: create_las_prj
1.0
Version
3.1
  • output_folder
  • create_multiple_packages
Parameter output_file changed from Required to Optional
3.0
New parameter added: area_of_interest
2.4
New parameter added: min_level_of_detail
Default value for parameter package_type changed from tpk to tpkx
2.3
New parameter added: package_type
2.2
New parameter added: compression_quality
1.3
New parameter added: extent
1.0
Version
2.7
New at this version
Version
2.6
New parameter added: reference_online_content
2.5
2.4
  • expiration_date
  • map_expiration_type
  • enable_map_expiration
  • expiration_message
2.3
  • anonymous_use
  • texture_optimization
2.1
New parameter added: anonymous_use
1.2
New at this version
Version
2.6
2.5
2.4
  • expiration_date
  • enable_scene_expiration
  • scene_expiration_type
2.3
New at this version
Version
3.7
Parameter product_definition has new option added: CARTOSAT
3.5
Parameter product_definition has 2 new options:
  • THEOS-2
  • WorldView Legion
3.3
Parameter product_definition had new option added: VISION-1_4BANDS
3.1
  • BLACKSKY
  • PLANETSCOPE
3.0
Parameter product_definition has 3 new options:
  • LANDSAT_9BANDS
  • SUPERVIEW-1_4BANDS
  • PLEIADES_NEO_6BANDS
2.9
Parameter product_definition had PlanetScope option removed
2.8
Parameter product_definition had new option added: PlanetScope
2.2
Parameter product_definition had new option added: SKYSAT_4BANDS
2.1
Parameter product_definition had new option added: WORLDVIEW-4_4BANDS
1.4
Parameter product_definition has 5 new options:
  • DEIMOS2_4BANDS
  • KOMPSAT-3_4BANDS
  • DUBAISAT-2_4BANDS
  • GF-4 PMI_4BANDS
  • JILIN-1_3BANDS
1.2
Parameter product_definition has 10 new options:
  • GF-2 PMS_4BANDS
  • ZY3-CRESDA_4BANDS
  • GF-1 WFV_4BANDS
  • ZY1-02C PMS_3BANDS
  • SPOT-7_4BANDS
  • SENTINEL2_13BANDS
  • HJ 1A/1B CCD_4BANDS
  • GF-1 PMS_4BANDS
  • TH-01_4BANDS
  • ZY3-SASMAC_4BANDS
1.1
Parameter product_definition had new option added: WORLDVIEW-3_8BANDS
1.0
Version
3.1
Parameter in_raster has 3 new data types:
  • Raster Dataset
  • Mosaic Dataset
  • Mosaic Layer
Parameter in_DEM_raster has 3 new data types:
  • Raster Dataset
  • Mosaic Dataset
  • Image Service
1.0
Version
3.7
Parameter sensor has new option added: Cartosat
3.5
Parameter sensor has 2 new options:
  • THEOS-2
  • WorldView Legion
3.3
Parameter sensor had new option added: Vision-1
3.1
Parameter sensor had new option added: BlackSky
3.0
Parameter sensor has 3 new options:
  • Pleiades Neo
  • SuperView-1
  • Landsat 9
2.2
Parameter sensor had new option added: SkySat
2.1
Parameter sensor had new option added: WorldView-4
1.4
  • KOMPSAT-3
  • Jilin-1
  • DubaiSat-2
1.2
Parameter sensor has 7 new options:
  • GF-2 PMS
  • SPOT 7
  • ZY1-02C PMS
  • TH-01
  • GF-1 PMS
  • ZY3-SASMAC
  • ZY3-CRESDA
1.1
Parameter sensor had new option added: WorldView-3
1.0
Version
3.6
New at this version
Version
3.0
  • out_name
Default value for parameter z_max_error_m changed from 0.01 to 0.001
Default value for parameter xy_max_error_m changed from 0.01 to 0.001
2.9
The tool label changed from Create Point Cloud Scene Layer Package to Create Point Cloud Scene Layer Content.
