Create Enterprise Geodatabase (Data Management Tools)
Summary
Creates a database, storage locations, and a database user to act as the geodatabase administrator and owner of the geodatabase. Functionality varies depending on the database management system used. The tool grants the geodatabase administrator the privileges required to create a geodatabase; it then creates a geodatabase in the database.
Usage
  • The following table indicates the tool functionality for each type of database management system:
    Function
    Database
    Create a database
    PostgreSQL and Microsoft SQL Server
    Create a tablespace
    Oracle
    Create a geodatabase administrator user in the database
    Oracle, PostgreSQL, and SQL Server
    The tool only creates a user in SQL Server if you create an sde-schema geodatabase.
    Grant the geodatabase administrator the privileges required to create a geodatabase, upgrade a geodatabase, and remove database connections
    Oracle and PostgreSQL
    Grant the geodatabase administrator the privileges required to create a geodatabase and remove database connections
    SQL Server (if creating an sde-schema geodatabase)
    Grant the geodatabase administrator the privileges required to import data using Oracle Data Pump
    Oracle
    Create a geodatabase in the specified database
  • You must have ArcGIS Desktop (Standard or Advanced), ArcGIS Pro (Standard or Advanced), or ArcGIS Server installed on the computer where you'll create the geodatabase. If you're using Oracle or SQL Server, you must also install and configure a database management system client on the computer where the ArcGIS client is installed.
  • Before you can create a geodatabase in Oracle, you must download the DatabaseSupport.zip (Windows) or DatabaseSupport.tar (Linux) file from My Esri to obtain the st_shapelib (Windows) or libst_shapelib (Linux) library. Place the library on the Oracle server. Be sure to copy the correct library for the operating system where Oracle is installed.
  • You must make a spatial type available to the PostgreSQL database cluster before you create a geodatabase. To use the ST_Geometry type, you must download the DatabaseSupport.zip (Windows) or DatabaseSupport.tar (Linux) file from My Esri to obtain the st_geometry library. Place the library in the %PostgreSQL%\lib directory (Windows) or $PKGLIBDIR directory (Linux) on the PostgreSQL server. Be sure to copy the correct library for the version of PostgreSQL you're using and the operating system where PostgreSQL is installed. To use a PostGIS spatial type, you must install PostGIS in the PostgreSQL database cluster.
  • This tool is not supported with database services.
  • Once the geodatabase is created in PostgreSQL or Oracle, you cannot rename the database in which it is stored. The database name is stored in geodatabase system tables and is used to fully qualify table and feature class names; changing the database name using database tools makes the geodatabase data inaccessible.
  • To generate a license file for an enterprise geodatabases licensed with ArcGIS Enterprise on Kubernetes, use the exportGeodatabaseLicense REST operation.
Parameters
Label Explanation Data type
Database Platform
Specifies the type of database management system to which a connection to create a geodatabase will be made.
  • Oracle—Connection to an Oracle instance will be made.
  • PostgreSQL—Connection to a PostgreSQL database cluster will be made.
  • SQL Server—Connection to a Microsoft SQL Server instance will be made.
String
Instance
The name of the instance.
For SQL Server, provide the SQL Server instance name. Case-sensitive or binary collation SQL Server instances are not supported.
For Oracle, provide either the TNS name or the Oracle Easy Connection string.
For PostgreSQL, provide the name of the server where PostgreSQL is installed.
String
Database
(Optional)
The name of the database.
This parameter is valid for PostgreSQL and SQL Server. You can provide either the name of an existing, preconfigured database or a name for a database that the tool will create.
If the tool creates the database in SQL Server, the file sizes will be either the same as defined for the SQL Server model database or 500 MB for the .mdf file and 125 MB for the .ldf file, whichever is greater. Both the .mdf and .ldf files are created in the default SQL Server location on the database server. Do not name the database sde.
If the tool creates the database in PostgreSQL, it uses the template1 database as the template for the database. If you need to use a different template—for example, you require a template that is enabled for PostGIS—you must create the database before running this tool and provide the name of the existing database. Always use lowercase characters for the database name. If you use uppercase letters, the tool will convert them to lowercase.
String
Operating System Authentication
(Optional)
Specifies the type of authentication that will be used for the database connection.
