Export Replica Schema (Data Management Tools)
Summary
Creates a replica schema file with the schema of an input one- or two-way replica.
Usage
  • The output schema file must be in XML format. You must specify .xml as the file suffix.
  • Modifying the schema of a replica to match the schema of a relative replica is a separate process from data synchronization. Use the following tools for this purpose:
    • Use the Compare Replica Schema tool to generate an .xml file containing the schema changes.
    • Import the changes using the Import Replica Schema tool.
    • To apply replica schema changes, run the Export Replica Schema tool to export the schema of the replica with the changes to an .xml file. Then use the .xml file as input to the Compare Replica Schema tool.
  • This tool is used when synchronizing replica schema. Additionally, see the Compare Replica Schema and Import Replica Schema tools.
Parameters
Label Explanation Data type
Export from Replica Geodatabase
The replica geodatabase from which the replica schema will be exported. The geodatabase can be a local or remote geodatabase.
Workspace; GeoDataServer
Output Replica Schema File
The file to which the replica schema will be exported.
File
Replica
The replica from which the schema will be exported.
String
Environments
Current Workspace, Scratch Workspace
Licensing information
  • Basic: No
  • Standard: Yes
  • Advanced: Yes