2.6
Default value for parameter scene_layer_version changed from 1.x to 2.x
2.3
New at this version
Version
3.4
New parameter added: support_symbol_referencing
2.9
The tool label changed from Create Point Scene Layer Package to Create Point Scene Layer Content.
2.3
New at this version
Version
1.0
Version
2.7
New parameter added: build_rat
1.0
Version
2.5
Default value for parameter pyramids changed from PYRAMIDS -1 NEAREST DEFAULT 75 NO_SKIP to PYRAMIDS -1 NEAREST DEFAULT 75 NO_SKIP NO_SIPS
1.0
Create Raster Type
Version
2.1
Deprecated
1.2
New at this version
Version
1.0
Version
3.3
1.0
Version
3.7
  • geometry_filter_type
  • extract_type
3.2
  • out_filegdb_folder_path
  • out_filegdb_name
Parameter out_type had new option added: NEW_FILE_GEODATABASE
3.1
New parameter added: all_records_for_tables
2.9
  • out_xml
  • out_type
Parameter out_geodatabase changed from Required to Optional
2.7
New parameter added: register_existing_data
Parameter archiving changed from Required to Optional
2.5
New at this version
Version
3.1
2.9
New at this version
Version
1.0
Create Scene Layer Package
Version
2.3
Deprecated
This is a deprecated tool. This functionality has been replaced by the Create 3D Object Scene Layer Package, Create Point Scene Layer Package, and Create Point Cloud Scene Layer Package tools.
2.2
New parameter added: scene_layer_version
2.1
New parameter added: in_coordinate_system
Parameter in_layer has 3 new data types:
  • Layer File
  • Folder
  • File
2.0
New parameter added: transform_method
1.4
7 new parameters added:
  • xy_max_error
  • point_size_meter_override
  • out_slpk
  • spatial_reference
  • z_max_error
  • attributes
  • in_layer
3 parameters removed:
  • out_file
  • attribute_fields
  • in_features
Parameter order changed at parameter 1:
  • Old parameter: in_features
  • New parameter: in_layer
1.3
New at this version
Version
3.3
New at this version
Version
1.2
New at this version
Version
3.3
New at this version
Version
3.3
Parameter spatial_type had new option added: GEOPACKAGE_1.4
2.7
Parameter spatial_type has new option added: GEOPACKAGE_1.3
2.0
Parameter spatial_type has 3 new options:
  • GEOPACKAGE_1.0
  • GEOPACKAGE_1.1
  • GEOPACKAGE_1.2
1.1
New at this version
Version
1.0
Version
3.2
2.6
1.0
Version
1.3
New at this version
Version
3.1
New at this version
Version
1.0
Version
1.0
Version
1.2
New at this version
Version
3.6
Parameter min_cached_scale changed from Required to Optional
Parameter max_cached_scale changed from Required to Optional
2.4
Parameter min_cached_scale changed from Optional to Required
Parameter max_cached_scale changed from Optional to Required
1.2
New at this version
Version
3.3
New parameter added: version_description
1.0
Version
2.9
New at this version
Version
1.0
Version
1.0
Version
1.0
Version
1.2
Parameter in_data has new data type Utility Network
Parameter in_data had data type Facility Network removed
1.0
Version
2.3
2.1
New at this version
Version
1.0
Version
1.0
Version
2.4
Parameter in_workspace accepts file geodatabase as input.