  • Checked—Operating system authentication will be used. The login information that you provide for the computer where you run the tool is the login that will be used to authenticate the database connection. If the database management system is not configured to allow operating system authentication, authentication will fail.
  • Unchecked—Database authentication will be used. You must provide a valid database username and password for authentication in the database. This is the default. If the database management system is not configured to allow database authentication, authentication will fail.
Boolean
Database Administrator
(Optional)
The database administrator user for database authentication. For Oracle, use the sys user. For PostgreSQL, specify a user with superuser status. For SQL Server, specify any member of the sysadmin fixed server role.
String
Database Administrator Password
(Optional)
The database administrator password for database authentication.
Encrypted String
Sde Owned Schema
(Optional)
This parameter is only relevant to SQL Server and specifies whether the geodatabase will be created in the schema of a user named sde or in the dbo schema in the database. If creating a dbo-schema geodatabase, connect as a user who is dbo in the SQL Server instance.
  • Checked—The geodatabase repository is owned by and will be stored in the schema of a user named sde. This is the default.
  • Unchecked—The geodatabase repository will be stored in the dbo schema in the database.
Boolean
Geodatabase Administrator
(Optional)
The name of the geodatabase administrator user.
If you are using PostgreSQL, this value must be sde. If the sde login role does not exist, this tool will create it and grant it superuser status in the database cluster. If the sde login role exists, this tool will grant it superuser status if it does not already have it. The tool also creates an sde schema in the database and grants usage on the schema to public.
If you are using Oracle, the value is sde. If the sde user does not exist in the Oracle database, the tool will create it and grant it the privileges required to create and upgrade a geodatabase and disconnect users from the database. The tool also grants privileges to allow data imports using Oracle Data Pump. If the sde user exists, the tool will grant these same privileges to the existing user.
Creating or upgrading user-schema geodatabases in Oracle is no longer supported.
If you are using SQL Server and specified an sde-schema geodatabase, this value must be sde. The tool will create an sde login, database user, and schema and grant it privileges to create a geodatabase and remove connections from the SQL Server instance. If you specified a dbo schema, do not provide a value for this parameter.
String
Geodatabase Administrator Password
(Optional)
The password for the geodatabase administrator user. If the geodatabase administrator user exists in the database management system, the password you provide must match the existing password. If the geodatabase administrator user does not exist, provide a valid database password for the new user. The password must meet the password policy enforced by the database.
The password is an encrypted string.
Encrypted String
Tablespace Name
(Optional)
The name of the tablespace.
This parameter is only valid for Oracle and PostgreSQL database management system types. For Oracle, do one of the following:
  • Provide the name of an existing tablespace. This tablespace will be used as the default tablespace for the geodatabase administrator user.
  • Provide a valid name for a new tablespace. The tool will create a 400 MB tablespace in the Oracle default storage location and set it as the geodatabase administrator's default tablespace.
  • Leave the tablespace blank. The tool will create a 400 MB tablespace named SDE_TBS in the Oracle default storage location. The SDE_TBS tablespace will be set as the geodatabase administrator's default tablespace.
This tool does not create a tablespace in PostgreSQL. You must either provide the name of an existing tablespace to be used as the database's default tablespace or leave this parameter blank. If you leave the parameter blank, the tool will create a database in the pg_default tablespace.
String
Authorization File
The keycodes file that was created when ArcGIS Server was authorized. If you have not done so, authorize ArcGIS Server to create this file.
This file is in the <drive>\Program Files\ESRI\License<release#>\sysgen folder on Windows or the /arcgis/server/framework/runtime/.wine/drive_c/Program Files/ESRI/License<release#>/sysgen directory on Linux.
Tip:
The /.wine directory is a hidden directory.
You may need to copy the keycodes file from the ArcGIS Server machine to a location that is accessible to the tool.
File
Spatial Type
(Optional)
Specifies the spatial type that will be used. This is only applicable to PostgreSQL databases.
  • ST_Geometry—The ST_Geometry spatial type will be used. This is the default.
  • PostGIS—The PostGIS spatial type will be used.
String
Derived output
Create Enterprise Geodatabase Succeeded
Specifies whether the enterprise geodatabase was successfully created.
Boolean
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: No
  • Standard: Yes
  • Advanced: Yes
