Trim Archive History (Data Management Tools)
Summary
Deletes retired archive records from nonversioned archive-enabled datasets.
Over time, the archive history of a table can increase exponentially as the edit history is maintained. This can affect storage and backup management decisions and may affect performance if the data becomes too large for the system in place. Some organizations may use nonversioned archiving because it is required for certain functionality and have no need for historical records, or they may want to remove older data that is no longer relevant. This tool allows you to delete all retired rows or the retired rows older than a specified date.
Learn more about trimming the archive history
Usage
  • This tool only supports datasets that are stored in an enterprise or mobile geodatabase. The following databases are supported:
    • IBM Db2
    • Microsoft SQL Server
    • Oracle
    • PostgreSQL
    • SAP HANA
  • The input table must be archive enabled.
  • The input table must be nonversioned. Versioned tables are not supported.
  • You must be connected to the geodatabase as the data owner to run this tool.
  • You can access the last trimmed date of a dataset from the feature class or table properties dialog box.
  • If the Input Table parameter value has been published as a feature service and is enabled for offline use, and the Trim Before Date parameter value is unspecified, and if any of the rows are referenced by a replica that has not synced those rows, the tool will fail. If the Trim Before Date parameter value is specified and the retired rows are referenced by a replica that has not synced those rows, you must provide an earlier Trim Before Date value or unregister the replica.
Parameters
Label Explanation Data type
Input Table
The nonversioned archive-enabled table with the archive history to be trimmed.
Table View
Trim Mode
Specifies the trim mode that will be used to trim the archive history.
At the current version of ArcGIS Pro, only the delete trim mode is available.
  • Delete—The archive records will be deleted.
String
Trim Before Date
(Optional)
Archive records older than this date and time will be deleted. The date and time must be in UTC. If no date is provided, all archive records will be deleted.
Date
Derived output
Output Table
The updated input table with the trimmed archive history.
Table
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: No
  • Standard: Yes
  • Advanced: Yes