2.1
New at this version
Version
1.0
Version
1.0
Version
2.9
New parameter added: method
1.0
Version
2.5
2.3
New at this version
Version
3.5
New parameter added: out_mapping_table
3.1
1.0
Version
1.0
Version
3.4
New at this version
Version
1.0
Version
1.0
Version
1.2
New at this version
Version
1.0
Version
1.2
New parameter added: compare_line_direction
1.0
Version
1.2
New at this version
Version
1.2
New at this version
Version
1.0
Version
1.0
Version
3.3
1.0
Version
2.3
2.2
New at this version
Version
1.4
New at this version
Version
2.4
Parameter in_dataset has 2 new data types:
  • Network Dataset
  • Topology
1.0
Version
2.4
New at this version
Version
3.5
New at this version
Version
2.6
New at this version
Version
3.0
New parameter added: concatenation_separator
1.0
Version
1.0
Version
3.7
New parameter added: downgrade_level
3.3
2.7
New at this version
Version
1.0
Version
2.3
Parameter edit_options has 3 new options:
  • INSERT
  • REMOVE
  • REPLACE
1.3
1.0
Version
1.0
Version
1.0
Version
1.0
Version
3.3
1.0
Version
2.3
2.2
New at this version
Version
1.4
New at this version
Version
3.4
New at this version
Version
2.4
  • Network Dataset
  • Topology
1.0
Version
1.1
1.0
Version
2.4
New at this version
Version
3.5
New at this version
Version
2.7
New at this version
Version
2.4
New parameter added: run_async
Parameter removed: async
Parameter order changed at parameter 4:
  • Old parameter: async
  • New parameter: run_async
Parameter extent changed from Required to Optional
2.3
New at this version
Version
3.6
New parameter added: merge
3.2
New at this version
Version
2.9
New at this version
Version
3.3
New at this version
Version
2.1
New at this version
Version
2.5
2.4
New at this version
Version
2.9
New at this version
Version
2.7
New at this version
Version
1.2
New at this version
Version
3.7
New at this version
Version
1.0
Version
3.4
  • band_method
  • band_id_selection
  • band_name_selection
3.0
New parameter added: image_space
2.6
Parameter format had new option added: Cloud Optimized GeoTIFF
2.1
Parameter format has 2 new options:
  • MRF
  • CRF
1.4
Environments added:
1.0
Version
3.1
New parameter added: remove_distortion
1.0
Version
3.1
New at this version
Version
1.0
Version
3.5
New at this version
Version
3.5
New parameter added: selection_symbology
2.4
New at this version
Version
1.3
New at this version
Version
2.5
Default value for parameter storage_format_type changed from COMPACT to COMPACT_V2
Parameter storage_format_type had new option added: COMPACT_V2
2.4
Parameter export_cache_type had new option added: TILE_PACKAGE_TPKX
1.0
Version
3.3
1.0
Version
3.4
Parameter out_type had new option added: NEW_MOBILE_GEODATABASE
3.3
New at this version
Version
2.8
Parameter output_folder changed from Required to Optional
2.7
  • storage_format_type
  • create_ready_to_serve_format
2.1
New parameter added: cache_package
1.0
Version
1.0
Version
1.1
Parameter ignore_options had new option added: IGNORE_FIELDALIAS
1.0
Version
1.0
Version
2.7
1.0
Version
2.7
1.0
Version
3.7
New parameter added: polygon_construction_source
2.7
1.0
Version
1.0
Version
2.9
New at this version
Version
1.0
Version
3.1
1.0
Version
2.6
The tool now supports flipping a multidimensional raster.
1.0
Version
3.3
3.1
New parameter added: match_pattern
1.0
Version
3.2
Parameter report_format has 2 new options:
  • JSON
  • BRIEF JSON
2.4
New parameter added: report_format
Parameter removed: report_type
Parameter order changed at parameter 6:
  • Old parameter: report_type
  • New parameter: report_format
2.3
New at this version
Version
3.4
New at this version
Version
3.4
New at this version
Version
2.7
Parameter in_raster had data type removed: Composite Layer
1.0
Version
1.3
1.0
Version
3.5
New parameter added: intersect_class_field
3.4
New at this version
Version
3.4
New at this version
Version
1.3
1.0
Version
3.2
New at this version
Version
3.3
Environments added:
  • Extent
  • Geographic Transformations
  • Output Coordinate System
3.2
The out_folder parameter supports cloud storage.
