ArcGIS requirements for using databases in the cloud
There are two basic types of databases in the cloud: databases that are installed on virtual machines in the cloud and databases that are available as database-as-a-service offerings.
When you use a database installed on a virtual machine in the cloud, you have access to the virtual machine where the database is installed and are usually responsible for maintaining it. This is generally true whether you install the database on the virtual machine or you use an image to launch an instance that includes an installation of the database. You are also responsible for most maintenance tasks on these types of databases.
This is different from database-as-a-service offerings, for which you do not have access to the machine that serves up the database or data warehouse. That means that you do not have to perform maintenance tasks—such as applying security patches—on the database, data warehouse, or operating system. But it also means that you often do not have control over changes in functionality that the service provider introduces. For example, if they remove support for an option or alter the behavior of an existing option you are using, those changes take effect when the provider pushes out updates.
Connections from ArcGIS software to databases or data warehouses in the cloud must originate from machines in the same cloud. For best performance, connections should originate from machines in the same cloud region. In the majority of cases, connection and query performance is poor when you connect from ArcGIS clients installed on-premises to databases or data warehouses in the cloud, connect from ArcGIS clients in the cloud to databases or data warehouses on-premises, or make connections between clients and databases or data warehouses in different cloud regions. In these scenarios, connections to the database may time out.
The information below applies to ArcGIS Enterprise 12.1 and ArcGIS Pro 3.7.
Support for databases installed in the cloud
To determine whether a cloud platform is supported for use with ArcGIS, you must know the specifications of the cloud virtual machines. A cloud platform is supported for use with a database that ArcGIS supports as long as the virtual machines provided on that cloud platform meet the operating system and system specification requirements for use with the ArcGIS clients and database you want to install.
Support for these virtual machines is predicated on the assumption that the virtual machines behave the same as a physical machine available on-premises that has the same specifications. In most cases, Esri Support attempts to replicate issues using on-premises machines with the same specifications as the cloud virtual machine you are using.
In addition, Oracle Base Database Service is certified for use with ArcGIS.
Supported cloud-based database services
Esri provides tooling to deploy ArcGIS Enterprise software, ArcGIS Pro, and many supported database-as-a-service offerings on Amazon Web Services (AWS) and Microsoft Azure. When deploying on these two cloud platforms, it's recommended that you use the specialized tooling and Esri images to simplify deployment and technical support. For cloud platforms for which Esri does not provide specialized deployment tooling, support is limited to troubleshooting ArcGIS software-specific issues that can be replicated on-premises.
The following database-as-a-service offerings are supported for use with ArcGIS. When minor versions are listed, they are the minimum supported minor versions.
The links below take you to external documentation provided by cloud vendors.
Amazon Aurora (PostgreSQL-compatible edition) versions 14.19, 15.14, 16.10, and 17.6
AWS installs a compatible PostGIS version.
Amazon RDS for PostgreSQL versions 14.20, 15.15, 16.11, 17.7, and 18.1
For each of these supported versions of Amazon RDS for PostgreSQL, ArcGIS supports the PostGIS versions that Amazon Web Services supports.
Amazon RDS for SQL Server versions 2019 and 2022
Google Cloud SQL for PostgreSQL 14.20, 15.15, 16.11, 17.7, and 18.1
For each of these supported versions of Google Cloud SQL for PostgreSQL, ArcGIS supports the PostGIS versions that Google Cloud supports.
Google Cloud SQL for SQL Server 2019 and 2022
Microsoft Azure Database for PostgreSQL (Flexible Server) 14.20, 15.15, 16.11, 17.7, and 18.1
For each of these supported versions of Microsoft Azure Database for PostgreSQL, ArcGIS supports the PostGIS versions that Microsoft Azure supports.
Microsoft Azure SQL Database or Microsoft Azure SQL Managed Instance version 12
Oracle Autonomous Database version 19c—Autonomous Data Warehouse and Autonomous Transaction Processing
Geoprocessing tools are supported on equivalent database-as-a-service offerings unless otherwise stated in the geoprocessing tool usage information. For example, if tool usage indicates the tool is supported with PostgreSQL, it works with Amazon RDS for PostgreSQL, Aurora PostgreSQL, Azure Database for PostgreSQL, and Google Cloud SQL for PostgreSQL unless the tool's usage statements indicate these are not supported.
Limitations
Be aware of the following limitations when using database-as-a-service offerings with ArcGIS software:
PostGIS 3.5.3 and 3.6.0 are not supported due to PostGIS issue 5978.
