Database and data warehouse clients
Database client software allows you to communicate between a client application and the relational database management system or data warehouse. To connect to the database or data warehouse listed in the table below, install the corresponding database client on your ArcGIS client machines.
Verify that the database client supports the operating system of the machine on which you install ArcGIS software.
Relational database or data warehouse
Database client
Amazon Redshift
Amazon Redshift ODBC driver
Amazon Relational Database Service (RDS) for Oracle
Oracle Database Client
Amazon RDS for SQL Server
Microsoft ODBC driver for SQL Server
Dameng
Dameng DM
Google BigQuery
Magnitude Simba ODBC driver
Google Cloud SQL for SQL Server
IBM Db2
IBM Data Server Runtime Client for Db2
Microsoft Azure SQL Database
Microsoft Azure SQL Managed Instance
Microsoft SQL Server
Oracle
Supported workload types of Oracle Autonomous Database
Oracle Base Database Service
SAP HANA
SAP HANA client
SAP HANA Cloud
SAP HANA client
Snowflake
Snowflake ODBC driver
Teradata Vantage
Teradata ODBC driver and associated files (GSS client and ICU library)
Obtain the database client from the database or data warehouse vendor and follow their client installation instructions to set up the client on your computer. IBM Data Server Runtime Client for Db2, the Windows version of the Microsoft ODBC driver for SQL Server, and the Oracle Instant Client are also available on My Esri.
For information on supported database client versions for the ArcGIS release you're using, see the ArcGIS system requirements for the database to which you need to connect. You can access system requirements pages from Supported databases and data warehouses.
Note the following in regard to database clients and ArcGIS:
  • No database client is required to connect to SQLite or a GeoPackage.
  • No database client is required to connect to a document database.
  • ArcGIS clients include the files you need to connect to PostgreSQL, so you don't need to install a PostgreSQL client.
  • To connect from 64-bit ArcGIS clients (such as ArcGIS Server or ArcGIS Pro), you must install 64-bit database clients.