3.1
2.3
Parameter matching_method had new option added: MVM
Parameter matching_method had 2 options removed:
  • MVLL
  • ESGM
2.2
Default value for parameter object_size changed from 50.0 to 10.0
Parameter matching_method had new option added: MVLL
Default value for parameter minimum_pairs changed from 2.0 to 4.0
1.4
New at this version
Version
3.4
  • Distance_Method
  • Distance_Field
Parameter Point_Placement had new option added: DISTANCE_FIELD
3.1
New parameter added: Add_Chainage_Fields
2.8
When the input is m- or z-enabled, the tool will now create m- or z-enabled output.
Environments added:
  • Output has M Values
  • Output has Z Values
1.2
New at this version
Version
2.2
New parameter added: out_base_name
2.1
New at this version
Version
2.6
2.4
New parameter added: process_as_multidimensional
2.0
1.4
Environments added:
1.3
New at this version
Version
2.1
New at this version
Version
3.6
3.2
New at this version
Version
3.4
New at this version
Version
3.4
New at this version
Version
2.2
New at this version
Version
3.1
New parameter added: H3_Resolution
Parameter Shape_Type had new option added: H3_HEXAGON
2.3
Parameter Shape_Type has 2 new options:
  • TRANSVERSE_HEXAGON
  • DIAMOND
1.2
New at this version
Version
1.2
New parameter added: lerc_error
Parameter tile_format had new option added: LERC
1.0
Version
2.2
New at this version
Version
3.5
New at this version
Version
3.3
The Add_Photos_As_Attachments parameter is now supported with a Basic license.
1.0
Version
1.0
Version
1.0
Version
1.0
Version
1.1
Parameter property_type had ACQUSITIONDATE option removed
Parameter property_type had new option added: ACQUISITIONDATE
1.0
Version
3.3
New parameter added: y_is_up
3.2
New at this version
Version
2.1
New at this version
Version
2.5
2.4
New at this version
Version
1.2
New at this version
Version
2.9
New at this version
Version
1.0
Version
3.1
New at this version
Version
1.4
Environments added:
New parameter added: overwrite
1.0
Version
3.3
1.0
Version
1.0
Version
3.4
3.2
Cloud storage supported for 2 parameters:
  • in_container
  • out_raster
3.1
1.4
New at this version
Version
3.2
3.0
  • field_mapping
  • fm_option
1.0
Version
1.0
Version
1.0
Version
3.2
New at this version
Version
3.2
New at this version
Version
2.8
New at this version
Version
3.0
Parameter in_feature_dataset has new data type: BIM File Workspace
2.5
New at this version
Version
1.0
Version
1.3
Environment added: Output Coordinate System
1.1
New parameter added: processing_template
1.0
Version
3.6
  • max_height
  • min_height
3.0
Parameter return_values has 4 new options:
  • LAST
  • LAST_OF_MANY
  • FIRST_OF_MANY
  • SINGLE
Parameter return_values had 4 options removed:
  • Last of Many
  • First of Many
  • Last Return
  • Single Return
2.4
Default value for parameter no_flag changed from False to True
Default value for parameter withheld changed from True to False
Default value for parameter keypoint changed from False to True
Default value for parameter synthetic changed from False to True
1.4
Parameter no_flag has 2 new options:
  • INCLUDE_UNFLAGGED
  • EXCLUDE_UNFLAGGED
Parameter keypoint has 2 new options:
  • INCLUDE_KEYPOINT