ArcGIS supports elastic clusters with Microsoft Azure Database for PostgreSQL (Flexible Server), but geodatabases are not supported in them.
Because you cannot load the ST_Geometry library to a database-as-a-service offering, only the PostGIS spatial types are supported when using Amazon Aurora (PostgreSQL-compatible edition), Amazon RDS for PostgreSQL, Google Cloud SQL for PostgreSQL, and Microsoft Azure Database for PostgreSQL (all options), and only the SDO_Geometry spatial type is supported when using Amazon RDS for Oracle or Autonomous Transaction Processing.
The following functions are not present in geodatabases in Amazon RDS for Oracle or Autonomous Transaction Processing:
GDB_UTIL.get_extent(),GDB_UTIL.geometry_type, andGDB_UTIL.spatial_ref_info().Amazon RDS for Oracle is not included in ArcGIS Enterprise on Amazon Web Services deployment tools; use AWS tools instead to create an Amazon RDS for Oracle instance.
If you do not use or cannot use the Esri cloud deployment tools to create a database, and you want to create a geodatabase in the supported database-as-a-service offerings listed above, you must use the Enable Enterprise Geodatabase geoprocessing tool to create a geodatabase. Do not use the Create Enterprise Geodatabase tool.
Only sde-schema geodatabases are supported when you create a geodatabase in Amazon RDS for SQL Server, Google Cloud SQL for SQL Server, Microsoft Azure SQL Database, or Microsoft Azure SQL Managed Instance.
Operating system authenticated connections are not supported from ArcGIS clients to most database-as-a-service offerings. Microsoft Entra ID options are available when connecting to Azure SQL Database or Azure SQL Managed Instance.
When using the Database Connections dialog box in ArcGIS Pro to connect to a geodatabase in Azure SQL Database as any user other than the database administrator, you must type the name of the database in the Database field.
If the SAP HANA Cloud instance contains a geodatabase, connecting users require
EXECUTE ON ACQUIRE_APPLICATION_LOCKandEXECUTE ON RELEASE_APPLICATION_LOCKprivileges. See Privileges for geodatabases in SAP HANA for information about privileges required for specific tasks.As with all service offerings, database-as-a-service providers can change settings and functionality in their offerings, even in minor releases. By using a database-as-a-service with ArcGIS, you acknowledge that it is possible that these changes made by the service provider could adversely affect access from ArcGIS to the database. Esri will attempt to patch such issues in ArcGIS software due to these changes. However, the time required to resolve such issues will be assessed on a case-by-case basis.
Supported cloud data warehouses
Cloud data warehouses are similar to database-as-a-service offerings; the vendor provides you with a data warehouse that they maintain and update. The following data warehouses hosted in cloud environments are supported with ArcGIS:
Geodatabases are not supported in the cloud data warehouses listed above.
Software required to connect to a database or data warehouse
Database client software allows communication between a client application and the database or data warehouse to which the client connects.
When you install an ArcGIS client on a virtual machine in the cloud or connect to a database that is listed in the Supported cloud-based database services section above, you may need to install database management system client files on the ArcGIS client machine. These client files are available from their respective database vendors. Follow instructions from the vendors to install and configure these files, and read the connection information in ArcGIS help for additional configuration needed to connect from ArcGIS clients.
In most cases, install the latest database client software that is supported for the database, database-as-a-service, or cloud data warehouse version that you need to access. The following are additional requirements or exceptions to this guideline:
The minimum SAP HANA ODBC client required to connect from ArcGIS to SAP HANA Cloud is 2.15.17. Install your ArcGIS client on a machine (physical or virtual) that is located as close as possible to the location where you deployed SAP HANA Cloud.
To connect to Microsoft Azure SQL Database or Microsoft Azure SQL Managed Instance, use at least the minimum ODBC version supported by Microsoft.
To connect from ArcGIS to BigQuery, install Magnitude Simba ODBC driver version 3.1.2.1004 or later.
To connect from ArcGIS to Snowflake using key-pair authentication, install the Snowflake ODBC driver version 3.4.0 or later.
In the following scenarios, database clients are provided for you and you no not need to install or configure them:
If you use an Azure image provided by Esri to deploy ArcGIS Enterprise and ArcGIS Pro, the required database clients are installed that allow you to connect to supported database-as-a-service offerings on Azure. Similarly, if you use ArcGIS Enterprise tools for Amazon Web Services, the database clients are installed that allow you to connect to supported Amazon RDS offerings.
ArcGIS Enterprise on Kubernetes includes client files to connect to the databases and cloud data warehouses that it supports.
