Create a geodatabase in PostgreSQL on Windows
Available with Standard or Advanced license.
To create a geodatabase in a PostgreSQL database, run a geoprocessing tool or Python script from an ArcGIS client.
When you create a geodatabase using ArcGIS Pro 3.7, the geodatabase version is 12.1.0.x.
Start by reading the prerequisites below, and follow the instructions that apply to your situation.
These instructions apply to PostgreSQL installations on a Microsoft Windows server. If you have PostgreSQL installed on a Linux server, see Create a geodatabase in PostgreSQL on Linux.
Prerequisites
Before you create a geodatabase in PostgreSQL, do the following:
  1. Confirm the ArcGIS, PostgreSQL, and operating system combinations you want to use are supported.
  2. Obtain an ArcGIS Server keycodes file and place it in a location you can access from the ArcGIS client you'll use to create the geodatabase.
  3. If you will create or enable the geodatabase in an existing PostgreSQL database, ensure that the public schema exists.
    One of the geodatabase system tables is created in the public schema.
  4. Determine who will create the geodatabase, because that affects who creates the database and which tool you use. Follow the instructions that apply to your situation:
You are the PostgreSQL and geodatabase administrator
If you perform the role of both the database administrator and geodatabase administrator and know the password for both login roles, you can use the Create Enterprise Geodatabase geoprocessing tool or a Python script that calls the tool to create a geodatabase in PostgreSQL.
The Create Enterprise Geodatabase tool creates the database objects necessary for the geodatabase and grants required privileges. To achieve this, specific default settings are used. The following describes what the Create Enterprise Geodatabase tool does and the settings it uses:
  • It creates a database using the PostgreSQL default template (template1).
    If you need a database created from a different template—for example, if you want to use a template you defined for your database cluster—you must create the database before running this tool. Then, when you run the Create Enterprise Geodatabase tool or script, specify the name of the database that you created.
  • It creates a database-authenticated sde login role in the database cluster and grants it superuser status.
    The sde user must be a superuser to create the geodatabase.
  • It creates an sde schema in the database.
    The geodatabase system tables, views, functions, and procedures are stored in the sde schema.
  • It sets the sde user as the owner of the sde schema and grants usage on the sde schema to the public role.
    Login roles that will use the geodatabase must be able to access the sde schema. Because geodatabase login roles likely do not exist yet, this tool grants usage to the public. After the geodatabase is created, you can increase security on the geodatabase by revoking usage on the sde schema from the public and granting usage only to those login groups and roles that need access to the geodatabase.
  • It creates a geodatabase.
First, you (or someone in your IT department) must install PostgreSQL and configure the database cluster.
Install and configure PostgreSQL
Follow these steps to set up a PostgreSQL database cluster to store a geodatabase:
  1. Obtain and install a supported release of PostgreSQL and configure the database cluster.
    See the PostgreSQL documentation for instructions to install and configure PostgreSQL.
  2. Configure the database cluster to accept connections.
    This includes altering the pg_hba.conf file to allow the database cluster to accept remote connections.
  3. Create a tablespace in the database cluster in which to store the database. If you do not create a tablespace, the pg_default tablespace is used.
Next, install and configure an ArcGIS client.
Provide access to a spatial type
To store a geodatabase, PostgreSQL must have access to a spatial type. You can provide the database cluster with access to the Esri ST_Geometry spatial type or install PostGIS.
When the database cluster has access to a spatial type, you can create a geodatabase.
ST_Geometry
To use ST_Geometry in the geodatabase, place the st_geometry.dll file in the PostgreSQL lib directory.
  1. Download the ST_Geometry package from My Esri.
    Packages are specific to the ArcGIS software version from which you will create the geodatabase.
    If the option to download is not present, contact your ArcGIS organization administrator.
  2. Extract the contents of the package.
  3. Place the st_geometry.dll file specific to your PostgreSQL version in the PostgreSQL lib directory. Ensure that you use the correct file version.
