Import Replica Schema (Data Management Tools)
Summary
Applies replica schema differences using an input replica geodatabase and an XML schema file.
Usage
The input replica schema changes file must be XML.
Modifying the schema of a replica to match the schema of a relative replica is a separate process from data synchronization. Use the following tools for this purpose:
Use the Compare Replica Schema tool to generate an
.xmlfile containing the schema changes.Import the changes using the Import Replica Schema tool.
To apply replica schema changes, run the Export Replica Schema tool to export the schema of the replica with the changes to an
.xmlfile. Then use the.xmlfile as input to the Compare Replica Schema tool.
Parameters
| Label | Explanation | Data type |
Import to Replica Geodatabase |
The replica geodatabase to which the replica schema will be imported. The geodatabase can be a local geodatabase or a geodata service. |
Workspace; GeoDataServer |
Replica Schema Changes File |
The file that contains the replica schema differences that will be imported. |
File |
Derived output
Output Replica Workspace |
The updated replica geodatabase. |
Workspace |
Environments
Current Workspace, Scratch Workspace
Licensing information
- Basic: No
- Standard: Yes
- Advanced: Yes