  • EXCLUDE_KEYPOINT
Parameter withheld has 2 new options:
  • EXCLUDE_WITHHELD
  • INCLUDE_WITHHELD
Parameter synthetic has 2 new options:
  • INCLUDE_SYNTHETIC
  • EXCLUDE_SYNTHETIC
Parameter overlap has 2 new options:
  • INCLUDE_OVERLAP
  • EXCLUDE_OVERLAP
1.0
Version
1.1
Parameter mosaic_operator had new option added: SUM
1.0
Version
2.5
Parameter in_dataset has new data type: Building Scene Layer
2.3
New at this version
Version
2.4
  • z_values
  • spatial_properties
  • m_values
  • extent
1.0
Version
1.0
Version
1.0
Version
1.0
Version
2.5
New at this version
Version
3.2
Parameter predefined_variables had 5 options removed:
  • H_OCEAN_LOWEST
  • H_OCEAN_HIGHEST
  • H_ICEBERG
  • H_IWS
  • H_OCEAN
3.1
New at this version
Version
1.0
Version
1.0
Version
2.5
Parameter bin_type has 4 new options:
  • POINTY_HEXAGON
  • GEOHASH
  • FLAT_HEXAGON
  • SQUARE
2.4
New at this version
Version
3.4
New parameter added: ready_to_serve_format
2.5
Parameter tiling_scheme had new option added: WGS84_V2_ELEVATION_SCHEME
2.2
Parameter tiling_scheme had new option added: WGS84_V2_SCHEME
1.4
Environments added:
1.2
Parameter tiling_scheme has 3 new options:
  • ARCGISONLINE_ELEVATION+_SCHEME
  • ARCGISONLINE_ELEVATION_SCHEME
  • ARCGISONLINE+_SCHEME
1.0
Version
2.3
New at this version
Version
2.5
New at this version
Version
3.3
1.3
Tool now honors the Maintain Attachments environment
1.0
Version
3.4
New parameter added: field_match_mode
2.4
New parameter added: add_source
1.3
1.0
Merge Branch
Version
1.3
This tool was deprecated from the Data Management toolbox. It remains accessible in ModelBuilder from the Insert > Logical menu.
1.0
Version
1.0
Version
3.2
New at this version
Version
3.3
1.0
Version
2.1
Tool no longer migrates ST_Raster data.
1.0
Version
3.5
New at this version
Version
2.8
The geometry_type parameter's CONVEX_HULL, CIRCLE and ENVELOPE options are now supported with a Standard or Basic license.
1.0
Version
3.2
New at this version
Version
2.6
The tool now supports mirroring a multidimensional raster.
1.0
Version
2.7
Parameter inputs had data type removed: Composite Layer
1.0
Version
1.3
New at this version
Version
2.7
Parameter input_rasters had data type removed: Composite Layer
1.0
Version
1.0
Version
3.3
New at this version
Version
3.1
  • preserve_sqlite
3.0
Parameter version had new option added: 3.x
Parameter in_layer has new data type: Table View
2.5
2.0
Parameter version had new option added: 2.x
Parameter version had 3 options removed:
  • 1.4
  • 1.3
  • 1.1
1.0
Version
2.5
1.0
Version
3.4
3.0
2.5
2.0
  • 1.4
  • 1.3
  • 1.1
1.0
Version
3.7
3.6
3.5
3.4
3.3
3.2
3.1
3.0
  • 3.0
  • 2.9
2.9
2.8
2.6
  • 2.5
  • 2.6
2.5
Parameter version had new option added: 2.4
2.3
Parameter version has 3 new options:
  • 2.2
  • 2.1
  • 2.3
Parameter version had 2 options removed:
  • 1.2
  • 2.x
2.1
  • read_only
  • include_toolboxes
  • include_history_items
2.0
  • 1.4
  • 1.3
  • 1.1
1.2
1.0
New at this version
Version
3.7
3.6
3.5
3.4
3.3
3.2
3.1
3.0
  • 3.0
  • 2.9
2.9
2.8
2.6
  • 2.5
  • 2.6
2.5
2.3
1.1
Ported from ArcMap 10.3.1
Version
1.0
Version
3.2
The tool was rewritten to improve performance.