    The st_geometry.dll requires the Microsoft Visual C++ Redistributable Package (x64). See PostgreSQL database requirements for the package version required. If this package is not present on the PostgreSQL server, download it from the Microsoft site and install it.
PostGIS
To use PostGIS spatial types in the geodatabase, install PostGIS on the PostgreSQL database cluster. Ensure that you install the version of PostGIS supported by ArcGIS.
Install an ArcGIS client
You (or someone in your IT department) must install ArcGIS Pro (Standard or Advanced) or ArcGIS Server. You can run a Python script to create a geodatabase from either of these clients. To run the Create Enterprise Geodatabase geoprocessing tool instead of a script, install ArcGIS Pro.
You need an ArcGIS Server keycodes file to authorize the geodatabase in the next section. Even if you do not run a Python script from an ArcGIS Server machine to create the geodatabase, you must authorize ArcGIS Server to get the keycodes file. You may need to copy the keycodes file from the ArcGIS Server machine to a location that the Create Enterprise Geodatabase geoprocessing tool can access.
Run the Create Enterprise Geodatabase tool from ArcGIS Pro, or run a Python script that calls the tool from an ArcGIS Pro or ArcGIS Server machine to create a geodatabase.
Follow these steps to create a geodatabase using the Create Enterprise Geodatabase tool in ArcGIS Pro:
  1. Start ArcGIS Pro.
  2. Open the Create Enterprise Geodatabase tool.
    You can search for or browse to this tool, which is located in the Geodatabase Administration toolset of the Data Management toolbox. See Find a geoprocessing tool for general information about opening geoprocessing tools.
  3. Choose PostgreSQL from the Database Platform drop-down list.
  4. Provide the name of the PostgreSQL server in the Instance text box.
  5. In the Database text box, provide the name of the database you want to create to contain the geodatabase.
    Type the database name in lowercase; uppercase and mixed-case object names are not supported for geodatabases in PostgreSQL. If you type a database name in uppercase or mixed case, ArcGIS converts it to lowercase.
  6. You must connect to the database cluster as the postgres superuser to create the database and other objects; therefore, the Database Administrator text box defaults to postgres.
    If your superuser has a different name, provide that name in the Database Administrator text box.
    You cannot use an operating system-authenticated postgres superuser login at this release.
  7. Provide the password for the postgres superuser in the Database Administrator Password text box.
  8. Type a password for the sde user in the Geodatabase Administrator Password text box.
    If the sde user already exists in the database cluster, provide the existing user's password, and an sde schema is created in the database. If the user does not already exist, a user named sde with the password you specify is created in the database cluster, and a corresponding schema is created in the database. Usage is granted on the sde schema to the public group role.
    Tip:
    To make the schema more secure after the geodatabase is created, you can revoke usage from the public group role, create a new group role, grant usage on the sde schema to that role, and grant the group role to all login roles that need to access the geodatabase.
    The geodatabase administrator must be named sde in PostgreSQL, so the Geodatabase Administrator text box is prepopulated with sde.
  9. If you configured a tablespace to use as the default tablespace for the database, provide its name in the Tablespace Name text box.
    This tool does not create a tablespace; you must either specify an existing tablespace or leave this text box blank. If you do not specify a tablespace, the database is created in pg_default.
  10. For Authorization File, browse to and choose the keycodes file that was created when you authorized ArcGIS Server.
    This file is written to \\Program Files\ESRI\License<release#>\sysgen when you install ArcGIS Server on Windows and to /arcgis/server/framework/runtime/.wine/drive_c/Program Files/ESRI/License<release#>/sysgen when you install ArcGIS Server on Linux. Copy this file to a location that is accessible to the client from which you will create the geodatabase. If you have not already done so, authorize ArcGIS Server now to create this file.
  11. Use the Spatial Type drop-down list to choose the spatial type the geodatabase will use: either ST_Geometry or PostGIS.
