Compare Replica Schema (Data Management Tools)
Summary
Generates an .xml file that describes schema differences between a replica geodatabase and the relative replica geodatabase.
Usage
Modifying the schema of a replica to match the schema of a relative replica is a separate process from data synchronization. Use the following tools for this purpose:
Use the Compare Replica Schema tool to generate an
.xmlfile containing the schema changes.Import the changes using the Import Replica Schema tool.
To apply replica schema changes, run the Export Replica Schema tool to export the schema of the replica with the changes to an
.xmlfile. Then use the.xmlfile as input to the Compare Replica Schema tool.
The output replica schema changes file must be in XML format.
Parameters
| Label | Explanation | Data type |
Compare to Replica Geodatabase |
The replica geodatabase to which the replica schema will be compared. The geodatabase can be a local geodatabase or a geodata service. |
Workspace; GeoDataServer |
Relative Replica Schema File |
The file that contains the relative replica schema that will be used for the comparison. |
File |
Output Replica Schema Changes File |
The file that will contain a description of the schema differences. |
File |
Environments
Current Workspace, Scratch Workspace
Licensing information
- Basic: No
- Standard: Yes
- Advanced: Yes