3.1
  • Transfer_Fields
  • Line_Construction_Method
  • Attribute_Source
1.0
Version
1.0
Version
3.2
The tool now supports writing output to the memory workspace
OGC Geopackage data is supported as input data.
2.7
Parameter out_dataset has new data type: File
Parameter in_dataset has 3 new data types:
  • File
  • Scene Layer
  • Building Scene Layer
1.4
New parameter added: vertical
1.0
Version
3.5
New at this version
Version
2.6
The tool now supports projecting a multidimensional raster.
2.2
1.0
Version
3.5
New at this version
Version
3.6
New parameter added: out_compare_raster
1.0
Version
1.0
Version
2.9
New at this version
Version
1.0
Version
3.2
Parameter store_extent has 2 new options:
  • STORE_EXTENT
  • DO_NOT_STORE_EXTENT
3.0
New parameter added: store_extent
1.2
New at this version
Version
2.7
New at this version
Version
2.6
New parameter added: reconcile_checkout_versions
Parameter conflict_resolution has 2 new options:
  • FAVOR_EDIT_VERSION
  • FAVOR_TARGET_VERSION
Parameter conflict_definition has 2 new options:
  • BY_ATTRIBUTE
  • BY_OBJECT
2.2
New parameter added: proceed_if_conflicts_not_reviewed
1.0
Version
1.0
Version
2.9
New at this version
Version
1.0
Version
2.3
Parameter input_link_file has new data type: Feature Class
Parameter transformation_type had new option added: FRAME
1.2
Parameter transformation_type had new option added: POLYSIMILARITY
Parameter register_mode had new option added: REGISTER_MS
1.0
Version
3.1
Parameter in_geometry_type had new option added: MULTIPATCH
1.4
5 new parameters added:
  • in_object_id_field
  • in_geometry_type
  • in_shape_field
  • in_spatial_reference
  • in_extent
Parameter in_dataset allows views as input.
1.0
Version
2.7
New at this version
Version
3.3
1.0
Version
1.0
Version
2.5
2.3
New at this version
Version
3.2
New at this version
Version
1.0
Version
2.6
Parameter out_topology has new data type: Topology Layer
Parameter out_topology had data type removed: Topology
Parameter in_topology has new data type: Topology Layer
Parameter in_topology had data type removed: Topology
1.3
New at this version
Version
1.0
Version
2.7
New parameter added: delete_pyramid
1.0
Version
1.0
Version
1.0
Version
1.0
New at this version
Version
2.3
New at this version
Version
1.3
New at this version
Version
1.0
Version
1.0
Version
1.0
Version
2.3
New at this version
Version
2.9
2.7
2.0
1.0
Version
1.0
Version
3.1
New at this version
Version
1.2
New at this version
Version
1.2
New at this version
Version
2.6
The tool now supports resampling a multidimensional raster.
1.0
Version
3.7
New at this version
Version
2.6
The tool now supports rescaling a multidimensional raster.
1.0
Version
2.6
The tool now supports rotating a multidimensional raster.
2.1
New parameter added: clipping_extent
1.0
Version
1.0
Version
3.7
3.6
3.5
3.4
3.3
3.2
3.1
3.0
New at this version
Select Data
Version
1.3
1.0
Version
2.3
New parameter added: count
1.0
Version
2.6
Parameter overlap_type had new option added: INTERSECT_DBMS
2.3
  • count
  • out_layers_or_views
2.2
Parameter in_layer has new data type: Raster Layer
1.2
Parameter invert_spatial_relationship the NON_INVERT option is now NOT_INVERT.