  12. Click Run.
You now have a geodatabase in a PostgreSQL database.
You can find messages related to geodatabase creation in the sde_setup.log file, which is created in the directory specified for the TEMP variable on the computer where the script is run. If you have problems creating a geodatabase, see this file to troubleshoot the problem.
Next, you can create a user who can load data into the geodatabase.
Run a Python script from an ArcGIS client machine
You can copy, save, and run the script provided here to create a geodatabase from an ArcGIS Pro (Standard or Advanced) or ArcGIS Server machine.
Tip:
For information about running Python from an ArcGIS Server machine, see ArcGIS Server and ArcPy.
  1. Create a text file on the ArcGIS client machine and copy the following script into the file, providing information specific to your site:
    Description: Create an enterprise geodatabase in PostgreSQL with provided DBMS connection information
    Author: Esri
    # Import system modules
    import arcpy, os
    # Local variables
    # Replace license path with the location of your keycodes file
    # Replace all arcpy.management.CreateEnterpriseGeodatabase values except "POSTGRESQL", "sde", and license with information appropriate for your site
    license = os.fsencode("\\Program Files\\path\\to\\authorization_file\\keycodes")
    try:
      arcpy.management.CreateEnterpriseGeodatabase(
        "POSTGRESQL",
        "pgprod",
        "pggdb",
        "DATABASE_AUTH",
        "postgres",
        "N0pe3king!",
        "sde",
        "sdepwd2vr9dzmctBuB",
        "gis",
        license,
        "ST_GEOMETRY"
      for i in range(arcpy.GetMessageCount()):
        arcpy.AddReturnMessage(i)
        arcpy.AddMessage("+++++++++\n")
    except:
  2. Replace values as noted in the script.
  3. Save the file with a .py extension.
  4. Run the script.
    You can find messages related to geodatabase creation in the sde_setup.log file, which is created in the directory specified for the TEMP or TMP variable on the computer where the script is run. If you have problems creating a geodatabase, see this file to troubleshoot the problem.
The PostgreSQL administrator creates the database; the geodatabase administrator creates the geodatabase
If the person creating the geodatabase does not have access to the database administrator's (the postgres superuser) password, the database administrator must create the database, sde login role, and sde schema. Next, the geodatabase administrator can connect to the database using the sde login and create a geodatabase using the Enable Enterprise Geodatabase geoprocessing tool or a Python script that calls the tool.
The Enable Enterprise Geodatabase tool takes a database connection file as input and creates the geodatabase system tables, views, functions, and procedures in the sde schema. The database administrator must set up the following in the PostgreSQL database cluster before the tool can be run:
  • A login role named sde that has superuser status.
  • A database.
  • An sde schema in the database to which the sde login has been granted authority.
  • A spatial type—Either the st_geometry library must be in the lib folder PostgreSQL installation directory or PostGIS must be configured in the database.
Install and configure PostgreSQL and a spatial type
First, the database administrator must prepare PostgreSQL to store a geodatabase.
To set up the PostgreSQL database cluster as the database administrator, complete the following steps:
All database object names must use lowercase characters only.
  3. Optionally, create a tablespace in the database cluster in which to store the database.
  4. Create a login role named sde and grant it superuser status.
    Tip:
    If the geodatabase administrator will not be removing database connections, you can revoke the superuser status from the sde role after the geodatabase is created.
  5. Create the database to store the geodatabase.
  6. Create a schema named sde in the database and give the sde login role authority on the schema.
  7. Enable a spatial data type in the database.
    • To configure PostGIS in the database, see PostGIS documentation for instructions; then proceed to step 9.
    • To configure ST_Geometry, proceed to the next step.
  8. Obtain and place the ST_Geometry library in the PostgreSQL lib directory.
      The st_geometry.dll file requires the Microsoft Visual C++ Redistributable Package (x64). See PostgreSQL database requirements for the package version required. If this package is not present on the PostgreSQL server, download it from the Microsoft site and install it.
