Disable COGO (Data Management Tools)
Summary
Disables COGO on a line feature class and removes COGO fields and COGO-enabled labeling and symbology. COGO fields can be deleted.
Usage
Caution:
This tool modifies the input data. See Tools that modify or update the input data for more information and strategies to avoid undesired data changes.
Disables the following COGO fields on the selected line feature class:
ArcLength,Direction,Distance,Radius, andRadius2. These fields can be deleted.Removes COGO-related labeling and symbology from the line feature class.
If a line feature class is not COGO enabled, the Traverse tool
will not store any entered dimensions.Use the Enable COGO tool to enable COGO on a line feature class.
Parameters
| Label | Explanation | Data type |
Input Line Features |
The line feature class that will have COGO disabled. |
Feature Layer |
Derived output
Updated Input Line features |
The COGO disabled dataset. |
Table View |
Environments
This tool does not use any geoprocessing environments.
Licensing information
- Basic: No
- Standard: Yes
- Advanced: Yes
