Create 3D Object Scene Layer Content (Data Management Tools)
Summary
Creates a scene layer package (.slpk) or scene layer content (.i3sREST) from a multipatch or 3D object feature layer input.
Usage
  • Supported inputs include a multipatch feature layer or feature class, 3D object feature layer, or CAD DWG and DGN layers.
  • Match the output coordinate system with the spatial reference of the web scene in which it will be displayed. If the intended display environment will be a global web scene, the output coordinate system must use GCS WGS84 or China Geodetic Coordinate System 2000.
  • Consider the following when defining z-coordinates in the 3D data being processed:
    • If the output scene layer package will have x,y coordinates in GCS WGS84, the z-coordinate system can be defined using any ellipsoidal datum or EGM96 or EGM2008 through the Output Coordinate System parameter. If the z-coordinate system is undefined, the vertical units will be meters.
    • If the output scene layer package will store x,y values in projected coordinates and the z-coordinate system is not defined, the vertical units will be the same as the x,y coordinates. For 3D features with undefined z-units that differ from the x,y units, you can use either the Adjust 3D Z tool to convert z-values to a matching linear unit or the Define Projection tool to define the correct z-datum.
  • The elevation of multipatch or 3D object feature layers must be defined with absolute heights. If an offset is applied to the layer, the offset will be applied to the z-values of the features' geometry. The offset cannot be removed after the scene layer is created.
  • Big integer, date only, time only, and timestamp offset fields are not currently supported in scene layers. Use the Export Features tool to create a copy of a feature class without unsupported field types that you can input to this tool.
  • Use the Time Zone environment if the input feature class contains date fields. Using this environment will encode the time value in the local time with an offset from UTC, or in UTC if that option is chosen. For more information about using time with scene layers, see Time-enabled scene layers.
  • Use the Target Cloud Connection parameter to output scene layer content to an object store located in the cloud such as Amazon S3, Azure Blob storage, Alibaba OSS, or Google Cloud. This content can be published as a scene service and the location you choose must be registered as a user-managed data store in ArcGIS Enterprise.
  • You can build a connection file (.acs) using the Create Cloud Storage Connection File tool.
Parameters
Label Explanation Data type
Input Dataset
The input multipatch feature layer or feature class, 3D object feature layer, or CAD DWG or DGN layer.
Layer File; Feature Layer; Feature Class
Output Scene Layer Package
The output scene layer package (.slpk).
File
(Optional)
The coordinate system of the output scene layer package. It can be any projected or custom coordinate system. Supported geographic coordinate systems include WGS84 and China Geodetic Coordinate System 2000. WGS84 and EGM96 Geoid are the default horizontal and vertical coordinate systems, respectively. The coordinate system can be specified in any of the following ways:
  • Specify the path to a .prj file.
  • Reference a dataset with the correct coordinate system.
  • Use an arcpy.SpatialReference object.
Spatial Reference
Geographic Transformation
The datum transformation method that will be used when the input layer's coordinate system uses a datum that differs from the output coordinate system. All transformations are bidirectional, regardless of the direction implied by their names. For example, NAD_1927_to_WGS84_3 will work correctly even if the datum conversion is from WGS84 to NAD 1927.
The ArcGIS coordinate system data is required for vertical datum transformations between ellipsoidal and gravity-related and two gravity-related datums.
String
Texture Optimization
(Optional)
Specifies the textures that will be optimized according to the target platform where the scene layer package will be used.
Caution:
Optimizations that include KTX2 may take significant time to process. For fastest results, use the Desktop or None options.
  • All—All texture formats will be optimized including JPEG, DXT, and KTX2 for use in desktop, web, and mobile platforms.
  • Desktop—Windows, Linux, and Mac supported textures will be optimized including JPEG and DXT for use in ArcGIS Pro clients on Windows and ArcGIS Maps SDKs desktop clients on Windows, Linux, and Mac. This is the default.
  • Mobile—Android and iOS supported textures will be optimized including JPEG and KTX2 for use in ArcGIS Maps SDKs mobile applications.
  • None—JPEG textures will be optimized for use in desktop and web platforms.
String
(Optional)
The target cloud connection file (.acs) where the scene layer content (.i3sREST) will be output.
Folder
Environments
Time Zone
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