1.0
Version
1.3
New at this version
Version
1.0
Version
2.6
New at this version
Version
3.7
3.5
  • THEOS-2
  • WorldView Legion
3.3
3.1
  • BLACKSKY
  • PLANETSCOPE
3.0
  • LANDSAT_9BANDS
2.9
2.8
2.2
2.1
  • product_definition
  • product_band_definitions
1.4
  • time_interval
  • time_interval_units
1.3
1.1
Parameter cell_size had 2 data types removed:
  • Raster Layer
  • Point
1.0
Version
3.5
Parameter data_type had new option added: SAR
3.1
Parameter data_type had new option added: DATE
2.9
New parameter added: multidimensional_info
1.0
Version
3.3
2.6
New at this version
Version
2.2
  • CLEAR_SUBTYPE_FIELD
  • DO_NOT_CLEAR
1.0
Version
1.0
Version
3.0
Parameter summary changed from Required to Optional
Parameter tags changed from Required to Optional
2.5
  • publish_web_layer
  • publish_results
  • portal_folder
  • package_item_id
1.0
Version
2.6
This tool supports shifting a multidimensional raster.
1.0
Version
1.0
Version
1.0
Version
1.0
Version
1.0
Version
1.0
Version
2.1
Parameter in_raster has 2 new data types:
  • Mosaic Layer
  • Mosaic Dataset
1.4
Environments added:
1.0
Version
2.7
New at this version
Version
2.3
New at this version
Version
3.3
New at this version
Version
1.4
Environments added:
1.2
New parameter added: estimate_statistics
1.0
Version
2.5
New at this version
Version
1.0
Version
1.1
1.0
Version
1.0
Version
2.9
  • geometry_type
  • method
2.6
1.0
Version
3.3
1.0
Version
3.2
2.6
Parameter input_paths has new data type: Raster Dataset
2.3
New at this version
Version
2.7
New at this version
Version
1.0
Version
2.6
New at this version
Version
1.0
Version
1.0
Version
1.0
Version
1.2
New at this version
Version
2.1
New at this version
Version
2.8
  • Trace Network
2.4
New at this version
Version
3.7
New parameter added: upgrade_level
3.3
2.7
New at this version
Version
2.6
New at this version
Version
3.0
1.0
Version
3.2
New at this version
Version
3.1
2.2
New at this version
Version
2.8
Parameter in_dataset allows trace networks as input.
2.4
New at this version
Version
3.7
New parameter added: utility_network_version
3.2
Parameter out_dataset has new data type: Catalog Layer
Parameter in_dataset has new data type: Catalog Layer
2.7
Parameter in_dataset has new data type: Trace Network Layer
2.5
Parameter out_dataset has new data type: Parcel Layer
Parameter in_dataset has new data type: Parcel Layer
2.3
Parameter out_dataset has new data type: Dimension Layer
Parameter in_dataset has new data type: Dimension Layer
2.2
Parameter out_dataset has new data type: Utility Network Layer
Parameter in_dataset has new data type: Utility Network Layer
2.0
  • Annotation Layer
  • Parcel Fabric Layer for ArcMap
Parameter in_dataset had data type removed: Parcel Fabric Layer
Parameter out_dataset has 2 new data types:
  • Annotation Layer
Parameter out_dataset had data type removed: Parcel Fabric Layer
1.0
Version
2.7
Parameter input_prerequisite_check no longer performs prerequisite checks specific to user-schema geodatabases in Oracle.
Tool checks for workgroup and desktop licenses and does not allow upgrades beyond geodatabase version 10.8.1.2.6.
1.0
Version
3.1
New parameter added: date_format
2.9
  • MOBILE
  • ALL
2.8
New at this version
Version
3.2
New at this version
Version
2.6
New at this version
Version
3.0
New parameter added: in_folder
Parameter in_slpk changed from Required to Optional
2.0
New at this version
Version
2.6
Parameter in_topology allows topology-enabled feature service URL as input.
1.3
New at this version
Version
2.6
This tool supports warping a multidimensional raster.
1.2
1.0
Version
2.6
1.2
1.0
Version
1.0
Version
2.1
New at this version
Version
2.9
2.6
1.0