    2. Extract the contents of the ST_Geometry package.
    3. Copy the st_geometry.dll file from the extracted package and place it in the PostgreSQL lib directory on the machine where PostgreSQL is installed.
      Ensure that you copy the correct library for the version of PostgreSQL you are using. If you use the wrong one, geodatabase creation will fail.
  9. Provide the geodatabase administrator with database connection information.
    The geodatabase administrator needs to know the database cluster name, database name, and password for the sde login role.
Now that a database exists, the geodatabase administrator can install an ArcGIS client and create a geodatabase.
The geodatabase administrator needs an ArcGIS client to create the geodatabase: either ArcGIS Pro (Standard or Advanced) or ArcGIS Server.
You need an ArcGIS Server keycodes file to authorize the geodatabase in the next section. Even if you do not run a Python script from an ArcGIS Server machine to create the geodatabase, you must install and authorize ArcGIS Server to get the keycodes file. You may need to copy the keycodes file from the ArcGIS Server machine to a location that the Enable Enterprise Geodatabase geoprocessing tool can access.
Once an ArcGIS client is installed, you can connect to the database and create a geodatabase.
The geodatabase administrator can either run the Enable Enterprise Geodatabase tool from ArcGIS Pro (Standard or Advanced), or run a Python script from ArcGIS Pro or ArcGIS Server that calls the ArcPy function to create a geodatabase in the existing database.
Run the Enable Enterprise Geodatabase tool
Follow these steps to create a geodatabase using the Enable Enterprise Geodatabase tool in ArcGIS Pro:
  2. Connect to the PostgreSQL database as the sde user.
    If the sde user is a database-authenticated user, you must save the sde user's password in the database connection.
  3. Open the Enable Enterprise Geodatabase tool.
  4. Drag the new connection file into the Input Database field.
  5. To specify an Authorization File value, browse to and choose the keycodes file that was created when you authorized ArcGIS Server.
  6. Click Run.
Next, the database administrator can create login roles and matching schemas for users who will create, edit, and view data and create login roles for editors and data viewers, and grant these users the appropriate privileges.
To create the geodatabase by running a script from an ArcGIS Pro (Standard or Advanced) or ArcGIS Server machine, you can use the script provided here.
Tip:
Follow these steps to run a Python script to create a geodatabase in a PostgreSQL database:
    # Name: enable_enterprise_gdb.py
    # Description: Create an enterprise geodatabase in an existing PostgreSQL database
    import arcpy, os
    # Local variables
    # Replace paths with those appropriate to your site
    license = "\\Program Files\\path\\to\\authorization_file\\keycodes"
    tempdir = "C:\\temp\\"
    connection_file_name = "egdb_connection.sde"
    # Check for the .sde file and delete it if present
    connection_file_name_path = os.path.join(tempdir, connection_file_name)
    arcpy.env.overwriteOutput=True
      if os.path.exists(connection_file_name_path):
         os.remove(connection_file_name_path)
    # Create a connection to the geodatabase as the geodatabase administrator
    # Replace "pgprod" with the name of your PostgreSQL instance, "N0L0oking" with the sde password, and "entgdb" with the name of the database
    arcpy.management.CreateDatabaseConnection(
      tempdir,
      connection_file_name,
      "POSTGRESQL",
      "pgprod",
      "DATABASE_AUTH",
      "sde",
      "N0L0oking",
      "SAVE_USERNAME",
      "entgdb"
    # Enable geodatabase
    try:
      arcpy.management.EnableEnterpriseGeodatabase(connection_file_name_path, license)
    except:
  4. Run the script.
    You can find messages related to geodatabase creation in the sde_setup.log file, which is created in the directory specified for your TEMP or TMP variable on the computer where the script is run. If you have problems creating a geodatabase, see this file to troubleshoot the problem.
